Hi,
We have received additional questions from our customers.
What does "own" in "own descriptor value" mean in the answer you received previously?
I didn't know what it was showing, so I checked to see if there was a value that could be specified.
Since it is a text field attribute, I am thinking of using it by setting "Password not updated", but even if I specified the filter "notcontains", I did not get the expected result, so I set the condition to the specified value. I am wondering if there is.
Regarding "If you set different values, they will be different. If you set the same values, they will be the same.", "What" will result in different values when different values are set in "descriptor"?
Or is it the result of a filter?
This question came up because a customer of ours had set up a filter and the results were not what they expected.
In the manual filter settings, if the group is static, only "equals" is valid.
Our customer found that setting the filter to "beginswith/endswith" produced the expected results.
Therefore, we believe that the target group is not a static group.
When "equals" is set, the filtered result will be the specified value.
When "beginswith & endswith" is set, the filtered result will be the specified value.
When "notcontains" was set, the filtered results did not match the specified value.
* "equals" and "notcontains" are set to the same 'Password not updated'.
Is there an example of what settings should be made for notcontains?
Thanks,
