Resurrecting an old topic, I am interested in current observations from Endevor admins who have already implemented anything similar......
I am not talking about the Endevor action called ARCHIVE action but extending Endevor DISPLAY for decommissioned elements by setting up an new environment called ARCHIVE/OBSOLETE/DEAD or something.
Source would be moved from PROD to an ARCHIVE environment.
This may be a MOVE to PROD next in map or TRANSFER to isolated environ (pros and cons to being visible up the map but a separate subject).
My particular interest is in a process for users moving code to an archive environment and handling shipment to remote copy of prod when using the archive environment.
Normally our code moved to PROD will be SHIPPED to a mapped remote set of libraries that needs to be emptied when the source is removed from PROD stage.
That can be achieved by a package to delete from PROD and shipping that production package to the remote PROD destination.
However considering a new ARCHIVE environ, standard Endevor source management would be move and delete behind only if the source and output management at targe was already successful in arriving at the target ARCHIVE environ.
It makes sense the users want confidence of move to archive being okay before the delete happens.
They also want to take the outputs to output libraries for the archive environment in case they need to be transferred back to prod in exceptional circumstances (bound to happen sometime).
To handle the removal from remote PROD destination requires delete from Endevor PROD stage and ship.
The requirement to see successful move to ARCHIVE requires the move to archive before the delete from PROD.
I want to keep using standard Endevor processing / panels as much as possible - allowing users to select the elements using the Endevor panels when building the packages etc
Therefore I think,
Process required to use....
1) PACKAGE 1 MOVE actions from PROD (to ARCH) (NO DELETE BEHIND)
2) PACKAGE 2 DELETE actions from PROD
3) SHIP PACKAGE 2 to PROD
Assuming this process used I would also need:
Additional processing to be provided:
- build the delete from PROD package automatically include matching elements that was moved to ARCH
(I can make a job for user where you enter the name of the ARCHIVE package and it builds the associated DELETE package). Later this can be included as step after shipment in skel when ARCHIVE detected so user did not need to create it.
- report elements in ARCH that still exist in PROD after (the process was not completed)
Finally,
Backout considerations
Deleted from PROD and archived but still required in prod.
Backout in case a program is removed that was actually still needed
Standard package backout for the deleted element.
Plus some follow up process for Endevor admin to copyback from ARCH to re-instate source at prod.
Thoughts?
