VMware vSphere
  • 1.  Low power consumption box for home ESXi server
    Posted Dec 06, 2021 05:04 PM
    Hi, I currently run a home server (ESX 5) on an old desktop PC but I calculate this is now costing £120+ (I reckon its about 80w) in power per year and I cant justify it. I want something with really low power consumption and having retired, no longer have any company affiliation to help with getting licences. I am happy to continue to run my ESXi 5 licence but will modern hardware be compatible?
    Will one of these fanless micro PC's work or require drivers which don't exist?
    Can I get a free licence for a later version and will this require running vCenter (I am currently using the vSphere client)?
    Appreciate any help
    Wallport
  • 2.  RE: Low power consumption box for home ESXi server
    Posted Dec 07, 2021 12:51 PM
    Check out reddit /homelab
  • 3.  RE: Low power consumption box for home ESXi server
    Posted Dec 09, 2021 07:46 AM
    Hey ,
    Take a look to the IntelNUC ones, maybe they fit your power consumption requirements, there are bunch of models and series.
  • 4.  RE: Low power consumption box for home ESXi server
    Posted Dec 09, 2021 09:24 AM
    Hello,
    i use three intel nucs as a 2 node vsan cluster.
    One of them is the management esxi for DNS, vCenter and Witness, the another one for the 2 node vSAN Cluster.
    However you should be careful, some intel nucs has only one hard disk. That's why I have to leave the case open
    But you can use 1 or more intel nucs with a qnap as shared storage.
  • 5.  RE: Low power consumption box for home ESXi server
    Posted Dec 09, 2021 09:27 AM
    Download link for vSphere Hypervisor 7 (ESXi 7): https://customerconnect.vmware.com/en/web/vmware/evalcenter?p=free-esxi7
  • 6.  RE: Low power consumption box for home ESXi server
    Posted Dec 29, 2021 04:51 PM
    Thanks Scott/all. Am now running an ASRock Beebox-S bought on ebay for £100 with ESXi 7.2. Its stable except for the USB NIC I added which drops out every couple of days. Got some questions out about this and may need to buy one with a different chipset.
    ...and this server idles at 10w running my firewall VM!
