Hi Mani,
apart from AE script and the use of an Output filter you can change the max. value for the Runtime tab of the jobs:
regards,
Peter
Automic Certified Professional & Expert & Knight
For AUTOMIC trainings please check
https://www.qskills.de/qs/workshops/automic/------------------------------
Original Message:
Sent: Sep 30, 2022 01:02 AM
Subject: Return code in post process script
HI Everyone
sub_xyz failed with below error message "detailedMessage": "",Job failed
** TEXT=" Job ended " RETCODE=01
Above is the log of a failed job that throws return code as 1 .User wants return code 1 to make the job ended ok in UC4.What is the post process script to be used in job to make the return code status 1 as successfull.
