My understanding is if the agent is running as root, it connects as ruu and effectively su's to id in the login object.
You can ssh with a key using the FTP agent using the issue remote commands option. This has to be enabled in the agent and is very limiting as you don't have and entire process block for running a full script. Its good for running a single command line.
on the flip side, you don't need an agent on the remote side.
Original Message:
Sent: May 22, 2025 12:29 PM
Subject: Running a jobs with a Login Unix machines via SSH Keys connection
I'm curious about this too...
Dunno if this might be helpful to you...
In our environment, our sysadmins have locked down certain accounts (service accounts) so that you cannot login to them directly -- you would have to login as your own user, and then 'su' over to the service account in question if you need to use one of those accounts yourself. That service account would have a password associated with it, but you wouldn't be able to login directly as that user. (I don't know exactly how the sysadmins restrict direct logins, but there's evidently some way to do it.) We put those service account credentials into our login object, and we're able to run jobs against that agent just fine.
So perhaps you could get around this problem if your sysadmins are allowed to create a password-authenticated user for Automic to use that does not allow direct logins?
