Content & Malware Analysis
ISG - Connection proxySG VA to CAS VA (same ISG)
  • 1.  ISG - Connection proxySG VA to CAS VA (same ISG)
    Posted Aug 10, 2024 03:51 AM
    Hello,
    After setting up ISG device I noticed (very late unfortunately) that CAS application is not compatible with vlan trunking meaning we had to dedicate 1 interface at least for the CAS application only....In my case for testing purpose I setup only one interface. here the current configuration :
    LAG5 (interface 2:0 2:1 2:2) - for proxy application
    2:3 - for CAS application
    Thing is, it was written in the documentation that interface sharing was possible between application but if I am not wrong there was nothing mentionned about CAS application not being compatible with vlan trunking.
    Next issue is that ICAP service work whenever it wants to.... I checked CPU / memory/ interface discard on both ISG and application no success .. And the service itself on CAS device seems to be working. Moreover during those issue, at network level both machine can see each other and ping each other. Next thing I did was to power off both application and restart ISG just in case. Nothing change....
    What I did next is that I tried to share interface 2:3 with the proxy application (as they have both an IP in same subnet) which does no seem to work (both machine cannot see each other at all).
    I was wondering if other people did face this issue ?
    Any idea in this kind of infrastructure what could be the root cause of this issue ? Proxy is in 7.4.2.1 and CAS 3.1.7.0. (ISG 2.3.7.1). I already opened a case for that but no progress at all (opened since 1 month)....
    Thanks in advance for your help
    Furil
