I currently have a script that is allowing me to pull most of the information I am looking for, but the only thing I'm stuck on is pulling either all the Custom attributes or even just the one specific one I'm looking for such as last backed up date/time. Can someone look at this script below and let me know where I can add lines to make that happen.
VCenterList = @("vcenter1","vcenter2","vcenter3")
$credPath = Path Private
$fileCred = Import-CliXML -Path $credPath
# Initialize an array to store the results
$result = @()
foreach ($vcenter in $vcenterlist) {
$esxconnect = Connect-VIServer -Server $VCenter -Credential $fileCred
# Get all clusters
$clusters = Get-Cluster
# Loop through each cluster
foreach ($cluster in $clusters) {
# Get cluster tags
$clusterTags = Get-TagAssignment -Entity $cluster | Select-Object -ExpandProperty Tag
# Get VMs in the cluster
$vms = Get-VM -Location $cluster
# Loop through each VM
foreach ($vm in $vms) {
$vmHost = Get-VMHost -VM $vm
$vmTags = Get-TagAssignment -Entity $vm | Select-Object -ExpandProperty Tag
$vmDisk = $vm | Get-HardDisk
# Create a custom object for each VM
$result += [PSCustomObject]@{
vCenter = $esxconnect.Name
vCenterVersion = $esxconnect.Version
vCenterBuild = $esxconnect.Build
ClusterName = $cluster.Name
ClusterTags = ($clusterTags -join ", ")
VMName = $vm.Name
VMTags = ($vmTags | ForEach-Object {$_.Name}) -join ", "
PowerState = $vm.PowerState
NumCPU = $vm.NumCpu
MemoryMB = $vm.MemoryMB
ProvisionedSpaceGB = [Math]::Round(((($vmDisk.CapacityGB | Measure-Object -Sum).Sum)),2)
GuestOS = $vm.Guest.OSFullName
IPAddress = ($vm.Guest.IPAddress)[0]
Datastore = ($vm | Get-Datastore).Name
Host = $vmHost.Name
HostVersion = $VMHost.Version
HostBuild = $VmHost.Build
# Disconnect from the vCenter Server
Disconnect-VIServer -Server $esxConnect -Confirm:$false -ErrorAction SilentlyContinue
# Export the results to a CSV file
$outputFile = "C:\test\VM_info.csv"
$result | Export-Csv -Path $outputFile -NoTypeInformation
