Symantec PGP Encryption
 ADK icon with White cross in red circle ?
Eric Bonheur's profile image
Eric Bonheur posted Aug 05, 2024 09:31 AM
Hello
We have hundreds of users enrolled as GKM in our 10.5.1 server. All keys have an ADK.  However, for a few of them, the ADK is displayed with a white cross ('plus' sign?) in a red circle in the key properties (as in the attached file). For all others keys, the ADK is displayed with no icon.
Do you know what it means?
Thanks!
Attachment  View in library
Dallin Fyffe's profile image
Broadcom Employee Dallin Fyffe
It just means the key is an ADK, and designated as such.
If you have some keys that are not showing the red circle with the cross, you can always reach out and we can do a health check to see if everything looks good.
In my testing, I usually only see the red circle icon, so tough to say for sure what is going on with your lcients.
If you have clients and are checking in, and show the ADK, then you're probably good, but reach out to Symantec Encryption Support if you're wanting to do a deep dive to make sure everything is good.
