DX NetOps
  • 1.  Problem with atributtes port_admin_status and port_oper_status
    Posted Apr 11, 2025 11:56 AM
    It´s have  a problema with the devices from vendor RADWIN Inc.
    The attributes port_admin_status and port_oper_status of this devices no show the status.
    The vendor certification with was discovered is "Interfaces".
    When I consulting this parameter from DB vertica the parameters its empty.
    This is a example.
    drdata=> SELECT   item_id, item_name, item_alternate_name, device_primary_ip, port_admin_status,port_oper_status, port_speed_in, port_speed_out, port_type FROM dauser.dim_item where item_id='527086';
    item_id |    item_name    | item_alternate_name | device_primary_ip | port_admin_status | port_oper_status | port_speed_in | port_speed_out | port_type
      527086 | Radio Interface | Radio Interface     | 10.179.121.148    |                   |                  |             0 |              0 |        39
    (1 row)
    drdata=> SELECT   item_id, item_name, item_alternate_name, device_primary_ip, port_admin_status,port_oper_status, port_speed_in, port_speed_out, port_type FROM dauser.dim_item where item_id='527085';
      527085 | Management Port on Odu | Management Port on Odu | 10.179.121.148    |                   |                  |     100000000 |      100000000 |         6
    (1 row)
    But,If I consulting for example a device CISCO, the parameters its correct.
    drdata=> SELECT   item_id, item_name, item_alternate_name, device_primary_ip, port_admin_status,port_oper_status, port_speed_in, port_speed_out, port_type FROM dauser.dim_item where item_id='260733';
      260733 | Gi0       | Gi0                 | 10.70.126.100     |                 1 |                2 |    1000000000 |     1000000000 |         6
    (1 row)
    I need to resolve this problem.
  • 2.  RE: Problem with atributtes port_admin_status and port_oper_status
    Posted Apr 14, 2025 12:39 PM
    For information on what values are collected for each type of element, you should check the Vendor Certifications, under DA Administration page.
    For each vendor certification, under Metric Expression you'll see all values that are collected for the respective device/port. Not all values that are present on a Metric Family are collected for all Vendor Certifications. Only those that have something written under Metric Expression will be available in the database and in the presented reports. Although might seem common and trivial, not all parameters are available to be collected.
    Cătălin Fărcășanu
    Senior Consultant
    SolvIT Networks
