CA TPX Session Management for z/OS
Tech Tip:  PTFs Required for the CAUNZIP Utility with CA Common Services r14.1
Nov 19, 2015 03:41 PM
As we have recently had several questions about the CAUNZIP utility, please note that the following maintenance is required above the base CCS r14.1 product in order to use this tool:
- RO54635 (Delivers the Utility)
- RO58216 (Corrects JCL problem)
The CAUNZIP utility provides non-MSM users with a method of handling a large number of PTFs downloaded with a support online shopping cart.  It is described in the CA Common Services r14.1 Administration Guide (see Chapter 11).
The CAUNZIP utility is also described in the CA Common Services r14.1 Wiki (see Administrating > CAUNZIP Utility) which includes the most up to date CCS information.
If you are at the CA Common Services r14.1 S1401 level, these PTFs should already be installed.
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
