I tried to reply last night to "NO reply"
so here we go again :)
Instead of retyping I am attaching PDF with my reply e-mail as answer.
Mail response with Pictures
Hi John,
Today it was really looooooong day , but as we know, while incident is fresh it can be fixed 😊
So its almost midnight 😊
Hopefully Support site improved and I can forward pictures over direct mail answer:
This is my current status in Schedulers section.
This is list aof my test jobs:
You said:
It sounds like you have already addressed the required EXECUTION_TRIGGER parameter within Automic's UC_SYSTEM_SETTINGS.
Since I forget quickly, I had to jump to my Automic LAB to see this , because in current state while writing I can't remember what I eat this morning 😊
and it seems under user 0 of Automic Automation under DIV_VARIABLES in UC_SYSTEMSETTINGS variable I had EXECUTION_TRIGGER under Value1 set to N, which I „repaired“ to Y
You said:
Does the account being used to connect to Automic (the account specified in the scheduler definition's Automic REST API User field) have the correct privileges within Automic - Read (R) and Executions (S) as well as Access to Administration and Access to deactivated tasks?
Account created just for this purpose is called REST_USER and it is total admin. Hopefully I made it this way to be sure it works 😊
Regardind documentation, Now when I see this part:
Important !
- For performance reasons, it is recommended to install the Automic Connector near the Automation Engine, not near AAI.
- Make sure that the EXECUTION_TRIGGER parameter of the UC_SYSTEM_SETTINGS variable in Automic Automation is set to Y[es]. Otherwise, Automic Automation cannot establish the connection to the Automic Connector. For more information, please refer to the Automic Automation documentation at https://docs.automic.com/.
I installed connector next to AAI since it is just POC, and ignored second row ☹ just because I could not find it from 1st attempt ….
So You pinponted to this steps, and now it is 0:19 ( I am slow) and I changed EXECUTION_TRIGGER TO Y, restarted AE, restarted AAI, Automic connector and I present to You following results:
new thing is : green ON TIME marking status.
Jammer on Time also finally green.
Overview still have same parsing error.
Jobs still have no details about start end times, and reoccurences.
So I think I might start some job manually, to see if this triger works. Since there is no retroactive variable ?
after some time:
Seems we have some progress….. it's only 0:41 😊
So this was kind of interactive trooubleshooter. But I still have in
0:51 its time to settle down and go to sleep 😊
Jobs are appearing as I start them.
I would like to have all past jobs data available in my list , so My future POC would make sense ..
Thank You John.
I will continue this troubleshooter tomorow. And hopefully try linux AAI server with connector.
b.r.
Mladen
