Aha, ok I see. The NAS probe did not fail, so I didn't suspect any NAS problem. I'll give the downgrade a try at the next upgrade session.
Original Message:
Sent: Feb 03, 2025 01:16 PM
Subject: Alarm management problem after upgrade to 23.4.3
We have had some reports of this especially when Replication between NAS probes is enabled. It is being investigated as a defect but for now, it appears that downgrading only the NAS probe to 23.4.2 resolves the issue, so it may not be necessary to revert the entire upgrade.
Original Message:
Sent: Feb 03, 2025 01:44 AM
We had problems with alarm management after upgrading to 23.4.3. Alarms not visible in IM (but the counter was not zero). In OC alarms were visible but acknowledging not working. Had to revert back to CU2.
What could the cause be? Did anybody else experience this?
