"assigned_to": "string",
"custom1": "string",
"custom2": "string",
"custom3": "string",
"custom4": "string",
"custom5": "string",
"deviceIds": "string",
"domain": "string",
"hostname": "string",
"hub": "string",
"id": "string",
"includeClosed": "string",
"level": "string",
"message": "string",
"message_count": "string",
"origin": "string",
"probe": "string",
"robot": "string",
"source": "string",
"subsystem": "string",
"subsystem_id": "string",
"timeArrival": "2025-07-17T23:36:59.273Z",
"timeLast": "2025-07-17T23:36:59.273Z",
"userTag1": "string",
"userTag2": "string",
"visible": true
or
/uimapi/alarms/v1 #doesnt seem to any obvious difference between the two versions.
"domain": "string",
"hub": "string",
"id": "string",
"level": "string",
"origin": "string",
"probe": "string",
"robot": "string",
"source": "string",
"timeArrival": "2025-07-17T23:36:59.286Z",
"timeLast": "2025-07-17T23:36:59.286Z",
"visible": true
Steve Danseglio
Senior Principal Support Engineer (Technical Support Engineer 5)
Broadcom Software-IMS Division
UIM Certified Expert
KCSv6 Practices Certified
Certified Customer Success Manager (CCSM) Level 1
Original Message:
Sent: Jul 17, 2025 06:59 PM
Subject: How to create a filter for capture alarms specific with UIMAPI
This looks like you would actually want to use the Post /uimapi/alarms method to perform filtered queries:
I took the payload that I had from F12 in OC, and was able to return the boot alarms that I had using the following:
{"pageNumber":0,"pageNumberOnResponse":0,"pageSize":50,"quickFilter":"","filters":["visible = true"],"colFilters":[{"column":"message","operator":"CONTAINS","value":"boot","negated":false}],"showHistorical":false,"showInvisible":true,"sort":[{"sortColumn":"alarmId","sortDirection":"asc"}],"context":{},"selectedAlarmId":null,"customFilters":0}
Original Message:
Sent: Jul 09, 2025 12:29 PM
Hello everyone, how are you?
I need to share to another system through UIMAPI only some alarms specific, how can i to create the filter ?
I tested different options but isn't work... returns all alarms
Alarm one:
curl -X GET "https://operatorconsole.host.local:443/uimapi/alarms" \
-H "Authorization: Authorization: Basic <base64_encoded_credentials>" \
-H "Content-Type: application/json" \
-k \
-G \
--data-urlencode "filter=robot eq 'servldap01' and probe eq 'logmon' and message like '%Conexion%' and message like '%NO ESTABLECIDO%'" \
-o testApiFilter1.log
Alarm two:
-k \
-G \
--data-urlencode "filter=robot eq 'srvapp22-p10' and probe eq 'oracle' and message like '%El ID de conexion%'" \
-o testApiFilter2.log
or a combination
-k \
-G \
--data-urlencode "filter=(robot eq 'servldap01' and probe eq 'logmon' and message like '%Conexion%' and message like '%NO ESTABLECIDO%') or (robot eq 'srvapp22-p10' and probe eq 'oracle' and message like '%El ID de conexion')" \
-o testApiFilter.log
Any idea ?
