Automic Workload Automation
  • 1.  Ability to monitor waits when configured to "allow 1 simultaneous execution"
    Posted Jan 16, 2025 01:09 PM
    Hi,
    I'm wondering if there is a way to monitor the instances of job executions that have to wait for a previous instance of the same job to finish.  We have some jobs configured to "allow 1 simultaneous execution," and the configured action is "wait".  I would like to measure the impact these waits have, but to do so I first need to be able to tell when they occur.
    It seems like the ideal solution would be a db query, so I could report on these; but any other technique would help.
    Also, is it possible to tell when a SYNC object has forced a job to wait?
    Thanks,
    Doug
  • 2.  RE: Ability to monitor waits when configured to "allow 1 simultaneous execution"
    Broadcom Employee
    Posted Jan 17, 2025 02:24 AM
    Hi Doug,
    you should be able to query the EH_status field in the EH table for
    1697 Waiting for SYNC
    1709 Waiting for end of parallel task
    Regards, Markus
  • 3.  RE: Ability to monitor waits when configured to "allow 1 simultaneous execution"
    Posted Jan 17, 2025 05:36 AM
    Hi Doug,
    Markus has already answered the "what". The "how" should be a DB query. Everything triggered in the system (regardless if from within our from the outsdie) would create too much traffic and system load.
    So the best way might be putting selected records from EH into some sort of data mart. This stresses the system less and allows also the building of a history.
    Regards,
    Jürgen
    Juergen Lechner
    Managing Consultant
    setis GmbH
    Germany
