Automation Analytics & Intelligence (AAI)
 Problem during authentication
Thierry Verreyt's profile image
Broadcom Partner Thierry Verreyt posted Oct 11, 2023 03:56 AM
HI,
I just install AAI on a new Redhat 8
When I try to connect I have this error and I cannot connect to AAI.
I try with http://xxx.xxx.xxx.xxx8:8080/aai/web/v2/login
John Hiett's profile image
Broadcom Employee John Hiett
Hi Thierry,
Can you please share the error message as unfortunately I don't see it in your initial message.
If its possible for us to identify the issue immediately then we can post here, but if not then I recommend that you raise a Support Case to engage our engineers.
Many thanks and kind regards,
Jon
