2018-09-25T09:03:21.314Z| vmx| I125: Log for VMware ESX pid=78552 version=6.5.0 build=build-8294253 option=Release
2018-09-25T09:03:21.314Z| vmx| I125: The process is 64-bit.
2018-09-25T09:03:21.314Z| vmx| I125: Host codepage=UTF-8 encoding=UTF-8
2018-09-25T09:03:21.314Z| vmx| I125: Host is VMkernel 6.5.0
2018-09-25T09:03:21.290Z| vmx| I125: VTHREAD initialize main thread 0 "vmx" tid 78552
2018-09-25T09:03:21.290Z| vmx| I125: Msg_SetLocaleEx: HostLocale=UTF-8 UserLocale=NULL
2018-09-25T09:03:21.290Z| vmx| I125: DictionaryLoad: Cannot open file "/usr/lib/vmware/config": No such file or directory.
2018-09-25T09:03:21.290Z| vmx| I125: ConfigDB: Failed to load /usr/lib/vmware/config
2018-09-25T09:03:21.290Z| vmx| I125: DictionaryLoad: Cannot open file "//.vmware/config": No such file or directory.
2018-09-25T09:03:21.290Z| vmx| I125: ConfigDB: Failed to load ~/.vmware/config
2018-09-25T09:03:21.309Z| vmx| I125: OBJLIB-LIB: ObjLibPlugins_Load: Loading plugin directory '/usr/lib64/vmware/plugin/objLib'
2018-09-25T09:03:21.309Z| vmx| I125: OBJLIB-LIB: ObjLibLoadPlugin: Loading plugin 'objLib/upitObjBE.so'
2018-09-25T09:03:21.309Z| vmx| I125: PluginLdr_Load: Loaded plugin 'objLib/upitObjBE.so' from '/usr/lib64/vmware/plugin/objLib/upitObjBE.so'
2018-09-25T09:03:21.309Z| vmx| I125: ObjLibPluginInit: Initialized plugin
2018-09-25T09:03:21.309Z| vmx| I125: UpitBackend_GetAPI: Received request for API com.vmware.plugin.objlib.backend.api@1.0
2018-09-25T09:03:21.309Z| vmx| I125: OBJLIB-LIB: ObjLib_RegisterDynamicBE: Back-end 'upit' found and registered as type 5
2018-09-25T09:03:21.309Z| vmx| I125: OBJLIB-LIB: ObjLibLoadPlugin: Loading plugin 'objLib/vsanObjBE.so'
2018-09-25T09:03:21.311Z| vmx| I125: PluginLdr_Load: Loaded plugin 'objLib/vsanObjBE.so' from '/usr/lib64/vmware/plugin/objLib/vsanObjBE.so'
2018-09-25T09:03:21.311Z| vmx| I125: ObjLibPluginInit: Initialized plugin
2018-09-25T09:03:21.311Z| vmx| I125: VsanBackend_GetAPI: Received request for API com.vmware.plugin.objlib.backend.api@1.0
2018-09-25T09:03:21.311Z| vmx| I125: OBJLIB-LIB: ObjLib_RegisterDynamicBE: Back-end 'vsan' found and registered as type 3
2018-09-25T09:03:21.311Z| vmx| I125: 78552:VVOLLIB : VVolLib_GetSoapContext:379: Using 30 secs for soap connect timeout.
2018-09-25T09:03:21.311Z| vmx| I125: 78552:VVOLLIB : VVolLib_GetSoapContext:380: Using 200 secs for soap receive timeout.
2018-09-25T09:03:21.311Z| vmx| I125: OBJLIB-LIB: Objlib initialized.
2018-09-25T09:03:21.311Z| vmx| I125: DictionaryLoad: Cannot open file "/usr/lib/vmware/config": No such file or directory.
2018-09-25T09:03:21.311Z| vmx| I125: DictionaryLoad: Cannot open file "//.vmware/config": No such file or directory.
2018-09-25T09:03:21.311Z| vmx| I125: DictionaryLoad: Cannot open file "//.vmware/preferences": No such file or directory.
2018-09-25T09:03:21.313Z| vmx| I125: lib/ssl: OpenSSL using FIPS_drbg for RAND
2018-09-25T09:03:21.313Z| vmx| I125: lib/ssl: protocol list tls1.2
2018-09-25T09:03:21.313Z| vmx| I125: lib/ssl: protocol list tls1.2 (openssl flags 0x17000000)
2018-09-25T09:03:21.313Z| vmx| I125: lib/ssl: cipher list !aNULL:kECDH+AESGCM:ECDH+AESGCM:RSA+AESGCM:kECDH+AES:ECDH+AES:RSA+AES
2018-09-25T09:03:21.314Z| vmx| I125: Hostname=localhost.lazea
2018-09-25T09:03:21.314Z| vmx| I125: IP=127.0.0.1 (lo0)
2018-09-25T09:03:21.314Z| vmx| I125: IP=172.16.12.81 (vmk0)
2018-09-25T09:03:21.314Z| vmx| I125: vmkernel build type: release
2018-09-25T09:03:21.314Z| vmx| I125: System uptime 78511684230 us
2018-09-25T09:03:21.314Z| vmx| I125: Command line: "/bin/vmx" "-s" "sched.group=host/user" "-#" "product=2;name=VMware ESX;version=6.5.0;buildnumber=8294253;licensename=VMware ESX Server;licenseversion=6.0;" "-@" "transport=3;msgs=ui" "/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01.vmx"
2018-09-25T09:03:21.315Z| vmx| I125: Environment: "USER=root" "HOME=/" "SHELL=/bin/sh" "LANG=C"
2018-09-25T09:03:21.315Z| vmx| I125: Msg_SetLocaleEx: HostLocale=UTF-8 UserLocale=NULL
2018-09-25T09:03:21.315Z| vmx| I125: Transport socket: 3
2018-09-25T09:03:21.315Z| vmx| I125: VigorTransport listening on fd 7
2018-09-25T09:03:21.315Z| vmx| I125: Vigor_Init 0
2018-09-25T09:03:21.315Z| vmx| I125: /vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01.vmx: Setup symlink /var/run/vmware/e9dd2cbffc40fc72029739f3e5b35c51 -> /var/run/vmware/0/78511684418_78552
2018-09-25T09:03:21.315Z| vmx| I125: Vix: [78552 mainDispatch.c:490]: VMAutomation: Initializing VMAutomation.
2018-09-25T09:03:21.315Z| vmx| I125: Vix: [78552 mainDispatch.c:746]: VMAutomationOpenListenerSocket() listening
2018-09-25T09:03:21.319Z| vmx| I125: Vix: [78552 mainDispatch.c:4234]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1870, success=1 additionalError=0
2018-09-25T09:03:21.319Z| vmx| I125: Transitioned vmx/execState/val to poweredOff
2018-09-25T09:03:21.319Z| vmx| I125: Vix: [78552 mainDispatch.c:4234]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2018-09-25T09:03:21.319Z| vmx| I125: Vix: [78552 mainDispatch.c:4234]: VMAutomation_ReportPowerOpFinished: statevar=2, newAppState=1877, success=1 additionalError=0
2018-09-25T09:03:21.319Z| vmx| I125: Vix: [78552 mainDispatch.c:4234]: VMAutomation_ReportPowerOpFinished: statevar=3, newAppState=1881, success=1 additionalError=0
2018-09-25T09:03:21.320Z| vmx| I125: FeatureCompat: No EVC masks.
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID vendor: GenuineIntel
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID family: 0x6 model: 0x1e stepping: 0x5
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID codename: Clarksfield/Lynnfield (Core i5)
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID name: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000000, 0: 0x0000000b 0x756e6547 0x6c65746e 0x49656e69
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000001, 0: 0x000106e5 0x00100800 0x0098e3fd 0xbfebfbff
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000002, 0: 0x55035a01 0x00f0b2e4 0x00000000 0x09ca212c
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000003, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000004, 0: 0x1c004121 0x01c0003f 0x0000003f 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000004, 1: 0x1c004122 0x00c0003f 0x0000007f 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000004, 2: 0x1c004143 0x01c0003f 0x000001ff 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000004, 3: 0x1c03c163 0x03c0003f 0x00001fff 0x00000002
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000004, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000005, 0: 0x00000040 0x00000040 0x00000003 0x00001120
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000006, 0: 0x00000003 0x00000002 0x00000001 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000007, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000008, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 00000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 0000000a, 0: 0x07300403 0x00000044 0x00000000 0x00000603
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 80000000, 0: 0x80000008 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 80000001, 0: 0x00000000 0x00000000 0x00000001 0x28100800
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 80000002, 0: 0x65746e49 0x2952286c 0x726f4320 0x4d542865
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 80000003, 0: 0x37692029 0x55504320 0x20202020 0x20202020
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 80000004, 0: 0x30363820 0x20402020 0x30382e32 0x007a4847
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 80000005, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 80000006, 0: 0x00000000 0x00000000 0x01006040 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 80000007, 0: 0x00000000 0x00000000 0x00000000 0x00000100
2018-09-25T09:03:21.320Z| vmx| I125: hostCPUID level 80000008, 0: 0x00003024 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.320Z| vmx| I125: CPUID differences from hostCPUID.
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[1] level 00000001, 0: 0x000106e5 0x01100800 0x0098e3fd 0xbfebfbff
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[1] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000001
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[1] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000001
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[1] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000001
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[2] level 00000001, 0: 0x000106e5 0x02100800 0x0098e3fd 0xbfebfbff
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[2] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000002
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[2] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000002
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[2] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000002
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[3] level 00000001, 0: 0x000106e5 0x03100800 0x0098e3fd 0xbfebfbff
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[3] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000003
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[3] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000003
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[3] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000003
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[4] level 00000001, 0: 0x000106e5 0x04100800 0x0098e3fd 0xbfebfbff
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[4] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000004
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[4] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000004
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[4] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000004
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[5] level 00000001, 0: 0x000106e5 0x05100800 0x0098e3fd 0xbfebfbff
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[5] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000005
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[5] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000005
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[5] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000005
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[6] level 00000001, 0: 0x000106e5 0x06100800 0x0098e3fd 0xbfebfbff
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[6] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000006
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[6] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000006
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[6] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000006
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[7] level 00000001, 0: 0x000106e5 0x07100800 0x0098e3fd 0xbfebfbff
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[7] level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000007
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[7] level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000007
2018-09-25T09:03:21.320Z| vmx| I125: CPUID[7] level 0000000b, 2: 0x00000000 0x00000000 0x00000002 0x00000007
2018-09-25T09:03:21.320Z| vmx| I125: CPUID Maximum Physical Address Bits supported across all CPUs: 36
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x3a = 0x1
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x480 = 0xda04000000000e
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x481 = 0x7f00000016
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x482 = 0xfff9fffe0401e172
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x483 = 0x7fffff00036dff
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x484 = 0xffff000011ff
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x485 = 0x401c5
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x486 = 0x80000021
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x487 = 0xffffffff
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x488 = 0x2000
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x489 = 0x67ff
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x48a = 0x2a
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x48b = 0x7f00000000
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x48c = 0xf0106114141
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x48d = 0x7f00000016
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x48e = 0xfff9fffe04006172
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x48f = 0x7fffff00036dfb
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x490 = 0xffff000011fb
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0x491 = 0
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0xc0010114 = 0
2018-09-25T09:03:21.320Z| vmx| I125: Common: MSR 0xce = 0x90040031500
2018-09-25T09:03:21.321Z| vmx| I125: UTIL: Change file descriptor limit from soft 3088,hard 3088 to soft 4096,hard 4096.
2018-09-25T09:03:21.321Z| vmx| I125: PTSC: using TSC + offset (-100294104026)
2018-09-25T09:03:21.321Z| vmx| I125: PTSC: hardware TSCs are synchronized.
2018-09-25T09:03:21.321Z| vmx| I125: PTSC: current PTSC=219840523425583
2018-09-25T09:03:21.321Z| vmx| I125: MKSXlib: Initialized thread-safe Xlib
2018-09-25T09:03:21.321Z| vmx| I125: [0xDDF3CA000-0xDE0493F4C): /bin/vmx
2018-09-25T09:03:21.328Z| vmx| I125: changing directory to /vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/.
2018-09-25T09:03:21.329Z| vmx| I125: Config file: /vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01.vmx
2018-09-25T09:03:21.329Z| vmx| I125: Vix: [78552 mainDispatch.c:4234]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2018-09-25T09:03:21.329Z| vmx| I125: Vix: [78552 mainDispatch.c:4234]: VMAutomation_ReportPowerOpFinished: statevar=2, newAppState=1878, success=1 additionalError=0
2018-09-25T09:03:21.335Z| vmx| I125: Vigor_ClientRequestCb: failed to do op=3 on unregistered device 'Tools' (cmd=queryFields)
2018-09-25T09:03:21.335Z| vmx| I125: Vigor_ClientRequestCb: failed to do op=3 on unregistered device 'GuestInfo' (cmd=queryFields)
2018-09-25T09:03:21.335Z| vmx| I125: Vigor_ClientRequestCb: failed to do op=3 on unregistered device 'GuestPeriodic' (cmd=queryFields)
2018-09-25T09:03:21.335Z| vmx| I125: Vigor_ClientRequestCb: failed to do op=3 on unregistered device 'GuestAppMonitor' (cmd=queryFields)
2018-09-25T09:03:21.335Z| vmx| I125: Vigor_ClientRequestCb: failed to do op=3 on unregistered device 'CrashDetector' (cmd=queryFields)
2018-09-25T09:03:21.336Z| vmx| I125: Vigor_ClientRequestCb: failed to do op=3 on unregistered device 'Tools' (cmd=queryFields)
2018-09-25T09:03:21.336Z| vmx| I125: Vigor_ClientRequestCb: failed to do op=3 on unregistered device 'GuestInfo' (cmd=queryFields)
2018-09-25T09:03:21.336Z| vmx| I125: Vigor_ClientRequestCb: failed to do op=3 on unregistered device 'GuestPeriodic' (cmd=queryFields)
2018-09-25T09:03:21.336Z| vmx| I125: Vigor_ClientRequestCb: failed to do op=3 on unregistered device 'GuestAppMonitor' (cmd=queryFields)
2018-09-25T09:03:21.336Z| vmx| I125: Vigor_ClientRequestCb: failed to do op=3 on unregistered device 'CrashDetector' (cmd=queryFields)
2018-09-25T09:03:21.350Z| vmx| W115: PowerOn
2018-09-25T09:03:21.350Z| vmx| I125: Vix: [78552 mainDispatch.c:4234]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1871, success=1 additionalError=0
2018-09-25T09:03:21.350Z| vmx| I125: UNAME VMkernel localhost.lazea 6.5.0 #1 SMP Release build-8294253 Apr 17 2018 19:05:39 x86_64 (uwglibc release: vmware, version: 2.12.2)
2018-09-25T09:03:21.350Z| vmx| I125: DICT --- GLOBAL SETTINGS /usr/lib/vmware/settings
2018-09-25T09:03:21.350Z| vmx| I125: DICT --- NON PERSISTENT (null)
2018-09-25T09:03:21.350Z| vmx| I125: DICT --- USER PREFERENCES //.vmware/preferences
2018-09-25T09:03:21.350Z| vmx| I125: DICT --- USER DEFAULTS //.vmware/config
2018-09-25T09:03:21.350Z| vmx| I125: DICT --- HOST DEFAULTS /etc/vmware/config
2018-09-25T09:03:21.350Z| vmx| I125: DICT libdir = "/usr/lib/vmware"
2018-09-25T09:03:21.350Z| vmx| I125: DICT authd.proxy.nfc = "vmware-hostd:ha-nfc"
2018-09-25T09:03:21.350Z| vmx| I125: DICT authd.proxy.nfcssl = "vmware-hostd:ha-nfcssl"
2018-09-25T09:03:21.350Z| vmx| I125: DICT authd.proxy.vpxa-nfcssl = "vmware-vpxa:vpxa-nfcssl"
2018-09-25T09:03:21.350Z| vmx| I125: DICT authd.proxy.vpxa-nfc = "vmware-vpxa:vpxa-nfc"
2018-09-25T09:03:21.350Z| vmx| I125: DICT authd.fullpath = "/sbin/authd"
2018-09-25T09:03:21.350Z| vmx| I125: DICT --- SITE DEFAULTS /usr/lib/vmware/config
2018-09-25T09:03:21.350Z| vmx| I125: DICT --- NONPERSISTENT
2018-09-25T09:03:21.350Z| vmx| I125: DICT sched.group = "host/user"
2018-09-25T09:03:21.350Z| vmx| I125: DICT --- COMMAND LINE
2018-09-25T09:03:21.350Z| vmx| I125: DICT --- RECORDING
2018-09-25T09:03:21.350Z| vmx| I125: DICT --- CONFIGURATION /vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01.vmx
2018-09-25T09:03:21.350Z| vmx| I125: DICT config.version = "8"
2018-09-25T09:03:21.350Z| vmx| I125: DICT virtualHW.version = "13"
2018-09-25T09:03:21.350Z| vmx| I125: DICT vmci0.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT floppy0.present = "FALSE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT numvcpus = "4"
2018-09-25T09:03:21.350Z| vmx| I125: DICT memSize = "2048"
2018-09-25T09:03:21.350Z| vmx| I125: DICT bios.bootRetry.delay = "10"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sched.cpu.units = "mhz"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sched.cpu.affinity = "all"
2018-09-25T09:03:21.350Z| vmx| I125: DICT powerType.suspend = "soft"
2018-09-25T09:03:21.350Z| vmx| I125: DICT tools.upgrade.policy = "manual"
2018-09-25T09:03:21.350Z| vmx| I125: DICT scsi0.virtualDev = "lsisas1068"
2018-09-25T09:03:21.350Z| vmx| I125: DICT scsi0.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sata0.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT usb.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT ehci.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT scsi0:0.deviceType = "scsi-hardDisk"
2018-09-25T09:03:21.350Z| vmx| I125: DICT scsi0:0.fileName = "Render01.vmdk"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sched.scsi0:0.shares = "normal"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sched.scsi0:0.throughputCap = "off"
2018-09-25T09:03:21.350Z| vmx| I125: DICT scsi0:0.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT ethernet0.virtualDev = "e1000"
2018-09-25T09:03:21.350Z| vmx| I125: DICT ethernet0.networkName = "VM Network"
2018-09-25T09:03:21.350Z| vmx| I125: DICT ethernet0.addressType = "generated"
2018-09-25T09:03:21.350Z| vmx| I125: DICT ethernet0.wakeOnPcktRcv = "FALSE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT ethernet0.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sata0:0.deviceType = "atapi-cdrom"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sata0:0.fileName = "/vmfs/devices/cdrom/mpx.vmhba64:C0:T0:L0"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sata0:0.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT displayName = "Render01"
2018-09-25T09:03:21.350Z| vmx| I125: DICT guestOS = "windows7-64"
2018-09-25T09:03:21.350Z| vmx| I125: DICT toolScripts.afterPowerOn = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT toolScripts.afterResume = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT toolScripts.beforeSuspend = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT toolScripts.beforePowerOff = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT tools.syncTime = "FALSE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT uuid.bios = "56 4d a9 45 c5 f5 7e 85-15 22 09 9e 9c d8 4f 5e"
2018-09-25T09:03:21.350Z| vmx| I125: DICT uuid.location = "56 4d a9 45 c5 f5 7e 85-15 22 09 9e 9c d8 4f 5e"
2018-09-25T09:03:21.350Z| vmx| I125: DICT vc.uuid = "52 48 b8 21 92 47 e0 58-c0 71 f8 ec 18 4e 94 c4"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sched.cpu.min = "0"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sched.cpu.shares = "normal"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sched.mem.min = "0"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sched.mem.minSize = "0"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sched.mem.shares = "normal"
2018-09-25T09:03:21.350Z| vmx| I125: DICT numa.autosize.vcpu.maxPerVirtualNode = "4"
2018-09-25T09:03:21.350Z| vmx| I125: DICT numa.autosize.cookie = "40001"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sched.swap.derivedName = "/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01-4d92e6ca.vswp"
2018-09-25T09:03:21.350Z| vmx| I125: DICT scsi0:0.redo = ""
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge0.pciSlotNumber = "17"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge4.pciSlotNumber = "21"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge5.pciSlotNumber = "22"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge6.pciSlotNumber = "23"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge7.pciSlotNumber = "24"
2018-09-25T09:03:21.350Z| vmx| I125: DICT scsi0.pciSlotNumber = "160"
2018-09-25T09:03:21.350Z| vmx| I125: DICT usb.pciSlotNumber = "32"
2018-09-25T09:03:21.350Z| vmx| I125: DICT ethernet0.pciSlotNumber = "33"
2018-09-25T09:03:21.350Z| vmx| I125: DICT ehci.pciSlotNumber = "34"
2018-09-25T09:03:21.350Z| vmx| I125: DICT vmci0.pciSlotNumber = "35"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sata0.pciSlotNumber = "36"
2018-09-25T09:03:21.350Z| vmx| I125: DICT scsi0.sasWWID = "50 05 05 65 c5 f5 7e 80"
2018-09-25T09:03:21.350Z| vmx| I125: DICT ethernet0.generatedAddress = "00:0c:29:d8:4f:5e"
2018-09-25T09:03:21.350Z| vmx| I125: DICT ethernet0.generatedAddressOffset = "0"
2018-09-25T09:03:21.350Z| vmx| I125: DICT vmci0.id = "-1663545506"
2018-09-25T09:03:21.350Z| vmx| I125: DICT monitor.phys_bits_used = "43"
2018-09-25T09:03:21.350Z| vmx| I125: DICT bios.forceSetupOnce = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT tools.guest.desktop.autolock = "FALSE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT nvram = "Render01.nvram"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge0.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT svga.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge4.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge4.virtualDev = "pcieRootPort"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge4.functions = "8"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge5.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge5.virtualDev = "pcieRootPort"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge5.functions = "8"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge6.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge6.virtualDev = "pcieRootPort"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge6.functions = "8"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge7.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge7.virtualDev = "pcieRootPort"
2018-09-25T09:03:21.350Z| vmx| I125: DICT pciBridge7.functions = "8"
2018-09-25T09:03:21.350Z| vmx| I125: DICT hpet0.present = "TRUE"
2018-09-25T09:03:21.350Z| vmx| I125: DICT RemoteDisplay.maxConnections = "-1"
2018-09-25T09:03:21.350Z| vmx| I125: DICT sched.cpu.latencySensitivity = "normal"
2018-09-25T09:03:21.350Z| vmx| I125: DICT migrate.hostlog = "./Render01-4d92e6ca.hlog"
2018-09-25T09:03:21.350Z| vmx| I125: DICT --- USER DEFAULTS ~/.vmware/config
2018-09-25T09:03:21.361Z| vmx| I125: ToolsISO: Selected Tools ISO 'windows.iso' for 'windows7-64' guest.
2018-09-25T09:03:21.361Z| vmx| I125: Vix: [78552 mainDispatch.c:4234]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2018-09-25T09:03:21.366Z| vmx| I125: Host VT-x Capabilities:
2018-09-25T09:03:21.366Z| vmx| I125: Basic VMX Information (0x00da04000000000e)
2018-09-25T09:03:21.366Z| vmx| I125: VMCS revision ID 14
2018-09-25T09:03:21.366Z| vmx| I125: VMCS region length 1024
2018-09-25T09:03:21.366Z| vmx| I125: VMX physical-address width natural
2018-09-25T09:03:21.366Z| vmx| I125: SMM dual-monitor mode yes
2018-09-25T09:03:21.366Z| vmx| I125: Advanced INS/OUTS info yes
2018-09-25T09:03:21.366Z| vmx| I125: True VMX MSRs yes
2018-09-25T09:03:21.366Z| vmx| I125: VMCS memory type WB
2018-09-25T09:03:21.366Z| vmx| I125: True Pin-Based VM-Execution Controls (0x0000007f00000016)
2018-09-25T09:03:21.366Z| vmx| I125: External-interrupt exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: NMI exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Virtual NMIs {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Activate VMX-preemption timer {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Process posted interrupts { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: True Primary Processor-Based VM-Execution Controls (0xfff9fffe04006172)
2018-09-25T09:03:21.366Z| vmx| I125: Interrupt-window exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Use TSC offsetting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: HLT exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: INVLPG exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: MWAIT exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: RDPMC exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: RDTSC exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: CR3-load exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: CR3-store exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: CR8-load exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: CR8-store exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Use TPR shadow {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: NMI-window exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: MOV-DR exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Unconditional I/O exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Use I/O bitmaps {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Monitor trap flag {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Use MSR bitmaps {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: MONITOR exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: PAUSE exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Activate secondary controls {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Secondary Processor-Based VM-Execution Controls (0x0000007f00000000)
2018-09-25T09:03:21.366Z| vmx| I125: Virtualize APIC accesses {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Enable EPT {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Descriptor-table exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Enable RDTSCP {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Virtualize x2APIC mode {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Enable VPID {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: WBINVD exiting {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Unrestricted guest { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: APIC-register virtualization { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: Virtual-interrupt delivery { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: PAUSE-loop exiting { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: RDRAND exiting { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: Enable INVPCID { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: Enable VM Functions { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: Use VMCS shadowing { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: Enable ENCLS/ENCLU { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: RDSEED exiting { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: Enable PML { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: EPT-violation #VE { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: Enable XSAVES/XRSTORS { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: Use TSC scaling { 0 }
2018-09-25T09:03:21.366Z| vmx| I125: True VM-Exit Controls (0x007fffff00036dfb)
2018-09-25T09:03:21.366Z| vmx| I125: Save debug controls {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Host address-space size {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Load IA32_PERF_GLOBAL_CTRL {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Acknowledge interrupt on exit {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Save IA32_PAT {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Load IA32_PAT {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Save IA32_EFER {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Load IA32_EFER {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Save VMX-preemption timer {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: True VM-Entry Controls (0x0000ffff000011fb)
2018-09-25T09:03:21.366Z| vmx| I125: Load debug controls {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: IA-32e mode guest {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Entry to SMM {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: Deactivate dual-monitor mode {0,1}
2018-09-25T09:03:21.366Z| vmx| I125: VPID and EPT Capabilities (0x00000f0106114141)
2018-09-25T09:03:21.366Z| vmx| I125: R=0/W=0/X=1 yes
2018-09-25T09:03:21.366Z| vmx| I125: Page-walk length 3 yes
2018-09-25T09:03:21.366Z| vmx| I125: EPT memory type WB yes
2018-09-25T09:03:21.366Z| vmx| I125: 2MB super-page yes
2018-09-25T09:03:21.366Z| vmx| I125: 1GB super-page no
2018-09-25T09:03:21.366Z| vmx| I125: INVEPT support yes
2018-09-25T09:03:21.366Z| vmx| I125: Access & Dirty Bits no
2018-09-25T09:03:21.366Z| vmx| I125: Type 1 INVEPT yes
2018-09-25T09:03:21.366Z| vmx| I125: Type 2 INVEPT yes
2018-09-25T09:03:21.366Z| vmx| I125: INVVPID support yes
2018-09-25T09:03:21.366Z| vmx| I125: Type 0 INVVPID yes
2018-09-25T09:03:21.366Z| vmx| I125: Type 1 INVVPID yes
2018-09-25T09:03:21.366Z| vmx| I125: Type 2 INVVPID yes
2018-09-25T09:03:21.366Z| vmx| I125: Type 3 INVVPID yes
2018-09-25T09:03:21.366Z| vmx| I125: Miscellaneous VMX Data (0x00000000000401c5)
2018-09-25T09:03:21.366Z| vmx| I125: TSC to preemption timer ratio 5
2018-09-25T09:03:21.366Z| vmx| I125: VM-Exit saves EFER.LMA no
2018-09-25T09:03:21.366Z| vmx| I125: Activity State HLT yes
2018-09-25T09:03:21.366Z| vmx| I125: Activity State shutdown yes
2018-09-25T09:03:21.366Z| vmx| I125: Activity State wait-for-SIPI yes
2018-09-25T09:03:21.366Z| vmx| I125: CR3 targets supported 4
2018-09-25T09:03:21.366Z| vmx| I125: Maximum MSR list size 512
2018-09-25T09:03:21.366Z| vmx| I125: Allow all VMWRITEs no
2018-09-25T09:03:21.366Z| vmx| I125: Allow zero instruction length no
2018-09-25T09:03:21.366Z| vmx| I125: MSEG revision ID 0
2018-09-25T09:03:21.366Z| vmx| I125: VMX-Fixed Bits in CR0 (0x0000000080000021/0x00000000ffffffff)
2018-09-25T09:03:21.366Z| vmx| I125: Fixed to 0 0xffffffff00000000
2018-09-25T09:03:21.366Z| vmx| I125: Fixed to 1 0x0000000080000021
2018-09-25T09:03:21.366Z| vmx| I125: Variable 0x000000007fffffde
2018-09-25T09:03:21.366Z| vmx| I125: VMX-Fixed Bits in CR4 (0x0000000000002000/0x00000000000067ff)
2018-09-25T09:03:21.366Z| vmx| I125: Fixed to 0 0xffffffffffff9800
2018-09-25T09:03:21.366Z| vmx| I125: Fixed to 1 0x0000000000002000
2018-09-25T09:03:21.366Z| vmx| I125: Variable 0x00000000000047ff
2018-09-25T09:03:21.366Z| vmx| I125: VMCS Enumeration (0x000000000000002a)
2018-09-25T09:03:21.366Z| vmx| I125: Highest index 0x15
2018-09-25T09:03:21.366Z| vmx| I125: VM Functions (0x0000000000000000)
2018-09-25T09:03:21.366Z| vmx| I125: The following VT-x features are required for VT-x support in VMware ESX; however, these features are not available on this host:
2018-09-25T09:03:21.366Z| vmx| I125: hostCpuFeatures = 0x1bd
2018-09-25T09:03:21.366Z| vmx| I125: hostNumGenPerfCounters = 4
2018-09-25T09:03:21.366Z| vmx| I125: hostNumFixedPerfCounters = 3
2018-09-25T09:03:21.366Z| vmx| I125: hostPerfCtrArch = 3
2018-09-25T09:03:21.367Z| vmx| I125: MONITOR MODE: allowed modes : BT
2018-09-25T09:03:21.367Z| vmx| I125: MONITOR MODE: user requested modes : BT HV HWMMU
2018-09-25T09:03:21.367Z| vmx| I125: MONITOR MODE: guestOS preferred modes: HWMMU HV BT
2018-09-25T09:03:21.367Z| vmx| I125: MONITOR MODE: filtered list : BT
2018-09-25T09:03:21.367Z| vmx| I125: MsgHint: msg.monitor.BTnoLM2
2018-09-25T09:03:21.367Z| vmx| I125+ Binary translation is incompatible with long mode on this platform. Long mode will be disabled in this virtual environment and applications requiring long mode will not function properly as a result. See http://vmware.com/info?id=152 for more details.
2018-09-25T09:03:21.367Z| vmx| I125+ ---------------------------------------
2018-09-25T09:03:21.367Z| vmx| I125: HV Settings: virtual exec = 'software'; virtual mmu = 'software'
2018-09-25T09:03:21.374Z| vmx| I125: DISKLIB-VMFS : "/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01-flat.vmdk" : open successful (524309) size = 214748364800, hd = 0. Type 3
2018-09-25T09:03:21.374Z| vmx| I125: DISKLIB-VMFS : "/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01-flat.vmdk" : closed.
2018-09-25T09:03:21.375Z| vmx| I125: OvhdMem_PowerOn: initial admission: paged 54933 nonpaged 3794 anonymous 26386
2018-09-25T09:03:21.375Z| vmx| I125: VMMEM: Initial Reservation: 332MB (MainMem=2048MB)
2018-09-25T09:03:21.375Z| vmx| I125: MemSched_PowerOn: balloon minGuestSize 209715 (80% of min required size 262144)
2018-09-25T09:03:21.375Z| vmx| I125: VMMonParseSchedConfig: Initial Vmx Memory Configuration
2018-09-25T09:03:21.375Z| vmx| I125: MemSched (MB): min: 14 sizeLimit: 1024 swapInitialFileSize: 110 prealloc: FALSE.
2018-09-25T09:03:21.375Z| vmx| I125: MemSched: properties ovhd: 0 guestmem: 0 pinned: 0 fpt: 0 ftCpt: 0 ls: -3 prealloc: 0
2018-09-25T09:03:21.375Z| vmx| I125: numaHost: NUMA config: consolidation= 1 preferHT= 0
2018-09-25T09:03:21.375Z| vmx| I125: numaHost: 4 VCPUs 1 VPDs 1 PPDs
2018-09-25T09:03:21.375Z| vmx| I125: numaHost: VCPU 0 VPD 0 PPD 0
2018-09-25T09:03:21.375Z| vmx| I125: numaHost: VCPU 1 VPD 0 PPD 0
2018-09-25T09:03:21.375Z| vmx| I125: numaHost: VCPU 2 VPD 0 PPD 0
2018-09-25T09:03:21.375Z| vmx| I125: numaHost: VCPU 3 VPD 0 PPD 0
2018-09-25T09:03:21.375Z| vmx| I125: CreateVM: Swap: generating normal swap file name.
2018-09-25T09:03:21.375Z| vmx| I125: FTCpt: (0 unk) vmk overheads: 0 pages (0 MB)
2018-09-25T09:03:21.375Z| vmx| I125: Swap file path: '/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01-4d92e6ca.vswp'
2018-09-25T09:03:21.375Z| vmx| I125: Disk_GetDigestDiskCount: numDigestDisks = 0
2018-09-25T09:03:21.402Z| vmx| A100: ConfigDB: Setting sched.swap.derivedName = "/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01-4d92e6ca.vswp"
2018-09-25T09:03:21.402Z| vthread-8| I125: VTHREAD start thread 8 "vthread-8" tid 78559
2018-09-25T09:03:21.402Z| vmx| I125: WORKER: setting thread limit to 16 (was 4)
2018-09-25T09:03:21.402Z| vmx| W115: VProbes facility is disabled.
2018-09-25T09:03:21.410Z| vmx| I125: ToolsISO: Selected Tools ISO 'windows.iso' for 'windows7-64' guest.
2018-09-25T09:03:21.413Z| vmx| I125: Monitor64_PowerOn()
2018-09-25T09:03:21.413Z| vmx| I125: vmm64-modules: [vmm.vmm64, mmu-nohv.vmm64, vprobe-none.vmm64, hv-none.vmm64, gphys-sw.vmm64, callstack-none.vmm64, vmce-vmce.vmm64, vvtd-none.vmm64, gi-none.vmm64, videio-none.vmm64, ahci-ahci.vmm64, {SharedAreaReservations} .shared_per_vm_vmx:0x3d40, {SharedInterVcpuVmxSection}, {SharedInterVcpuSection}, <MonSrcFile>, e1000Shared=0xfffffffffc0ce480, ahciShared=0xfffffffffc0cc000, ahciRegs=0xfffffffffc0cb000, {UseUnwind}=0x0, hvLoadedAsAddr=0x0, useNPTAsAddr=0x0, numVCPUsAsAddr=0x4, busmemFrameSizeLog2AsAddr=0x4, busmemFrameSizeAsAddr=0x10, {rodataSize}=0x21890, {textAddr}=0xfffffffffc400000, {textSize}=0x9e165]
2018-09-25T09:03:21.413Z| vmx| I125: vmm64-vcpus: 4
2018-09-25T09:03:21.421Z| vmx| I125: KHZEstimate 2800099
2018-09-25T09:03:21.421Z| vmx| I125: MHZEstimate 2800
2018-09-25T09:03:21.421Z| vmx| I125: NumVCPUs 4
2018-09-25T09:03:21.421Z| vmx| I125: Guest OS (20497) not supported for replay debugging.
2018-09-25T09:03:21.421Z| vmx| I125: UUID: location-UUID is 56 4d a9 45 c5 f5 7e 85-15 22 09 9e 9c d8 4f 5e
2018-09-25T09:03:21.422Z| vmx| I125: AIOGNRC: numThreads=1 ide=0, scsi=0, passthru=0
2018-09-25T09:03:21.422Z| vmx| I125: WORKER: Creating new group with numThreads=1 (1)
2018-09-25T09:03:21.422Z| vmx| I125: WORKER: Creating new group with numThreads=2 (3)
2018-09-25T09:03:21.422Z| vmx| I125: WORKER: Creating new group with numThreads=1 (4)
2018-09-25T09:03:21.422Z| vmx| I125: MainMem: CPT PLS=1 PLR=0 BS=0 BlkP=64 Mult=2 W=25
2018-09-25T09:03:21.422Z| vmx| I125: MStat: Creating Stat vm.uptime
2018-09-25T09:03:21.422Z| vmx| I125: MStat: Creating Stat vm.suspendTime
2018-09-25T09:03:21.422Z| vmx| I125: MStat: Creating Stat vm.powerOnTimeStamp
2018-09-25T09:03:21.422Z| vmx| I125: VMXAIOMGR: Using: simple=Generic unbuf=Generic
2018-09-25T09:03:21.423Z| vmx| I125: WORKER: Creating new group with numThreads=1 (5)
2018-09-25T09:03:21.423Z| vmx| I125: FTCpt: (0 unk) State transition FTCPT_UNSET -> FTCPT_NOT_CONFIGURED (0:1)
2018-09-25T09:03:21.424Z| vmx| I125: WORKER: Creating new group with numThreads=4 (9)
2018-09-25T09:03:21.424Z| vmx| I125: WORKER: Creating new group with numThreads=1 (10)
2018-09-25T09:03:21.424Z| vmx| I125: MigrateBusMemPrealloc: BusMem preallocation begins.
2018-09-25T09:03:21.425Z| vmx| I125: MigrateBusMemPrealloc: BusMem preallocation completes.
2018-09-25T09:03:21.425Z| vmx| I125: TimeTracker host to guest rate conversion 219840816134611 @ 2800099000Hz -> 0 @ 2800099000Hz
2018-09-25T09:03:21.425Z| vmx| I125: TimeTracker host to guest rate conversion ((x * 2147483648) >> 31) + -219840816134611
2018-09-25T09:03:21.425Z| vmx| I125: Disabling TSC scaling since host does not support it.
2018-09-25T09:03:21.425Z| vmx| I125: TSC offsetting enabled.
2018-09-25T09:03:21.425Z| vmx| I125: timeTracker.globalProgressMaxAllowanceMS: 2000
2018-09-25T09:03:21.425Z| vmx| I125: timeTracker.globalProgressToAllowanceNS: 1000
2018-09-25T09:03:21.425Z| vmx| A100: ConfigDB: Setting scsi0:0.redo = ""
2018-09-25T09:03:21.425Z| vmx| I125: DISK: OPEN scsi0:0 '/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01.vmdk' persistent R[]
2018-09-25T09:03:21.426Z| vmx| I125: DISKLIB-VMFS : "/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01-flat.vmdk" : open successful (10) size = 214748364800, hd = 72696. Type 3
2018-09-25T09:03:21.426Z| vmx| I125: DISKLIB-DSCPTR: Opened [0]: "Render01-flat.vmdk" (0xa)
2018-09-25T09:03:21.426Z| vmx| I125: DISKLIB-LINK : Opened '/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01.vmdk' (0xa): vmfs, 419430400 sectors / 200 GB.
2018-09-25T09:03:21.426Z| vmx| I125: DISKLIB-LIB : Opened "/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01.vmdk" (flags 0xa, type vmfs).
2018-09-25T09:03:21.426Z| vmx| I125: DISK: Disk '/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01.vmdk' has UUID '60 00 c2 9a ea b8 91 8d-2b c9 d8 3d 25 d9 62 cf'
2018-09-25T09:03:21.426Z| vmx| I125: DISK: OPEN '/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01.vmdk' Geo (26108/255/63) BIOS Geo (0/0/0)
2018-09-25T09:03:21.427Z| vmx| I125: DISK: DiskConfigureVirtualSSD: Disk 'scsi0:0' identified as Virtual SSD device.
2018-09-25T09:03:21.427Z| vmx| I125: UTIL: Change file descriptor limit from soft 4096,hard 4096 to soft 4211,hard 4211.
2018-09-25T09:03:21.427Z| vmx| I125: DISK: Opening disks took 1 ms.
2018-09-25T09:03:21.427Z| vmx| I125: SOCKET creating new socket, connecting to /var/run/vmware/usbarbitrator-socket
2018-09-25T09:03:21.427Z| vmx| I125: USB: Initializing 'Virtual Hub' backend
2018-09-25T09:03:21.427Z| vmx| I125: USB: Initializing 'Generic' backend
2018-09-25T09:03:21.427Z| vmx| I125: USB: Initializing 'Virtual HID' backend
2018-09-25T09:03:21.427Z| vmx| I125: USB: Initializing 'Remote Device' backend
2018-09-25T09:03:21.427Z| vmx| I125: RemoteUSBVMX: Retrieved hostId [38 74 fe 45 b1 f0 de 11-b6 07 00 1c c0 c8 1e 6f]
2018-09-25T09:03:21.427Z| vmx| I125: RemoteUSBVMX: Protocol version min:15 current:16
2018-09-25T09:03:21.427Z| vmx| I125: RemoteUSBVMX: no delay setting is TRUE.
2018-09-25T09:03:21.427Z| vmx| I125: USB: Initializing 'Virtual Mass Storage' backend
2018-09-25T09:03:21.427Z| vmx| I125: USB: Initializing 'Virtual RNG' backend
2018-09-25T09:03:21.429Z| vmx| I125: MKS PowerOn
2018-09-25T09:03:21.430Z| mks| I125: VTHREAD start thread 2 "mks" tid 78560
2018-09-25T09:03:21.430Z| mks| I125: MKS thread is alive
2018-09-25T09:03:21.430Z| mks| W115: ObtainHardwareID unexpected failure: 22.
2018-09-25T09:03:21.430Z| mks| W115: Hostinfo_MachineID ObtainHardwareID failure (Invalid argument); providing default.
2018-09-25T09:03:21.430Z| mks| I125: MKS-RenderMain: RenderMain: PowerOn allowed MKSBasicOps
2018-09-25T09:03:21.430Z| mks| I125: MKS-RenderMain: Starting MKSBasicOps
2018-09-25T09:03:21.430Z| mks| I125: MKS-RemoteMgr: Set default display name: Render01
2018-09-25T09:03:21.430Z| mks| I125: MKS-RemoteMgr: Loading VNC Configuration from VM config file
2018-09-25T09:03:21.431Z| vmx| I125: VLANCE: send cluster threshold is 80, size = 2 recalcInterval is 2 ticks
2018-09-25T09:03:21.431Z| vmx| I125: Chipset version: 0x13
2018-09-25T09:03:21.432Z| vmx| A100: ConfigDB: Setting pciBridge4.pciSlotNumber = "-1"
2018-09-25T09:03:21.432Z| vmx| A100: ConfigDB: Setting pciBridge5.pciSlotNumber = "-1"
2018-09-25T09:03:21.432Z| vmx| A100: ConfigDB: Setting pciBridge6.pciSlotNumber = "-1"
2018-09-25T09:03:21.432Z| vmx| A100: ConfigDB: Setting pciBridge7.pciSlotNumber = "-1"
2018-09-25T09:03:21.432Z| vmx| A100: ConfigDB: Setting pciBridge4.pciSlotNumber = "21"
2018-09-25T09:03:21.432Z| vmx| A100: ConfigDB: Setting pciBridge5.pciSlotNumber = "22"
2018-09-25T09:03:21.432Z| vmx| A100: ConfigDB: Setting pciBridge6.pciSlotNumber = "23"
2018-09-25T09:03:21.432Z| vmx| A100: ConfigDB: Setting pciBridge7.pciSlotNumber = "24"
2018-09-25T09:03:21.435Z| vmx| I125: SCSI: scsi0: reqCallThreshold 0
2018-09-25T09:03:21.435Z| vmx| I125: SCSI: scsi0: intr coalescing: on period=50msec cifTh=4 iopsTh=2000 hlt=0
2018-09-25T09:03:21.435Z| vmx| I125: SCSI0: UNTAGGED commands will be converted to ORDER tags.
2018-09-25T09:03:21.435Z| vmx| I125: SCSI DEVICE (scsi0:0): Computed value of scsi0:0.useBounceBuffers: default
2018-09-25T09:03:21.435Z| vmx| I125: Creating virtual dev for 'scsi0:0'.
2018-09-25T09:03:21.435Z| vmx| I125: DumpDiskInfo: scsi0:0 createType=11, capacity = 419430400, numLinks = 1, allocationType = 1
2018-09-25T09:03:21.435Z| vmx| I125: SCSIDiskESXPopulateVDevDesc: Using FS backend
2018-09-25T09:03:21.435Z| vmx| I125: DISKUTIL: scsi0:0 : geometry=26108/255/63
2018-09-25T09:03:21.435Z| vmx| I125: SCSIFilterESXAttachCBRCInt: CBRC not enabled or opened without filters,skipping CBRC filter attach.
2018-09-25T09:03:21.436Z| vmx| I125: SVGA: Maximum display topology 2560x1600.
2018-09-25T09:03:21.436Z| vmx| I125: SVGA-GFB: Initial gfbSize=8388608
2018-09-25T09:03:21.436Z| vmx| I125: SVGA-GFB: MaxPrimaryMem register = 8388608
2018-09-25T09:03:21.436Z| vmx| I125: SVGA: Number of displays 1
2018-09-25T09:03:21.436Z| vmx| I125: SVGA: Truncated maximum resolution to VRAM size: 8388608 bytes VRAM, 1672x1254 Max Resolution
2018-09-25T09:03:21.436Z| vmx| I125: SVGA: FIFO capabilities 0x0000077f
2018-09-25T09:03:21.436Z| vmx| I125: SVGA: Device capabilities 0x3dff83e2
2018-09-25T09:03:21.436Z| vmx| I125: SVGA3dCaps: host, at power on: 3d disabled
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 0]: 0x00000000 (3D)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 1]: 0x00000000 (MAX_LIGHTS)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 2]: 0x00000000 (MAX_TEXTURES)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 3]: 0x00000000 (MAX_CLIP_PLANES)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 4]: 0x00000000 (VERTEX_SHADER_VERSION)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 5]: 0x00000000 (VERTEX_SHADER)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 6]: 0x00000000 (FRAGMENT_SHADER_VERSION)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 7]: 0x00000000 (FRAGMENT_SHADER)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 8]: 0x00000000 (MAX_RENDER_TARGETS)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 9]: 0x00000000 (S23E8_TEXTURES)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 10]: 0x00000000 (S10E5_TEXTURES)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 11]: 0x00000000 (MAX_FIXED_VERTEXBLEND)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 12]: 0x00000000 (D16_BUFFER_FORMAT)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 13]: 0x00000000 (D24S8_BUFFER_FORMAT)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 14]: 0x00000000 (D24X8_BUFFER_FORMAT)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 15]: 0x00000000 (QUERY_TYPES)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 16]: 0x00000000 (TEXTURE_GRADIENT_SAMPLING)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 17]: 0.000000 (MAX_POINT_SIZE)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 18]: 0x00000000 (MAX_SHADER_TEXTURES)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 19]: 0x00001000 (MAX_TEXTURE_WIDTH)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 20]: 0x00001000 (MAX_TEXTURE_HEIGHT)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 21]: 0x00000000 (MAX_VOLUME_EXTENT)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 22]: 0x00000000 (MAX_TEXTURE_REPEAT)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 23]: 0x00000000 (MAX_TEXTURE_ASPECT_RATIO)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 24]: 0x00000000 (MAX_TEXTURE_ANISOTROPY)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 25]: 0x00000000 (MAX_PRIMITIVE_COUNT)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 26]: 0x00000000 (MAX_VERTEX_INDEX)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 27]: 0x00000000 (MAX_VERTEX_SHADER_INSTRUCTIONS)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 28]: 0x00000000 (MAX_FRAGMENT_SHADER_INSTRUCTIONS)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 29]: 0x00000000 (MAX_VERTEX_SHADER_TEMPS)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 30]: 0x00000000 (MAX_FRAGMENT_SHADER_TEMPS)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 31]: 0x00000000 (TEXTURE_OPS)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 32]: 0x00000000 (SURFACEFMT_X8R8G8B8)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 33]: 0x00000000 (SURFACEFMT_A8R8G8B8)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 34]: 0x00000000 (SURFACEFMT_A2R10G10B10)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 35]: 0x00000000 (SURFACEFMT_X1R5G5B5)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 36]: 0x00000000 (SURFACEFMT_A1R5G5B5)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 37]: 0x00000000 (SURFACEFMT_A4R4G4B4)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 38]: 0x00000000 (SURFACEFMT_R5G6B5)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 39]: 0x00000000 (SURFACEFMT_LUMINANCE16)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 40]: 0x00000000 (SURFACEFMT_LUMINANCE8_ALPHA8)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 41]: 0x00000000 (SURFACEFMT_ALPHA8)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 42]: 0x00000000 (SURFACEFMT_LUMINANCE8)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 43]: 0x00000000 (SURFACEFMT_Z_D16)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 44]: 0x00000000 (SURFACEFMT_Z_D24S8)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 45]: 0x00000000 (SURFACEFMT_Z_D24X8)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 46]: 0x00000000 (SURFACEFMT_DXT1)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 47]: 0x00000000 (SURFACEFMT_DXT2)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 48]: 0x00000000 (SURFACEFMT_DXT3)
2018-09-25T09:03:21.436Z| vmx| I125: cap[ 49]: 0x00000000 (SURFACEFMT_DXT4)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 50]: 0x00000000 (SURFACEFMT_DXT5)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 51]: 0x00000000 (SURFACEFMT_BUMPX8L8V8U8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 52]: 0x00000000 (SURFACEFMT_A2W10V10U10)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 53]: 0x00000000 (SURFACEFMT_BUMPU8V8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 54]: 0x00000000 (SURFACEFMT_Q8W8V8U8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 55]: 0x00000000 (SURFACEFMT_CxV8U8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 56]: 0x00000000 (SURFACEFMT_R_S10E5)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 57]: 0x00000000 (SURFACEFMT_R_S23E8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 58]: 0x00000000 (SURFACEFMT_RG_S10E5)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 59]: 0x00000000 (SURFACEFMT_RG_S23E8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 60]: 0x00000000 (SURFACEFMT_ARGB_S10E5)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 61]: 0x00000000 (SURFACEFMT_ARGB_S23E8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 62]: 0x00000000 (MISSING62)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 63]: 0x00000000 (MAX_VERTEX_SHADER_TEXTURES)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 64]: 0x00000000 (MAX_SIMULTANEOUS_RENDER_TARGETS)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 65]: 0x00000000 (SURFACEFMT_V16U16)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 66]: 0x00000000 (SURFACEFMT_G16R16)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 67]: 0x00000000 (SURFACEFMT_A16B16G16R16)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 68]: 0x00000000 (SURFACEFMT_UYVY)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 69]: 0x00000000 (SURFACEFMT_YUY2)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 70]: 0x00000000 (MULTISAMPLE_NONMASKABLESAMPLES)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 71]: 0x00000000 (MULTISAMPLE_MASKABLESAMPLES)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 72]: 0x00000000 (ALPHATOCOVERAGE)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 73]: 0x00000000 (SUPERSAMPLE)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 74]: 0x00000000 (AUTOGENMIPMAPS)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 75]: 0x00000000 (SURFACEFMT_NV12)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 76]: 0x00000000 (SURFACEFMT_AYUV)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 77]: 0x00000000 (MAX_CONTEXT_IDS)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 78]: 0x00000000 (MAX_SURFACE_IDS)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 79]: 0x00000000 (SURFACEFMT_Z_DF16)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 80]: 0x00000000 (SURFACEFMT_Z_DF24)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 81]: 0x00000000 (SURFACEFMT_Z_D24S8_INT)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 82]: 0x00000000 (SURFACEFMT_ATI1)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 83]: 0x00000000 (SURFACEFMT_ATI2)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 84]: 0x00000000 (DEAD1)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 85]: 0x00000000 (VIDEO_DECODE)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 86]: 0x00000000 (VIDEO_PROCESS)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 87]: 0x00000000 (LINE_AA)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 88]: 0x00000000 (LINE_STIPPLE)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 89]: 0.000000 (MAX_LINE_WIDTH)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 90]: 0.000000 (MAX_AA_LINE_WIDTH)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 91]: 0x00000000 (SURFACEFMT_YV12)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 92]: 0x00000000 (DEAD3)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 93]: 0x00000001 (TS_COLOR_KEY)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 94]: 0x00000000 (DEAD2)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 95]: 0x00000000 (DXCONTEXT)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 96]: 0x00000000 (MAX_TEXTURE_ARRAY_SIZE)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 97]: 0x00000000 (DX_MAX_VERTEXBUFFERS)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 98]: 0x00000000 (DX_MAX_CONSTANT_BUFFERS)
2018-09-25T09:03:21.437Z| vmx| I125: cap[ 99]: 0x00000000 (DX_PROVOKING_VERTEX)
2018-09-25T09:03:21.437Z| vmx| I125: cap[100]: 0x00000000 (DXFMT_X8R8G8B8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[101]: 0x00000000 (DXFMT_A8R8G8B8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[102]: 0x00000000 (DXFMT_R5G6B5)
2018-09-25T09:03:21.437Z| vmx| I125: cap[103]: 0x00000000 (DXFMT_X1R5G5B5)
2018-09-25T09:03:21.437Z| vmx| I125: cap[104]: 0x00000000 (DXFMT_A1R5G5B5)
2018-09-25T09:03:21.437Z| vmx| I125: cap[105]: 0x00000000 (DXFMT_A4R4G4B4)
2018-09-25T09:03:21.437Z| vmx| I125: cap[106]: 0x00000000 (DXFMT_Z_D32)
2018-09-25T09:03:21.437Z| vmx| I125: cap[107]: 0x00000000 (DXFMT_Z_D16)
2018-09-25T09:03:21.437Z| vmx| I125: cap[108]: 0x00000000 (DXFMT_Z_D24S8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[109]: 0x00000000 (DXFMT_Z_D15S1)
2018-09-25T09:03:21.437Z| vmx| I125: cap[110]: 0x00000000 (DXFMT_LUMINANCE8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[111]: 0x00000000 (DXFMT_LUMINANCE4_ALPHA4)
2018-09-25T09:03:21.437Z| vmx| I125: cap[112]: 0x00000000 (DXFMT_LUMINANCE16)
2018-09-25T09:03:21.437Z| vmx| I125: cap[113]: 0x00000000 (DXFMT_LUMINANCE8_ALPHA8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[114]: 0x00000000 (DXFMT_DXT1)
2018-09-25T09:03:21.437Z| vmx| I125: cap[115]: 0x00000000 (DXFMT_DXT2)
2018-09-25T09:03:21.437Z| vmx| I125: cap[116]: 0x00000000 (DXFMT_DXT3)
2018-09-25T09:03:21.437Z| vmx| I125: cap[117]: 0x00000000 (DXFMT_DXT4)
2018-09-25T09:03:21.437Z| vmx| I125: cap[118]: 0x00000000 (DXFMT_DXT5)
2018-09-25T09:03:21.437Z| vmx| I125: cap[119]: 0x00000000 (DXFMT_BUMPU8V8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[120]: 0x00000000 (DXFMT_BUMPL6V5U5)
2018-09-25T09:03:21.437Z| vmx| I125: cap[121]: 0x00000000 (DXFMT_BUMPX8L8V8U8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[122]: 0x00000000 (DXFMT_FORMAT_DEAD1)
2018-09-25T09:03:21.437Z| vmx| I125: cap[123]: 0x00000000 (DXFMT_ARGB_S10E5)
2018-09-25T09:03:21.437Z| vmx| I125: cap[124]: 0x00000000 (DXFMT_ARGB_S23E8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[125]: 0x00000000 (DXFMT_A2R10G10B10)
2018-09-25T09:03:21.437Z| vmx| I125: cap[126]: 0x00000000 (DXFMT_V8U8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[127]: 0x00000000 (DXFMT_Q8W8V8U8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[128]: 0x00000000 (DXFMT_CxV8U8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[129]: 0x00000000 (DXFMT_X8L8V8U8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[130]: 0x00000000 (DXFMT_A2W10V10U10)
2018-09-25T09:03:21.437Z| vmx| I125: cap[131]: 0x00000000 (DXFMT_ALPHA8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[132]: 0x00000000 (DXFMT_R_S10E5)
2018-09-25T09:03:21.437Z| vmx| I125: cap[133]: 0x00000000 (DXFMT_R_S23E8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[134]: 0x00000000 (DXFMT_RG_S10E5)
2018-09-25T09:03:21.437Z| vmx| I125: cap[135]: 0x00000000 (DXFMT_RG_S23E8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[136]: 0x00000000 (DXFMT_BUFFER)
2018-09-25T09:03:21.437Z| vmx| I125: cap[137]: 0x00000000 (DXFMT_Z_D24X8)
2018-09-25T09:03:21.437Z| vmx| I125: cap[138]: 0x00000000 (DXFMT_V16U16)
2018-09-25T09:03:21.437Z| vmx| I125: cap[139]: 0x00000000 (DXFMT_G16R16)
2018-09-25T09:03:21.437Z| vmx| I125: cap[140]: 0x00000000 (DXFMT_A16B16G16R16)
2018-09-25T09:03:21.437Z| vmx| I125: cap[141]: 0x00000000 (DXFMT_UYVY)
2018-09-25T09:03:21.437Z| vmx| I125: cap[142]: 0x00000000 (DXFMT_YUY2)
2018-09-25T09:03:21.437Z| vmx| I125: cap[143]: 0x00000000 (DXFMT_NV12)
2018-09-25T09:03:21.438Z| vmx| I125: cap[144]: 0x00000000 (DXFMT_AYUV)
2018-09-25T09:03:21.438Z| vmx| I125: cap[145]: 0x00000000 (DXFMT_R32G32B32A32_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[146]: 0x00000000 (DXFMT_R32G32B32A32_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[147]: 0x00000000 (DXFMT_R32G32B32A32_SINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[148]: 0x00000000 (DXFMT_R32G32B32_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[149]: 0x00000000 (DXFMT_R32G32B32_FLOAT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[150]: 0x00000000 (DXFMT_R32G32B32_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[151]: 0x00000000 (DXFMT_R32G32B32_SINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[152]: 0x00000000 (DXFMT_R16G16B16A16_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[153]: 0x00000000 (DXFMT_R16G16B16A16_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[154]: 0x00000000 (DXFMT_R16G16B16A16_SNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[155]: 0x00000000 (DXFMT_R16G16B16A16_SINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[156]: 0x00000000 (DXFMT_R32G32_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[157]: 0x00000000 (DXFMT_R32G32_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[158]: 0x00000000 (DXFMT_R32G32_SINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[159]: 0x00000000 (DXFMT_R32G8X24_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[160]: 0x00000000 (DXFMT_D32_FLOAT_S8X24_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[161]: 0x00000000 (DXFMT_R32_FLOAT_X8X24_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[162]: 0x00000000 (DXFMT_X32_TYPELESS_G8X24_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[163]: 0x00000000 (DXFMT_R10G10B10A2_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[164]: 0x00000000 (DXFMT_R10G10B10A2_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[165]: 0x00000000 (DXFMT_R11G11B10_FLOAT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[166]: 0x00000000 (DXFMT_R8G8B8A8_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[167]: 0x00000000 (DXFMT_R8G8B8A8_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[168]: 0x00000000 (DXFMT_R8G8B8A8_UNORM_SRGB)
2018-09-25T09:03:21.438Z| vmx| I125: cap[169]: 0x00000000 (DXFMT_R8G8B8A8_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[170]: 0x00000000 (DXFMT_R8G8B8A8_SINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[171]: 0x00000000 (DXFMT_R16G16_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[172]: 0x00000000 (DXFMT_R16G16_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[173]: 0x00000000 (DXFMT_R16G16_SINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[174]: 0x00000000 (DXFMT_R32_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[175]: 0x00000000 (DXFMT_D32_FLOAT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[176]: 0x00000000 (DXFMT_R32_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[177]: 0x00000000 (DXFMT_R32_SINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[178]: 0x00000000 (DXFMT_R24G8_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[179]: 0x00000000 (DXFMT_D24_UNORM_S8_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[180]: 0x00000000 (DXFMT_R24_UNORM_X8_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[181]: 0x00000000 (DXFMT_X24_TYPELESS_G8_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[182]: 0x00000000 (DXFMT_R8G8_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[183]: 0x00000000 (DXFMT_R8G8_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[184]: 0x00000000 (DXFMT_R8G8_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[185]: 0x00000000 (DXFMT_R8G8_SINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[186]: 0x00000000 (DXFMT_R16_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[187]: 0x00000000 (DXFMT_R16_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[188]: 0x00000000 (DXFMT_R16_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[189]: 0x00000000 (DXFMT_R16_SNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[190]: 0x00000000 (DXFMT_R16_SINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[191]: 0x00000000 (DXFMT_R8_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[192]: 0x00000000 (DXFMT_R8_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[193]: 0x00000000 (DXFMT_R8_UINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[194]: 0x00000000 (DXFMT_R8_SNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[195]: 0x00000000 (DXFMT_R8_SINT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[196]: 0x00000000 (DXFMT_P8)
2018-09-25T09:03:21.438Z| vmx| I125: cap[197]: 0x00000000 (DXFMT_R9G9B9E5_SHAREDEXP)
2018-09-25T09:03:21.438Z| vmx| I125: cap[198]: 0x00000000 (DXFMT_R8G8_B8G8_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[199]: 0x00000000 (DXFMT_G8R8_G8B8_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[200]: 0x00000000 (DXFMT_BC1_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[201]: 0x00000000 (DXFMT_BC1_UNORM_SRGB)
2018-09-25T09:03:21.438Z| vmx| I125: cap[202]: 0x00000000 (DXFMT_BC2_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[203]: 0x00000000 (DXFMT_BC2_UNORM_SRGB)
2018-09-25T09:03:21.438Z| vmx| I125: cap[204]: 0x00000000 (DXFMT_BC3_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[205]: 0x00000000 (DXFMT_BC3_UNORM_SRGB)
2018-09-25T09:03:21.438Z| vmx| I125: cap[206]: 0x00000000 (DXFMT_BC4_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[207]: 0x00000000 (DXFMT_ATI1)
2018-09-25T09:03:21.438Z| vmx| I125: cap[208]: 0x00000000 (DXFMT_BC4_SNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[209]: 0x00000000 (DXFMT_BC5_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[210]: 0x00000000 (DXFMT_ATI2)
2018-09-25T09:03:21.438Z| vmx| I125: cap[211]: 0x00000000 (DXFMT_BC5_SNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[212]: 0x00000000 (DXFMT_R10G10B10_XR_BIAS_A2_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[213]: 0x00000000 (DXFMT_B8G8R8A8_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[214]: 0x00000000 (DXFMT_B8G8R8A8_UNORM_SRGB)
2018-09-25T09:03:21.438Z| vmx| I125: cap[215]: 0x00000000 (DXFMT_B8G8R8X8_TYPELESS)
2018-09-25T09:03:21.438Z| vmx| I125: cap[216]: 0x00000000 (DXFMT_B8G8R8X8_UNORM_SRGB)
2018-09-25T09:03:21.438Z| vmx| I125: cap[217]: 0x00000000 (DXFMT_Z_DF16)
2018-09-25T09:03:21.438Z| vmx| I125: cap[218]: 0x00000000 (DXFMT_Z_DF24)
2018-09-25T09:03:21.438Z| vmx| I125: cap[219]: 0x00000000 (DXFMT_Z_D24S8_INT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[220]: 0x00000000 (DXFMT_YV12)
2018-09-25T09:03:21.438Z| vmx| I125: cap[221]: 0x00000000 (DXFMT_R32G32B32A32_FLOAT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[222]: 0x00000000 (DXFMT_R16G16B16A16_FLOAT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[223]: 0x00000000 (DXFMT_R16G16B16A16_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[224]: 0x00000000 (DXFMT_R32G32_FLOAT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[225]: 0x00000000 (DXFMT_R10G10B10A2_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[226]: 0x00000000 (DXFMT_R8G8B8A8_SNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[227]: 0x00000000 (DXFMT_R16G16_FLOAT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[228]: 0x00000000 (DXFMT_R16G16_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[229]: 0x00000000 (DXFMT_R16G16_SNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[230]: 0x00000000 (DXFMT_R32_FLOAT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[231]: 0x00000000 (DXFMT_R8G8_SNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[232]: 0x00000000 (DXFMT_R16_FLOAT)
2018-09-25T09:03:21.438Z| vmx| I125: cap[233]: 0x00000000 (DXFMT_D16_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[234]: 0x00000000 (DXFMT_A8_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[235]: 0x00000000 (DXFMT_BC1_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[236]: 0x00000000 (DXFMT_BC2_UNORM)
2018-09-25T09:03:21.438Z| vmx| I125: cap[237]: 0x00000000 (DXFMT_BC3_UNORM)
2018-09-25T09:03:21.439Z| vmx| I125: cap[238]: 0x00000000 (DXFMT_B5G6R5_UNORM)
2018-09-25T09:03:21.439Z| vmx| I125: cap[239]: 0x00000000 (DXFMT_B5G5R5A1_UNORM)
2018-09-25T09:03:21.439Z| vmx| I125: cap[240]: 0x00000000 (DXFMT_B8G8R8A8_UNORM)
2018-09-25T09:03:21.439Z| vmx| I125: cap[241]: 0x00000000 (DXFMT_B8G8R8X8_UNORM)
2018-09-25T09:03:21.439Z| vmx| I125: cap[242]: 0x00000000 (DXFMT_BC4_UNORM)
2018-09-25T09:03:21.439Z| vmx| I125: cap[243]: 0x00000000 (DXFMT_BC5_UNORM)
2018-09-25T09:03:21.439Z| vmx| I125: cap[244]: 0x00000000 (ALLOW_D16_L16_COPY)
2018-09-25T09:03:21.439Z| vmx| I125: cap[245]: 0x00000000 (LOGICOPS)
2018-09-25T09:03:21.439Z| vmx| I125: SVGA3dCaps: guest, compatibility level: 5
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 0]: 0x00000000 (3D)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 1]: 0x00000000 (MAX_LIGHTS)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 2]: 0x00000000 (MAX_TEXTURES)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 3]: 0x00000000 (MAX_CLIP_PLANES)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 4]: 0x00000000 (VERTEX_SHADER_VERSION)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 5]: 0x00000000 (VERTEX_SHADER)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 6]: 0x00000000 (FRAGMENT_SHADER_VERSION)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 7]: 0x00000000 (FRAGMENT_SHADER)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 8]: 0x00000000 (MAX_RENDER_TARGETS)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 9]: 0x00000000 (S23E8_TEXTURES)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 10]: 0x00000000 (S10E5_TEXTURES)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 11]: 0x00000000 (MAX_FIXED_VERTEXBLEND)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 12]: 0x00000000 (D16_BUFFER_FORMAT)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 13]: 0x00000000 (D24S8_BUFFER_FORMAT)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 14]: 0x00000000 (D24X8_BUFFER_FORMAT)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 15]: 0x00000000 (QUERY_TYPES)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 16]: 0x00000000 (TEXTURE_GRADIENT_SAMPLING)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 17]: 0.000000 (MAX_POINT_SIZE)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 18]: 0x00000000 (MAX_SHADER_TEXTURES)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 19]: 0x00001000 (MAX_TEXTURE_WIDTH)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 20]: 0x00001000 (MAX_TEXTURE_HEIGHT)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 21]: 0x00000000 (MAX_VOLUME_EXTENT)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 22]: 0x00000000 (MAX_TEXTURE_REPEAT)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 23]: 0x00000000 (MAX_TEXTURE_ASPECT_RATIO)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 24]: 0x00000000 (MAX_TEXTURE_ANISOTROPY)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 25]: 0x00000000 (MAX_PRIMITIVE_COUNT)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 26]: 0x00000000 (MAX_VERTEX_INDEX)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 27]: 0x00000000 (MAX_VERTEX_SHADER_INSTRUCTIONS)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 28]: 0x00000000 (MAX_FRAGMENT_SHADER_INSTRUCTIONS)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 29]: 0x00000000 (MAX_VERTEX_SHADER_TEMPS)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 30]: 0x00000000 (MAX_FRAGMENT_SHADER_TEMPS)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 31]: 0x00000000 (TEXTURE_OPS)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 32]: 0x00000000 (SURFACEFMT_X8R8G8B8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 33]: 0x00000000 (SURFACEFMT_A8R8G8B8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 34]: 0x00000000 (SURFACEFMT_A2R10G10B10)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 35]: 0x00000000 (SURFACEFMT_X1R5G5B5)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 36]: 0x00000000 (SURFACEFMT_A1R5G5B5)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 37]: 0x00000000 (SURFACEFMT_A4R4G4B4)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 38]: 0x00000000 (SURFACEFMT_R5G6B5)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 39]: 0x00000000 (SURFACEFMT_LUMINANCE16)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 40]: 0x00000000 (SURFACEFMT_LUMINANCE8_ALPHA8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 41]: 0x00000000 (SURFACEFMT_ALPHA8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 42]: 0x00000000 (SURFACEFMT_LUMINANCE8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 43]: 0x00000000 (SURFACEFMT_Z_D16)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 44]: 0x00000000 (SURFACEFMT_Z_D24S8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 45]: 0x00000000 (SURFACEFMT_Z_D24X8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 46]: 0x00000000 (SURFACEFMT_DXT1)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 47]: 0x00000000 (SURFACEFMT_DXT2)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 48]: 0x00000000 (SURFACEFMT_DXT3)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 49]: 0x00000000 (SURFACEFMT_DXT4)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 50]: 0x00000000 (SURFACEFMT_DXT5)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 51]: 0x00000000 (SURFACEFMT_BUMPX8L8V8U8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 52]: 0x00000000 (SURFACEFMT_A2W10V10U10)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 53]: 0x00000000 (SURFACEFMT_BUMPU8V8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 54]: 0x00000000 (SURFACEFMT_Q8W8V8U8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 55]: 0x00000000 (SURFACEFMT_CxV8U8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 56]: 0x00000000 (SURFACEFMT_R_S10E5)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 57]: 0x00000000 (SURFACEFMT_R_S23E8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 58]: 0x00000000 (SURFACEFMT_RG_S10E5)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 59]: 0x00000000 (SURFACEFMT_RG_S23E8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 60]: 0x00000000 (SURFACEFMT_ARGB_S10E5)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 61]: 0x00000000 (SURFACEFMT_ARGB_S23E8)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 62]: 0x00000000 (MISSING62)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 63]: 0x00000000 (MAX_VERTEX_SHADER_TEXTURES)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 64]: 0x00000000 (MAX_SIMULTANEOUS_RENDER_TARGETS)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 65]: 0x00000000 (SURFACEFMT_V16U16)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 66]: 0x00000000 (SURFACEFMT_G16R16)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 67]: 0x00000000 (SURFACEFMT_A16B16G16R16)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 68]: 0x00000000 (SURFACEFMT_UYVY)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 69]: 0x00000000 (SURFACEFMT_YUY2)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 70]: 0x00000000 (MULTISAMPLE_NONMASKABLESAMPLES)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 71]: 0x00000000 (MULTISAMPLE_MASKABLESAMPLES)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 72]: 0x00000000 (ALPHATOCOVERAGE)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 73]: 0x00000000 (SUPERSAMPLE)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 74]: 0x00000000 (AUTOGENMIPMAPS)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 75]: 0x00000000 (SURFACEFMT_NV12)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 76]: 0x00000000 (SURFACEFMT_AYUV)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 77]: 0x00000000 (MAX_CONTEXT_IDS)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 78]: 0x00000000 (MAX_SURFACE_IDS)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 79]: 0x00000000 (SURFACEFMT_Z_DF16)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 80]: 0x00000000 (SURFACEFMT_Z_DF24)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 81]: 0x00000000 (SURFACEFMT_Z_D24S8_INT)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 82]: 0x00000000 (SURFACEFMT_ATI1)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 83]: 0x00000000 (SURFACEFMT_ATI2)
2018-09-25T09:03:21.439Z| vmx| I125: cap[ 84]: 0x00000000 (DEAD1)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 85]: 0x00000000 (VIDEO_DECODE)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 86]: 0x00000000 (VIDEO_PROCESS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 87]: 0x00000000 (LINE_AA)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 88]: 0x00000000 (LINE_STIPPLE)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 89]: 0.000000 (MAX_LINE_WIDTH)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 90]: 0.000000 (MAX_AA_LINE_WIDTH)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 91]: 0x00000000 (SURFACEFMT_YV12)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 92]: 0x00000000 (DEAD3)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 93]: 0x00000000 (TS_COLOR_KEY)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 94]: 0x00000000 (DEAD2)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 95]: 0x00000000 (DXCONTEXT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 96]: 0x00000000 (MAX_TEXTURE_ARRAY_SIZE)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 97]: 0x00000000 (DX_MAX_VERTEXBUFFERS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 98]: 0x00000000 (DX_MAX_CONSTANT_BUFFERS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[ 99]: 0x00000000 (DX_PROVOKING_VERTEX)
2018-09-25T09:03:21.440Z| vmx| I125: cap[100]: 0x00000000 (DXFMT_X8R8G8B8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[101]: 0x00000000 (DXFMT_A8R8G8B8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[102]: 0x00000000 (DXFMT_R5G6B5)
2018-09-25T09:03:21.440Z| vmx| I125: cap[103]: 0x00000000 (DXFMT_X1R5G5B5)
2018-09-25T09:03:21.440Z| vmx| I125: cap[104]: 0x00000000 (DXFMT_A1R5G5B5)
2018-09-25T09:03:21.440Z| vmx| I125: cap[105]: 0x00000000 (DXFMT_A4R4G4B4)
2018-09-25T09:03:21.440Z| vmx| I125: cap[106]: 0x00000000 (DXFMT_Z_D32)
2018-09-25T09:03:21.440Z| vmx| I125: cap[107]: 0x00000000 (DXFMT_Z_D16)
2018-09-25T09:03:21.440Z| vmx| I125: cap[108]: 0x00000000 (DXFMT_Z_D24S8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[109]: 0x00000000 (DXFMT_Z_D15S1)
2018-09-25T09:03:21.440Z| vmx| I125: cap[110]: 0x00000000 (DXFMT_LUMINANCE8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[111]: 0x00000000 (DXFMT_LUMINANCE4_ALPHA4)
2018-09-25T09:03:21.440Z| vmx| I125: cap[112]: 0x00000000 (DXFMT_LUMINANCE16)
2018-09-25T09:03:21.440Z| vmx| I125: cap[113]: 0x00000000 (DXFMT_LUMINANCE8_ALPHA8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[114]: 0x00000000 (DXFMT_DXT1)
2018-09-25T09:03:21.440Z| vmx| I125: cap[115]: 0x00000000 (DXFMT_DXT2)
2018-09-25T09:03:21.440Z| vmx| I125: cap[116]: 0x00000000 (DXFMT_DXT3)
2018-09-25T09:03:21.440Z| vmx| I125: cap[117]: 0x00000000 (DXFMT_DXT4)
2018-09-25T09:03:21.440Z| vmx| I125: cap[118]: 0x00000000 (DXFMT_DXT5)
2018-09-25T09:03:21.440Z| vmx| I125: cap[119]: 0x00000000 (DXFMT_BUMPU8V8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[120]: 0x00000000 (DXFMT_BUMPL6V5U5)
2018-09-25T09:03:21.440Z| vmx| I125: cap[121]: 0x00000000 (DXFMT_BUMPX8L8V8U8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[122]: 0x00000000 (DXFMT_FORMAT_DEAD1)
2018-09-25T09:03:21.440Z| vmx| I125: cap[123]: 0x00000000 (DXFMT_ARGB_S10E5)
2018-09-25T09:03:21.440Z| vmx| I125: cap[124]: 0x00000000 (DXFMT_ARGB_S23E8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[125]: 0x00000000 (DXFMT_A2R10G10B10)
2018-09-25T09:03:21.440Z| vmx| I125: cap[126]: 0x00000000 (DXFMT_V8U8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[127]: 0x00000000 (DXFMT_Q8W8V8U8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[128]: 0x00000000 (DXFMT_CxV8U8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[129]: 0x00000000 (DXFMT_X8L8V8U8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[130]: 0x00000000 (DXFMT_A2W10V10U10)
2018-09-25T09:03:21.440Z| vmx| I125: cap[131]: 0x00000000 (DXFMT_ALPHA8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[132]: 0x00000000 (DXFMT_R_S10E5)
2018-09-25T09:03:21.440Z| vmx| I125: cap[133]: 0x00000000 (DXFMT_R_S23E8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[134]: 0x00000000 (DXFMT_RG_S10E5)
2018-09-25T09:03:21.440Z| vmx| I125: cap[135]: 0x00000000 (DXFMT_RG_S23E8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[136]: 0x00000000 (DXFMT_BUFFER)
2018-09-25T09:03:21.440Z| vmx| I125: cap[137]: 0x00000000 (DXFMT_Z_D24X8)
2018-09-25T09:03:21.440Z| vmx| I125: cap[138]: 0x00000000 (DXFMT_V16U16)
2018-09-25T09:03:21.440Z| vmx| I125: cap[139]: 0x00000000 (DXFMT_G16R16)
2018-09-25T09:03:21.440Z| vmx| I125: cap[140]: 0x00000000 (DXFMT_A16B16G16R16)
2018-09-25T09:03:21.440Z| vmx| I125: cap[141]: 0x00000000 (DXFMT_UYVY)
2018-09-25T09:03:21.440Z| vmx| I125: cap[142]: 0x00000000 (DXFMT_YUY2)
2018-09-25T09:03:21.440Z| vmx| I125: cap[143]: 0x00000000 (DXFMT_NV12)
2018-09-25T09:03:21.440Z| vmx| I125: cap[144]: 0x00000000 (DXFMT_AYUV)
2018-09-25T09:03:21.440Z| vmx| I125: cap[145]: 0x00000000 (DXFMT_R32G32B32A32_TYPELESS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[146]: 0x00000000 (DXFMT_R32G32B32A32_UINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[147]: 0x00000000 (DXFMT_R32G32B32A32_SINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[148]: 0x00000000 (DXFMT_R32G32B32_TYPELESS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[149]: 0x00000000 (DXFMT_R32G32B32_FLOAT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[150]: 0x00000000 (DXFMT_R32G32B32_UINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[151]: 0x00000000 (DXFMT_R32G32B32_SINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[152]: 0x00000000 (DXFMT_R16G16B16A16_TYPELESS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[153]: 0x00000000 (DXFMT_R16G16B16A16_UINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[154]: 0x00000000 (DXFMT_R16G16B16A16_SNORM)
2018-09-25T09:03:21.440Z| vmx| I125: cap[155]: 0x00000000 (DXFMT_R16G16B16A16_SINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[156]: 0x00000000 (DXFMT_R32G32_TYPELESS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[157]: 0x00000000 (DXFMT_R32G32_UINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[158]: 0x00000000 (DXFMT_R32G32_SINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[159]: 0x00000000 (DXFMT_R32G8X24_TYPELESS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[160]: 0x00000000 (DXFMT_D32_FLOAT_S8X24_UINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[161]: 0x00000000 (DXFMT_R32_FLOAT_X8X24_TYPELESS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[162]: 0x00000000 (DXFMT_X32_TYPELESS_G8X24_UINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[163]: 0x00000000 (DXFMT_R10G10B10A2_TYPELESS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[164]: 0x00000000 (DXFMT_R10G10B10A2_UINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[165]: 0x00000000 (DXFMT_R11G11B10_FLOAT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[166]: 0x00000000 (DXFMT_R8G8B8A8_TYPELESS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[167]: 0x00000000 (DXFMT_R8G8B8A8_UNORM)
2018-09-25T09:03:21.440Z| vmx| I125: cap[168]: 0x00000000 (DXFMT_R8G8B8A8_UNORM_SRGB)
2018-09-25T09:03:21.440Z| vmx| I125: cap[169]: 0x00000000 (DXFMT_R8G8B8A8_UINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[170]: 0x00000000 (DXFMT_R8G8B8A8_SINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[171]: 0x00000000 (DXFMT_R16G16_TYPELESS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[172]: 0x00000000 (DXFMT_R16G16_UINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[173]: 0x00000000 (DXFMT_R16G16_SINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[174]: 0x00000000 (DXFMT_R32_TYPELESS)
2018-09-25T09:03:21.440Z| vmx| I125: cap[175]: 0x00000000 (DXFMT_D32_FLOAT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[176]: 0x00000000 (DXFMT_R32_UINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[177]: 0x00000000 (DXFMT_R32_SINT)
2018-09-25T09:03:21.440Z| vmx| I125: cap[178]: 0x00000000 (DXFMT_R24G8_TYPELESS)
2018-09-25T09:03:21.441Z| vmx| I125: cap[179]: 0x00000000 (DXFMT_D24_UNORM_S8_UINT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[180]: 0x00000000 (DXFMT_R24_UNORM_X8_TYPELESS)
2018-09-25T09:03:21.441Z| vmx| I125: cap[181]: 0x00000000 (DXFMT_X24_TYPELESS_G8_UINT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[182]: 0x00000000 (DXFMT_R8G8_TYPELESS)
2018-09-25T09:03:21.441Z| vmx| I125: cap[183]: 0x00000000 (DXFMT_R8G8_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[184]: 0x00000000 (DXFMT_R8G8_UINT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[185]: 0x00000000 (DXFMT_R8G8_SINT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[186]: 0x00000000 (DXFMT_R16_TYPELESS)
2018-09-25T09:03:21.441Z| vmx| I125: cap[187]: 0x00000000 (DXFMT_R16_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[188]: 0x00000000 (DXFMT_R16_UINT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[189]: 0x00000000 (DXFMT_R16_SNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[190]: 0x00000000 (DXFMT_R16_SINT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[191]: 0x00000000 (DXFMT_R8_TYPELESS)
2018-09-25T09:03:21.441Z| vmx| I125: cap[192]: 0x00000000 (DXFMT_R8_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[193]: 0x00000000 (DXFMT_R8_UINT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[194]: 0x00000000 (DXFMT_R8_SNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[195]: 0x00000000 (DXFMT_R8_SINT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[196]: 0x00000000 (DXFMT_P8)
2018-09-25T09:03:21.441Z| vmx| I125: cap[197]: 0x00000000 (DXFMT_R9G9B9E5_SHAREDEXP)
2018-09-25T09:03:21.441Z| vmx| I125: cap[198]: 0x00000000 (DXFMT_R8G8_B8G8_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[199]: 0x00000000 (DXFMT_G8R8_G8B8_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[200]: 0x00000000 (DXFMT_BC1_TYPELESS)
2018-09-25T09:03:21.441Z| vmx| I125: cap[201]: 0x00000000 (DXFMT_BC1_UNORM_SRGB)
2018-09-25T09:03:21.441Z| vmx| I125: cap[202]: 0x00000000 (DXFMT_BC2_TYPELESS)
2018-09-25T09:03:21.441Z| vmx| I125: cap[203]: 0x00000000 (DXFMT_BC2_UNORM_SRGB)
2018-09-25T09:03:21.441Z| vmx| I125: cap[204]: 0x00000000 (DXFMT_BC3_TYPELESS)
2018-09-25T09:03:21.441Z| vmx| I125: cap[205]: 0x00000000 (DXFMT_BC3_UNORM_SRGB)
2018-09-25T09:03:21.441Z| vmx| I125: cap[206]: 0x00000000 (DXFMT_BC4_TYPELESS)
2018-09-25T09:03:21.441Z| vmx| I125: cap[207]: 0x00000000 (DXFMT_ATI1)
2018-09-25T09:03:21.441Z| vmx| I125: cap[208]: 0x00000000 (DXFMT_BC4_SNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[209]: 0x00000000 (DXFMT_BC5_TYPELESS)
2018-09-25T09:03:21.441Z| vmx| I125: cap[210]: 0x00000000 (DXFMT_ATI2)
2018-09-25T09:03:21.441Z| vmx| I125: cap[211]: 0x00000000 (DXFMT_BC5_SNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[212]: 0x00000000 (DXFMT_R10G10B10_XR_BIAS_A2_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[213]: 0x00000000 (DXFMT_B8G8R8A8_TYPELESS)
2018-09-25T09:03:21.441Z| vmx| I125: cap[214]: 0x00000000 (DXFMT_B8G8R8A8_UNORM_SRGB)
2018-09-25T09:03:21.441Z| vmx| I125: cap[215]: 0x00000000 (DXFMT_B8G8R8X8_TYPELESS)
2018-09-25T09:03:21.441Z| vmx| I125: cap[216]: 0x00000000 (DXFMT_B8G8R8X8_UNORM_SRGB)
2018-09-25T09:03:21.441Z| vmx| I125: cap[217]: 0x00000000 (DXFMT_Z_DF16)
2018-09-25T09:03:21.441Z| vmx| I125: cap[218]: 0x00000000 (DXFMT_Z_DF24)
2018-09-25T09:03:21.441Z| vmx| I125: cap[219]: 0x00000000 (DXFMT_Z_D24S8_INT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[220]: 0x00000000 (DXFMT_YV12)
2018-09-25T09:03:21.441Z| vmx| I125: cap[221]: 0x00000000 (DXFMT_R32G32B32A32_FLOAT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[222]: 0x00000000 (DXFMT_R16G16B16A16_FLOAT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[223]: 0x00000000 (DXFMT_R16G16B16A16_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[224]: 0x00000000 (DXFMT_R32G32_FLOAT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[225]: 0x00000000 (DXFMT_R10G10B10A2_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[226]: 0x00000000 (DXFMT_R8G8B8A8_SNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[227]: 0x00000000 (DXFMT_R16G16_FLOAT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[228]: 0x00000000 (DXFMT_R16G16_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[229]: 0x00000000 (DXFMT_R16G16_SNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[230]: 0x00000000 (DXFMT_R32_FLOAT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[231]: 0x00000000 (DXFMT_R8G8_SNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[232]: 0x00000000 (DXFMT_R16_FLOAT)
2018-09-25T09:03:21.441Z| vmx| I125: cap[233]: 0x00000000 (DXFMT_D16_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[234]: 0x00000000 (DXFMT_A8_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[235]: 0x00000000 (DXFMT_BC1_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[236]: 0x00000000 (DXFMT_BC2_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[237]: 0x00000000 (DXFMT_BC3_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[238]: 0x00000000 (DXFMT_B5G6R5_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[239]: 0x00000000 (DXFMT_B5G5R5A1_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[240]: 0x00000000 (DXFMT_B8G8R8A8_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[241]: 0x00000000 (DXFMT_B8G8R8X8_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[242]: 0x00000000 (DXFMT_BC4_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: cap[243]: 0x00000000 (DXFMT_BC5_UNORM)
2018-09-25T09:03:21.441Z| vmx| I125: USB: Initializing 'UHCI' host controller
2018-09-25T09:03:21.441Z| svga| I125: VTHREAD start thread 1 "svga" tid 78561
2018-09-25T09:03:21.442Z| vmx| I125: Ethernet0 MAC Address: 00:0c:29:d8:4f:5e
2018-09-25T09:03:21.443Z| vmx| I125: USB: Initializing 'EHCI' host controller
2018-09-25T09:03:21.443Z| vmx| A100: ConfigDB: Setting vmci0.id = "-1663545506"
2018-09-25T09:03:21.443Z| vmx| I125: AHCI:Successfully created adapter 'sata0' as num 0
2018-09-25T09:03:21.443Z| vmx| I125: SCSI DEVICE (sata0:0): Computed value of sata0:0.useBounceBuffers: default
2018-09-25T09:03:21.443Z| vmx| I125: DISKUTIL: sata0:0 : capacity=0 logical sector size=2048
2018-09-25T09:03:21.443Z| vmx| I125: DISKUTIL: sata0:0 : geometry=0/0/0
2018-09-25T09:03:21.443Z| vmx| I125: AHCI:Creating ATAPI CDROM on SATA adapter.
2018-09-25T09:03:21.443Z| vmx| I125: AHCI:Successfully created device: sata0:0
2018-09-25T09:03:21.443Z| vmx| I125: GuestLib Generated SessionId 2428346555583220640
2018-09-25T09:03:21.443Z| vmx| I125: WORKER: Creating new group with numThreads=1 (11)
2018-09-25T09:03:21.443Z| vmx| I125: DISKUTIL: (null) : max toolsVersion = 0, type = 0
2018-09-25T09:03:21.444Z| vmx| I125: DISKUTIL: Offline toolsVersion = 0, type = 0
2018-09-25T09:03:21.444Z| vmx| I125: TOOLS setting legacy tools version to '0' type 0, manifest status is 9
2018-09-25T09:03:21.444Z| vmx| I125: VMXVmdb_SetToolsVersionStatus: status value set to 'noTools', 'noTools', install possible
2018-09-25T09:03:21.444Z| vmx| I125: Tools: sending 'OS_PowerOn' (state = 3) state change request
2018-09-25T09:03:21.444Z| vmx| I125: Tools: Delaying state change request to state 3.
2018-09-25T09:03:21.444Z| vmx| I125: TOOLS INSTALL initializing state to IDLE on power on.
2018-09-25T09:03:21.448Z| vmx| I125: FeatureCompat: No VM masks.
2018-09-25T09:03:21.448Z| vmx| I125: MonPmc: ctrBase 0xc1 selBase 0x186/1 PGC 1/1 SMM 1 drain 1 AMD 0
2018-09-25T09:03:21.448Z| vmx| I125+ MonPmc: gen counters num: 4 width 48 write width 32
2018-09-25T09:03:21.448Z| vmx| I125+ MonPmc: fix counters num: 3 width 48
2018-09-25T09:03:21.448Z| vmx| I125+ MonPmc: unavailable counters: 0x200000000
2018-09-25T09:03:21.450Z| vmx| I125: guestCpuFeatures = 0xb9
2018-09-25T09:03:21.450Z| vmx| I125: guestNumGenPerfCounters = 4
2018-09-25T09:03:21.450Z| vmx| I125: guestNumFixedPerfCounters = 0
2018-09-25T09:03:21.450Z| vmx| I125: guestPerfCtrArch = 1
2018-09-25T09:03:21.450Z| vmx| A100: ConfigDB: Setting monitor.phys_bits_used = "43"
2018-09-25T09:03:21.450Z| vmx| I125: Full guest CPUID with differences from hostCPUID highlighted.
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest vendor: GenuineIntel
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest family: 0x6 model: 0x1e stepping: 0x5
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest codename: Clarksfield/Lynnfield (Core i5)
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest name: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID level eaxIn, ecxIn: eax ebx ecx edx
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000000, 0: 0x0000000b 0x756e6547 0x6c65746e 0x49656e69
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000001, 0: 0x000106e5 0x00010800 0x81b80201 0x0fabfbff
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID *host level 00000001, 0: 0x000106e5 0x00100800 0x0098e3fd 0xbfebfbff
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000002, 0: 0x55035a01 0x00f0b2e4 0x00000000 0x09ca212c
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000003, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000004, 0: 0x00000121 0x01c0003f 0x0000003f 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID *host level 00000004, 0: 0x1c004121 0x01c0003f 0x0000003f 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000004, 1: 0x00000122 0x00c0003f 0x0000007f 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID *host level 00000004, 1: 0x1c004122 0x00c0003f 0x0000007f 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000004, 2: 0x00000143 0x01c0003f 0x000001ff 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID *host level 00000004, 2: 0x1c004143 0x01c0003f 0x000001ff 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000004, 3: 0x00000163 0x03c0003f 0x00001fff 0x00000002
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID *host level 00000004, 3: 0x1c03c163 0x03c0003f 0x00001fff 0x00000002
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000004, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000004, 5: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000004, 6: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000006, 0: 0x00000004 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID *host level 00000006, 0: 0x00000003 0x00000002 0x00000001 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000007, 0: 0x00000000 0x00000002 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID *host level 00000007, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000008, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 00000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000a, 0: 0x07300401 0x0000007f 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID *host level 0000000a, 0: 0x07300403 0x00000044 0x00000000 0x00000603
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000b, 0: 0x00000000 0x00000001 0x00000100 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID *host level 0000000b, 0: 0x00000001 0x00000002 0x00000100 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000b, 1: 0x00000000 0x00000001 0x00000201 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID *host level 0000000b, 1: 0x00000004 0x00000008 0x00000201 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 1: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 2: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 3: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 5: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 6: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 7: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 8: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 9: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, a: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, b: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, c: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, d: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, e: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, f: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 10: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 11: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 12: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 13: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 14: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 15: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 16: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 17: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 18: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 19: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 1a: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 1b: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 1c: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 1d: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 1e: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 1f: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 20: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 21: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 22: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 23: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 24: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 25: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 26: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 27: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 28: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 29: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 2a: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 2b: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 2c: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 2d: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 2e: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 2f: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 30: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 31: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 32: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 33: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 34: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 35: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 36: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 37: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 38: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 39: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 3a: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 3b: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 3c: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 3d: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 0000000d, 3e: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 40000000, 0: 0x40000010 0x61774d56 0x4d566572 0x65726177
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 40000001, 0: 0x31237648 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 40000002, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 40000003, 0: 0x00000262 0x00000000 0x00000000 0x00000508
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 40000004, 0: 0x00000020 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 40000005, 0: 0xffffffff 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 40000006, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 40000007, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 40000008, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 40000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 4000000a, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 4000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 4000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 4000000d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 4000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 4000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 40000010, 0: 0x002ab9e3 0x000101d0 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000000, 0: 0x80000008 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000001, 0: 0x00000000 0x00000000 0x00000000 0x08100800
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID *host level 80000001, 0: 0x00000000 0x00000000 0x00000001 0x28100800
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000002, 0: 0x65746e49 0x2952286c 0x726f4320 0x4d542865
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000003, 0: 0x37692029 0x55504320 0x20202020 0x20202020
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000004, 0: 0x30363820 0x20402020 0x30382e32 0x007a4847
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000005, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000006, 0: 0x00000000 0x00000000 0x01006040 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000007, 0: 0x00000000 0x00000000 0x00000000 0x00000100
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000008, 0: 0x0000302b 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID *host level 80000008, 0: 0x00003024 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000009, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 8000000b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 8000000c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 8000000d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 8000000e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 8000000f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000010, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000011, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000012, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000013, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000014, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.450Z| vmx| I125: guest vs. host CPUID guest level 80000015, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 80000016, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 80000017, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 80000018, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 80000019, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 8000001a, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 8000001b, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 8000001c, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 8000001d, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 8000001d, 1: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 8000001d, 2: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 8000001d, 3: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 8000001d, 4: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 8000001e, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: guest vs. host CPUID guest level 8000001f, 0: 0x00000000 0x00000000 0x00000000 0x00000000
2018-09-25T09:03:21.451Z| vmx| I125: Msg_Post: Error
2018-09-25T09:03:21.451Z| vmx| I125: [msg.cpuid.noLongmode2] This virtual machine is configured for 64-bit guest operating systems. However, 64-bit operation is not possible.
2018-09-25T09:03:21.451Z| vmx| I125+ This host supports Intel VT-x, but Intel VT-x is disabled.
2018-09-25T09:03:21.451Z| vmx| I125+ Intel VT-x might be disabled if it has been disabled in the BIOS/firmware settings or the host has not been power-cycled since changing this setting.
2018-09-25T09:03:21.451Z| vmx| I125+ (1) Verify that the BIOS/firmware settings enable Intel VT-x and disable 'trusted execution.'
2018-09-25T09:03:21.451Z| vmx| I125+ (2) Power-cycle the host if either of these BIOS/firmware settings have been changed.
2018-09-25T09:03:21.451Z| vmx| I125+ (3) Power-cycle the host if you have not done so since installing VMware ESX.
2018-09-25T09:03:21.451Z| vmx| I125+ (4) Update the host's BIOS/firmware to the latest version.
2018-09-25T09:03:21.451Z| vmx| I125+ For more detailed information, see http://vmware.com/info?id=152.
2018-09-25T09:03:21.451Z| vmx| I125: ----------------------------------------
2018-09-25T09:03:21.452Z| vmx| I125: Module 'CPUID' power on failed.
2018-09-25T09:03:21.452Z| vmx| I125: VMX_PowerOn: ModuleTable_PowerOn = 0
2018-09-25T09:03:21.452Z| vmx| I125: Tools: ToolsRunningStatus_Exit, delayedRequest is 0xDE0E9CAE0
2018-09-25T09:03:21.452Z| vmx| I125: SVMotion_PowerOff: Not running Storage vMotion. Nothing to do
2018-09-25T09:03:21.452Z| svga| I125: SVGA thread is alive
2018-09-25T09:03:21.452Z| svga| I125: SVGA thread is exiting
2018-09-25T09:03:21.452Z| vmx| I125: Destroying virtual dev for scsi0:0 vscsi=8205
2018-09-25T09:03:21.452Z| vmx| I125: VMMon_VSCSIStopVports: No such target on adapter
2018-09-25T09:03:21.453Z| vmx| I125: MKS thread stopping before Finalize
2018-09-25T09:03:21.453Z| vmx| I125: MKS thread is stopped
2018-09-25T09:03:21.453Z| mks| I125: MKS-RenderMain: Stopping MKSBasicOps
2018-09-25T09:03:21.453Z| mks| I125: MKS PowerOff
2018-09-25T09:03:21.453Z| mks| I125: MKS thread is exiting
2018-09-25T09:03:21.453Z| vmx| I125: SVMotion_PowerOff: Not running Storage vMotion. Nothing to do
2018-09-25T09:03:21.453Z| vmx| I125: scsi0:0: numIOs = 0 numMergedIOs = 0 numSplitIOs = 0 ( 0.0%)
2018-09-25T09:03:21.453Z| vmx| I125: Closing disk 'scsi0:0'
2018-09-25T09:03:21.453Z| vmx| I125: SVMotion_DiskCloseCB: Closing disks in svmPhase 0. Not destroying mirror node.
2018-09-25T09:03:21.453Z| vmx| I125: DISKLIB-VMFS : "/vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01-flat.vmdk" : closed.
2018-09-25T09:03:21.454Z| vmx| I125: Vix: [78552 mainDispatch.c:1175]: VMAutomationPowerOff: Powering off.
2018-09-25T09:03:21.454Z| vmx| W115: /vmfs/volumes/5ba8c666-7d750299-b9cc-a0369f3e99cc/Render01/Render01.vmx: Cannot remove symlink /var/run/vmware/0/78511684418_78552/configFile: No such file or directory
2018-09-25T09:03:21.454Z| vmx| I125: WORKER: asyncOps=1 maxActiveOps=1 maxPending=0 maxCompleted=0
2018-09-25T09:03:21.470Z| vmx| I125: Vix: [78552 mainDispatch.c:4234]: VMAutomation_ReportPowerOpFinished: statevar=1, newAppState=1873, success=1 additionalError=0
2018-09-25T09:03:21.470Z| vmx| I125+ Power on failure messages: Module 'CPUID' power on failed.
2018-09-25T09:03:21.470Z| vmx| I125+ This virtual machine is configured for 64-bit guest operating systems. However, 64-bit operation is not possible.
2018-09-25T09:03:21.470Z| vmx| I125+ This host supports Intel VT-x, but Intel VT-x is disabled.
2018-09-25T09:03:21.470Z| vmx| I125+ Intel VT-x might be disabled if it has been disabled in the BIOS/firmware settings or the host has not been power-cycled since changing this setting.
2018-09-25T09:03:21.470Z| vmx| I125+ (1) Verify that the BIOS/firmware settings enable Intel VT-x and disable 'trusted execution.'
2018-09-25T09:03:21.470Z| vmx| I125+ (2) Power-cycle the host if either of these BIOS/firmware settings have been changed.
2018-09-25T09:03:21.470Z| vmx| I125+ (3) Power-cycle the host if you have not done so since installing VMware ESX.
2018-09-25T09:03:21.470Z| vmx| I125+ (4) Update the host's BIOS/firmware to the latest version.
2018-09-25T09:03:21.470Z| vmx| I125+ For more detailed information, see http://vmware.com/info?id=152.
2018-09-25T09:03:21.470Z| vmx| I125+ Failed to start the virtual machine.
2018-09-25T09:03:21.470Z| vmx| I125: Vix: [78552 mainDispatch.c:4234]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1870, success=1 additionalError=0
2018-09-25T09:03:21.470Z| vmx| I125: Transitioned vmx/execState/val to poweredOff
2018-09-25T09:03:21.470Z| vmx| I125: Vix: [78552 mainDispatch.c:4234]: VMAutomation_ReportPowerOpFinished: statevar=0, newAppState=1870, success=0 additionalError=0
2018-09-25T09:03:21.470Z| vmx| I125: Vix: [78552 mainDispatch.c:4273]: Error VIX_E_FAIL in VMAutomation_ReportPowerOpFinished(): Unknown error
2018-09-25T09:03:21.475Z| vmx| I125: Vix: [78552 mainDispatch.c:834]: VMAutomation_LateShutdown()
2018-09-25T09:03:21.475Z| vmx| I125: Vix: [78552 mainDispatch.c:783]: VMAutomationCloseListenerSocket. Closing listener socket.
2018-09-25T09:03:21.475Z| vmx| I125: Flushing VMX VMDB connections
2018-09-25T09:03:21.475Z| vmx| I125: VigorTransport_ServerCloseClient: Closing transport DE0B1DAB0 (err = 0)
2018-09-25T09:03:21.475Z| vmx| I125: VigorTransport_ServerDestroy: server destroyed.
2018-09-25T09:03:21.475Z| vmx| I125: VMX exit (0).
2018-09-25T09:03:21.476Z| vmx| I125: AIOMGR-S : stat o=2 r=6 w=0 i=0 br=98304 bw=0
2018-09-25T09:03:21.476Z| vmx| I125: AIOMGR-U : stat o=1 r=36 w=9 i=0 br=8936 bw=8604
2018-09-25T09:03:21.476Z| vmx| I125: OBJLIB-LIB: ObjLib cleanup done.
2018-09-25T09:03:21.476Z| vmx| W115: VMX has left the building: 0.
