Endpoint Security Complete
  • 1.  Need installer for SEP 14.3RU9 Build 11232.9000 For Dark Site
    Posted Mar 18, 2025 11:33 AM
    I need an installer for my dark site.  My Entitlements only has a download that contains SAV64.dat and SAV64.info.  Or please tell me how to install the SEP version otherwise?  I do have a case open but ... I AM WAITING ... Yesterday the tech did attempt to assist by having me create an .exe from a SEPM with access to the internet but the .exe will not install on my dark site.  HELP
    TechChick
    Southwest Power Pool
  • 2.  RE: Need installer for SEP 14.3RU9 Build 11232.9000 For Dark Site
    Broadcom Employee
    Posted Mar 20, 2025 11:50 AM
    Hi Sherry,
    Thanks for using the Broadcom Community!
    I'm not sure what error you're getting with the ".exe" version of 14.3 RU9 SEP client, but if you need a ".msi" type file format instead you can follow the steps in the kb below to generate that:
    https://knowledge.broadcom.com/external/article/177945/creating-a-non-exe-or-a-msi-install-pack.html
    Alternatively, you also have the option to make the SEP client installation package a Dark Network "client type" which will "turn off" all the functionality in the SEP client that needs internet access.  For this check out this techdoc:
    https://techdocs.broadcom.com/us/en/symantec-security-software/endpoint-security-and-management/endpoint-protection/all/Dialog-Overview/cs-admin-page-install-packages-v14650803-d21e4696/client-install-settings-v9514696-d21e4792.html
    Best,
    Russ_V
