Hi Eshwar,
it depends on the devices capabilities.
- if they support SNMP, then I would proceed with Spectrum and PM. In this link, you can verify if their MIBs are certified. In case you cannot find them, then you can ask for a certification in Broadcom Support.
https://netops-certification.broadcom.com/
Note: I recommend to search by sysObjetID (value returned by OID 1.3.6.1.2.1.1.2)
- if they don't support SNMP, then I would recommend Mediation Manager. It seems there are some device packs for SBC
https://techdocs.broadcom.com/us/en/ca-enterprise-software/it-operations-management/mediation-manager/23-3/programming/read-the-list-of-all-supported-device-packs.html
Regards
Original Message:
Sent: Apr 17, 2024 01:05 AM
Subject: Monitor SonicWall, SBC and Avaya through DX NetOps portifolio
Hi community,
Can we monitor SonicWall, SBC and Avaya devices through DX NetOps portfolio? Please suggest which component is suitable for these devices.
Regards,
Eshwar
