Hi Jim
As per your screenshot above, the OneClick web server accepts Java Runtime Environment version 1.8.0_51 or above (1.8.0_51+). The "+" means alllow new versions. 1.8.0_121+ and 1.8.0_161+ are redundant. The 1.8.0_51+ takes precedence to the 1.8.0_121+ and 1.8.0_161+.
I would modify to the JRE version to that comes with Spectrum 22.2.5: 1.8.0_352 and you can include the "+" to allow new versions.
Note: OneClick will not allow JRE 1.8.0_351 and below
Thanks,
Silvio
