IT Management Suite
Using Deployment Solution with Cloud Enabled Management
  • 1.  Using Deployment Solution with Cloud Enabled Management
    Broadcom Employee
    Posted Nov 01, 2023 04:44 PM
    The white paper describing how to use Deployment Solution with Cloud Enabled Management has been updated to include information regarding some of the new features added in the ITMS 8.7.1 release, including the offline domain join functionality and the ability for scripted OS installations to use HTTP/HTTPS when a UNC path is not available.
    You can find an updated version of the document here
