Solutions
Support & Services
Company
How To Buy
Skip to main content (Press Enter).
Sign in
Skip auxiliary navigation (Press Enter).
Register
Skip main navigation (Press Enter).
Toggle navigation
Search Options
Home
Communities
All Communities
Enterprise Software
Mainframe Software
Symantec Enterprise
Blogs
All Blogs
Enterprise Software
Mainframe Software
Symantec Enterprise
Events
Enterprise Software
Mainframe Software
Symantec Enterprise
VMware
Water Cooler
Education
Groups
Enterprise Software
Mainframe Software
Symantec Enterprise
DX Infrastructure Management
Private Community
Community Home
Threads
Library
Events
Members
Back to Library
Tech tip: jvm_monitor does not send QOS_DEFINITION for QOS_JVM_THREADCOUNT
0
Recommend
Oct 18, 2018 11:38 AM
Marco Ippati
Document ID :
KB000117082
Last Modified Date :
08/10/2018
Issue:
I have activated the
"Thread Count"
QOS in jvm_monitoring but data is not coming into the database. Looking at DrNimbus I found out that probe does not send QOS_DEFINITON for this specific metric with the QOS Deinition messages for QOS_JVM_THREADCOUNT.
However, the monitor
"Thread Count"
sends that data correctly with QOS_MESSAGES. For this Reason data for the specific QOS is not available.
Environment:
UIM 8.x
jvm_monitor 1.48
Cause:
This is a known issue for the
ThredCount
(QOS_JVM_THREADCOUNT) monitor.
For QOS_MESSAGE messages to be stored to the database a previous bus message with the QOS_DEFINITION for the same metric type must be received by the data_engine.
For some reason, the specific monitor JVM> java.lang > Threading > Name >
ThredCount
(QOS_JVM_THREADCOUNT) does not send the definition on probe start or after saving the monitor. The probe though sends the QOS_DEFINITION for QOS_JVM_THREADCOUNT if activated on different monitors within the same resource.
Resolution:
WORKAROUND:
The workaround consists in activating any other monitor for the QOS "QOS_JVM_THREADCOUNT" in order to create the definition on the DB. Once it is created, the QOS from the monitor
ThredCount
will be stored correctly.
INSTRUCTIONS:
1. Activate the QOS for the monitor "PeakThreadCount" (under the same folder under threading) - by default it defines: QOS_JVM_THREADCOUNT
2. Apply and save.
3. If you don't want to monitor "PeakThreadCount" deactivate it.
4. ThreadCount QOS is now stored on DB as definition was created by PeakThreadCount so
ThredCount
QOS is now stored.
Additional Information:
jvm_monitor Release Notes
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
Skip Navigation Links
Footer
Copyright 2023. All rights reserved.
Powered by Higher Logic
