Can some share with me how to use boolean configuration to configure datastore accessible?
I not sure which is the right, we set the unit "1" then received below alert:
Hope some can advise on this.
Thank you.
Try to use a threshold: true or false.
Hi Luc,
When use true or false, "Ok" button become grey:
Hello,
For availability is 100 so it might be the same in your case.
Marius
