Hi Ron
You need to do a POST request on the executions endpoint
https://docs.automic.com/documentation/webhelp/english/AA/24.3/DOCU/24.3/REST%20API/Automation.Engine/index.html?overrideUrls=../Automation.Engine/swagger.json,../Continuous.Delivery.Automation/swagger.json,../Analytics/swagger.json,../Infrastructure.Manager/swagger.json
The example from the documentation provides two variables:
"TEXTFIELD1#": "test",
"CHECKGROUP1#": "AE/AE"
You need to catch them in the object (that is started) by either having a promptset attached to it fetching the variables or by utilizing the READ AE script statement.
Regards
Joel
☎️ Swisscom Automation/AI Engineer & 🧙 PEM Creator
Online Automic Training 24/7:
https://membership.philippelmer.com/ (deutsch)
https://pemautomic.com (english)
Original Message:
Sent: Feb 28, 2025 08:31 AM
Subject: activate a workflow via restapi call passing a variable to the flow being activated
How do you activate a workflow via restapi call passing a variable to the flow being activated?
