I'm new to vSphere and I have a couple of servers set up to test vSphere before I roll it out.
I have a HP DL380 server with a HP dual port 10Gb NIC. This NIC is connected to a HP switch. The switch is set up so the 2 ports are teamed. If I boot the server under windows 2008 it shows 20Gb in the team's local connection status.
Booted as a ESXi 5.0 Host I have NIC teaming set up as:
Load Balancing: Route based on IP hash
Network Failover Detection: Link Status Only
Notify Switches/Fallback: both to Yes
Both the NIC ports show under Active adapters (no standby adapters).
These NIC ports are only used for the default standard vSwitch0 (no other VM port groups defined).
On a Win 2008 R2 VM (same for a 2003 R2 VM) the local connection status shows 10Gb. Shouldn't it show 20Gb?
I also noticed that if I backup one of these VMs (using Veeamzip) and restore to another server (Esxi 5.1 with a Intel 4 port Gb NIC teamed, same basic setup) it still shows 10Gb when the max available is 4Gb. Shouldn't it show 4Gb?
