I'm re-creating some MCS configuration to monitor that certain Windows processes are running, using the "processes" probe. Originally such MCS configuration was created on an older version of UIM (the "Details" window in Operator Console says it has "Template version 2.44").
The new configuration is being created on a new UIM 20.4 CU4 installation, with processes v4.80 and processes_mcs v4.70 ("Details" window shows "Template version 4.70.1").
On the old installation, the MCS profile is configured to generate an alarm if the process isn't running:
Generate Alarm
Process Restart: (inactive)
Report on Process: Down
Severity: Information (greyed out, think it's related to the inactive "Process Restart" field)
Severity: Critical
Severity: Information (greyed out, becomes available if I set "Report on Process" to either "Up" or "(none)")
When I set up a new MCS profile, based on "Processes (Enhanced)", I only see some of these fields, and I can't change them - they are greyed out / not possible to change:
Process Restart: (inactive, greyed out)
Severity: Information (greyed out)
How can I configure an MCS profile to give alarms of a certain severity level when the process is (or isn't) running?
