SYSVIEW Performance Management
SYSVIEW Datacom Command Enhancements for System and Cross-System
  • 1.  SYSVIEW Datacom Command Enhancements for System and Cross-System
    Broadcom Employee
    Posted Sep 12, 2024 02:29 PM
    Greetings SYSVIEW community!
    On behalf of the SYSVIEW product team, we are pleased to announce the SYSVIEW Datacom Option adds support for group, system, and cross-system capabilities to SYSVIEW Datacom commands. Also, the Datacom Option expands the functionally or various commands.
    The enhancements are delivered to you in Feature PTF LU14691. The following list summarizes the enhancements.
    Group, System, and Cross-System Capabilities Updates
    You can now leverage several Datacom commands for group, system, and cross-system displays. Also, several command parameters were added or updated to let you tailor the display to meet the needs to monitor one instance of Datacom, or several instances on one or more systems.
    Datacom Release Field Updates
    You can now view the Datacom release number and the level set number (if available) for the monitored job on several Datacom commands. For example, DCLIST.
    For more detailed information about the Datacom Option enhancements, see the topics Datacom Cross-System Enabled Command Standardization and Updated Datacom Commands in Datacom Enhancements.
    NOTE: The Datacom Option enhancements that are delivered with Feature PTF LU14691 do not apply to SYSVIEW Essentials configurations of SYSVIEW Performance Management.
    We value your business and thank you for using SYSVIEW!
    James Bauman
    Staff Technical Writer
    Mainframe Software Division | Broadcom
