Automic Workload Automation
  • 1.  Issue cancelling SSIS job using dtexec
    Posted Jun 10, 2024 03:30 AM
    HI Team
    The customer is using DTexec command line with the relevant parameters to execute a SSIS package in a Windows job.
    When they try to cancel a task the tasks ends in Automic but the back-end process is still running.
    Any ideas how to overcome this?
    Regards
    Klaus
  • 2.  RE: Issue cancelling SSIS job using dtexec
    Posted Jun 11, 2024 05:51 AM
    HI Klaus,
    This topic is covered in the Automic Help for Windows Agents.
    Have you tried playing with the 'Use Windows OS Job Object' setting?
    https://docs.automic.com/documentation/webhelp/english/AA/21.0/DOCU/21.0.9/Automic%20Automation%20Guides/Content/AWA/Objects/obj_jobs_WIN.htm?tocpath=Using%7CDesigning%7CObject-Specific%20Properties%7CJobs%20(JOBS)%7CWindows%7C_____0
  • 3.  RE: Issue cancelling SSIS job using dtexec
    Posted Jun 11, 2024 08:06 AM
    HI Kay
    Thank you for the response.
    I missed that setting.
    I requested the customer to test.
    Thanks
    Klaus
