VMware recommends a gigabit connection between vSphere Client and the vCenter Server it is connecting to. Has anyone had success running the vSphere Client over a slower internet connection? If so, what have you found is the slowest speed that is practically usable? Has anyone made it work over regular home internet service plan speeds - (which are always less than 100Mbps down and less than 100Mbps up) - if so what is the minimum you recommend.
Thanks
