DX Unified Infrastructure Management
  • 1.  Problem with UIM azure probe. am trying to monitor the azure application but am facing (java.util.concurrent.ExecutionException: java.lang.IllegalAccessError:)
    Posted May 29, 2025 12:36 AM
    UIM : 23.4
    Azure probe: 3.21
  • 2.  RE: Problem with UIM azure probe. am trying to monitor the azure application but am facing (java.util.concurrent.ExecutionException: java.lang.IllegalAccessError:)
    Broadcom Employee
    Posted May 29, 2025 07:56 AM
      |   view attached
    Hi Willy,
    This azure 3.22 Test build fix should resolve the reported issue. Please download and deploy it in your test/dev or Prod (as you can downgrade back to azure 3.21 GA if it doesnt work), and let me know the results.
    Thanks,
    Steve
    Steve Danseglio
    Senior Principal Support Engineer (Technical Support Engineer 5)
    Broadcom Software-IMS Division
    UIM Certified Expert
    KCSv6 Practices Certified
    Certified Customer Success Manager (CCSM) Level 1
    Attachment(s)
  • 3.  RE: Problem with UIM azure probe. am trying to monitor the azure application but am facing (java.util.concurrent.ExecutionException: java.lang.IllegalAccessError:)
    Broadcom Employee
    Posted May 29, 2025 08:03 AM
    Edited by Stephen Danseglio May 29, 2025 08:07 AM
      |   view attached
    Hi Willy,
    If you still see the error after deploying the T2 test build:  java.util.concurrent.ExecutionException: java.lang.IllegalAccessError: tried to access class in the azure.log, use this T3 test build (attached) as azure-3.22T3.zip, and recheck the log.
    The azure probe fixes created and included in the T2 and T3 build will both be included and available in the next GA version of the probe.
    Best Regards,
    Steve
    Steve Danseglio
    Attachment(s)
    zip
    azure-3.22T3.zip   28.30 MB 1 version
  • 4.  RE: Problem with UIM azure probe. am trying to monitor the azure application but am facing (java.util.concurrent.ExecutionException: java.lang.IllegalAccessError:)
    Posted Jun 01, 2025 05:37 AM
    Hello Stephen
    Thank you very much for your guide, this is very helpful.
    I will apply the hotfix and I will get to you, when i am back in office.
  • 5.  RE: Problem with UIM azure probe. am trying to monitor the azure application but am facing (java.util.concurrent.ExecutionException: java.lang.IllegalAccessError:)
    Posted Jun 10, 2025 06:19 PM
    Thank you very much for your assistance, now the azure probe works well.
  • 6.  RE: Problem with UIM azure probe. am trying to monitor the azure application but am facing (java.util.concurrent.ExecutionException: java.lang.IllegalAccessError:)
    Broadcom Employee
    Posted Jun 10, 2025 06:20 PM
    Hi Willy,
    Glad it helped resolve the issue. ;-)
    Steve
    Steve Danseglio
