Automic Workload Automation
  • 1.  Automation Engine 21.0+ on Azure SQL Managed Instance
    Posted Sep 18, 2024 02:15 PM
    I suggest this product UC4/AE Server 21.0+ work with Azure SQL Managed Instance. "Microsoft ensures 100% compatibility of MS SQL Server with Azure SQL Managed Instance:
    What is Azure SQL? - Azure SQL | Microsoft Learn
    ·        Azure SQL Managed Instance: Modernize your existing SQL Server applications at scale with an intelligent fully managed instance as a service, with almost 100% feature parity with the SQL Server database engine. Best for most migrations to the cloud."
    Please submit this suggest to the respective team. Thanks!
    Andriy
  • 2.  RE: Automation Engine 21.0+ on Azure SQL Managed Instance
    Posted Sep 19, 2024 11:32 AM
    This suggestion is primarily for the AE product (Automic suite) Dev team and the related ones.
