Endpoint Protection Cloud
  • 1.  Help getting a case escalated to Broadcom Engineering 60028910 Toyota GTS+ Issue
    Posted Aug 31, 2023 04:21 PM
    Is John Owen still around at Broadcom to help.
    For months we have been trying to have SEP resolve an important SEP product issue affecting ALL Toyota and Lexus dealerships.
    Toyota has a new vehicle diagnostic program called GTS+ by Denso that was rolled out to dealerships in May 2023.
    It does NOT work on any PC when is SEP installed.  If we uninstall SEP the software works, we reinstall SEP it doesn't work.  We have whitelisted all files and folders identified by DENSO.  SEP does not log what it is blocking and we get no SEP popups.
    I called other Toyota stores and confirmed that sites using SEP have the same issue as us.  It is not unique to my environment.  We submitted various exe's as "false positives" just to be sure with no product change.
    The TEIR 1 "support" people have no idea.  We keep asking for escalation to upper tiers and/or Broadcom engineering but the "support" person will not escalate.  They only keep going over and over the same knowledge base "solutions"
    They do not understand how the SEP product works or why SEP is stopping the Toyota diagnostic software from running.
    We keep only getting TD Synex TIER 1 "support" people who know nothing about how a car diagnostic program works.  They are quick to close case after case after case.  We call in and get another TIER 1 untrained "support" person in the product and we are not making and progress with this problem.
    Car Dealerships are considered banks under the US FTC and we use SEP to address FTC rules for protecting customer data and we look to SEP for that added layer of security.
    The most recent solution form TIER 1 "support" is to turn off SEP via SMC -stop and then turn it back on when done using the Toyota Diagnostic software.  How is that a solution?!
    CURRENT CASE OPENED IS 60028910
    Help us Broadcom.
    Mark J.
  • 2.  RE: Help getting a case escalated to Broadcom Engineering 60028910 Toyota GTS+ Issue
    Posted Sep 04, 2023 09:37 AM
    Hi John,
    Unfortunately this kind of issue is not something that is isolated to Broadcom. You will see it everywhere where subcontractors are unwilling to admit that they are having problems delivering the services they were hired for. It could be an unhealthy culture among certain technicians, or it could be the whole subcontracting organization; as customers we don't really have any way of knowing.
    When this happens you may want to consider contacting Broadcom directly to make them aware of the issues you are encountering with their support provider. I have personally had some success contacting them directly via the feedback page when this happened to our organization.
    https://www.broadcom.com/company/contact-us/feedback-and-comments
    For reference, you should provide enough ticket numbers that they can get a sense of the problem when they investigate along with any comments you feel may be helpful in resolving the issue.
    Hope this works for you.
  • 3.  RE: Help getting a case escalated to Broadcom Engineering 60028910 Toyota GTS+ Issue
    Posted Sep 04, 2023 02:03 PM
    Thanks Jon that was a very good suggestion.  We will try that route.
    I'll update if it worked.
    Mark
    On September 4, 2023 08:39:12 am CDT, "Jon Rein via Broadcom"
    <mail@broadcom.com> wrote:
    Hi John,  Unfortunately this kind of issue is not something that is
    are...
    [1]Broadcom
    [2]Endpoint
    Protection Cloud
    [3]Post
    New Message
    [4]Re: Help getting a case escalated to Broadcom
    [5]Reply to Group [6]Reply to Sender
    [7]Jon Rein Sep 4, 2023 9:37 AM
    [8]Jon Rein
    Hi John,
    of knowing.
    our organization.
    [9]www.broadcom.com/company/contact-us/...
      [10]Reply to Group Online   [11]Reply to Group via Email
    [12]View Thread   [13]Recommend   [14]Forward   [15]Flag as
    Inappropriate
