Service Virtualization
  • 1.  Issue in connecting JMS Connection factory in DevTest 10.8.3.1
    Posted Jul 25, 2025 02:51 PM
    Hi Team,
    In DevTest 10.8.3.1 version, not able to connect to JMS connection factory. Getting the below error.
    Have copied below jar files in lib folder.
    tibcrypt.jar
    tibjms.jar
    tibjmsadmin.jar
    tibjmsapps.jar
    tibrvjms.jar
    Error:
    Unexpected error: Could not initialize class com.tibco.security.providers.SecurityVendor_j2se
    java.lang.NoClassDefFoundError: Could not initialize class com.tibco.security.providers.SecurityVendor_j2se
    Please check and suggest if we are missing any other config or jar files.
    Thank You
    Rajasekhar
  • 2.  RE: Issue in connecting JMS Connection factory in DevTest 10.8.3.1
    Broadcom Employee
    Posted Jul 25, 2025 03:05 PM
    The class it is referring to should be in the tibcrypt.jar file.  You may need a newer version of this jar to use with the java we deliver with DevTest 10.8.3.1, which is
    C:\DevTest10.8.3.1\jre\bin>java -version
    openjdk version "17.0.7" 2023-04-18
    OpenJDK Runtime Environment Temurin-17.0.7+7 (build 17.0.7+7)
    OpenJDK 64-Bit Server VM Temurin-17.0.7+7 (build 17.0.7+7, mixed mode)
    Hope this helps.
    ~Marcy
  • 3.  RE: Issue in connecting JMS Connection factory in DevTest 10.8.3.1
    Posted Jul 25, 2025 03:36 PM
    Thank You Marcy for quick response. Which version for tibcrypt.jar file to be used for DevTest 10.8.3.1 version
    Regards,
    Rajasekhar
  • 4.  RE: Issue in connecting JMS Connection factory in DevTest 10.8.3.1
    Broadcom Employee
    Posted Jul 25, 2025 04:24 PM
    Just use the latest version of Tibco jar files.  We do not specify what version of Tibco we support with DevTest in our documentation, so just use the latest.
