DX NetOps
  • 1.  Management Agent Lost alarms clear after right-click
    Posted Mar 15, 2024 12:03 PM
    Hello everyone,
    I have a strange situation in hands.
    I have a bunch of devices that have Management Agent Lost alarms and when I just click them (the device, not the alarm), it clears.
    Did anyone come across this?
    Spectrum Version: 10.4.0.0.95 on a Linux server
    Client: Windows 11 using java version that come with the Spectrum Version (Oneclick)
    Regards,
    Bruno
  • 2.  RE: Management Agent Lost alarms clear after right-click
    Broadcom Employee
    Posted Mar 15, 2024 03:11 PM
    Are these devices managed using snmpv3? If so, you might try clearing the v3 cache by doing the following CLI command on the SpectroSERVER:
    ./update action=0x10333 mh=<mh_of_VNM>
    As I am sure you are aware, Spectrum 10.4.0.0.95 is end of support.
    https://support.broadcom.com/web/ecx/support-content-notification/-/external/content/product-advisories/End-of-Service-Announcement-for-DX-NetOps-Spectrum-10.4-and-10.4.1/19298
    Joe
  • 3.  RE: Management Agent Lost alarms clear after right-click
    Posted Mar 16, 2024 06:09 AM
    Hello Joe,
    Thanks for the answer.
    This is not the case, the devices are all in V1 or V2c.
    Yes, we are aware that it reached EOS sometime ago. An update is being studied but not for the moment and we need to release our NOC from unnecessary alarms.
    Bruno
  • 4.  RE: Management Agent Lost alarms clear after right-click
    Posted Mar 18, 2024 05:35 AM
    Try also tuning the communication parameters. Increase either the timeout values or number of retries.
    Cătălin Fărcășanu
    Senior Consultant
    SolvIT Networks
  • 5.  RE: Management Agent Lost alarms clear after right-click
    Posted 29 days ago
    Thanks for the info Catalin, no such luck, the only difference is that the alarms take more time to re-appear.
    Thanks Catalin.
  • 6.  RE: Management Agent Lost alarms clear after right-click
    Posted 29 days ago
    Thanks for the tip but we did it before with no such luck, the only difference was that the alarms took more time to re-appear.
    Thanks Catalin
  • 7.  RE: Management Agent Lost alarms clear after right-click
    Broadcom Employee
    Posted Mar 18, 2024 08:57 AM
    Bruna,
    Also try running a sniffer (wireshark on Windows or tcpdump on Linux) to see the snmp leave Spectrum and if/how the devices are responding. As Catalin stated, could be a latency and increasing the DCM Timeout may resolve.
    Regards,
    Joe
  • 8.  RE: Management Agent Lost alarms clear after right-click
    Posted 30 days ago
    Thanks for the tip Joe, currently I don´t have access to the spectroservers and I can not do that (sniffing).
    I will have to wait for the access and after I will came back to you.
    Thanks Joe.
  • 9.  RE: Management Agent Lost alarms clear after right-click
    Posted 29 days ago
    Thanks for the info Catalin but no such luck, the only difference is that the alarms take more time to re-appear.
    Thanks Catalin.
