Original Message:
Sent: Jul 11, 2025 10:17 AM
Subject: Migrating ORACLE Db wat UTF-8 with AE at V21.0.9 - need help to verify/test DB consistency
Hello,
we have tested a similar scenario but used Broadcom's tool "UTF-8 DB Migration Action Pack" for the migration.
After that we just kept the NLS settings in ucsrv.ini same as before:
... SP=NLS_LANGUAGE=AMERICAN,NLS_TERRITORY=AMERICA,CODESET=WE8ISO8859P1,NLS_LENGTH_SEMANTICS=CHAR
And continued running all UC4 components with version 21.0.
Later we updated the UC4 components with version 24.0 and changed sqlDriverConnect to:
… SP=NLS_LANGUAGE=AMERICAN,NLS_TERRITORY=AMERICA,CODESET=AL32UTF8
So far it worked, and we didn't find any issue with the encoding. However getting a "OK" form the vendor would be great.
KR, Josef
Original Message:
Sent: Jun 05, 2025 12:45 PM
Hello Experts, Good day!!
Current AE Version : 21.0.9+hf.1.build.1706176060310
AE is running on : Red Hat Enterprise Linux release 8.10
We wanted to avoid V21 to V24 & UTF database migration together so staying at AE V21, we are trying to migrating our ORACLE DB to UTF8.
We have copied our DEV system DB schema & imported into another NEW UTF8 DB without using Broadcom tools.
We started the AE without any change in the ucsrv.ini ( except the NEW ORACLE service name )
Here are the parameters from the UTF8 DB ( from DB table NLS_DATABASE_PARAMETERS ) :
NLS_NCHAR_CHARACTERSET=UTF8
NLS_CHARACTERSET=AL32UTF8
Here is the UC_SYSTEM_SETTINGS parameters (after logging in to AE client 0 that is using UTF8 DB) :
XML_ENCODING=ISO-8859-15
SERVER_OPTIONS=NNNMNNNNNN5NNP
Here are the parameter from ucsrv.ini
sqlDriverConnect=ODBCVAR=NNJNIORO
Sample jobs are running fine but before moving further, we wanted to check the data consistency after migrating from NON-UTF to UTF8 Database.
It will be very helpful if anyone have a checklist which already provided by Broadcom.
OR please feel free to share your observation if anyone has done it already.
Any comments/suggestion/comments would be a great help !!
Regards,
Prosenjit
