Hello,
I am running Windows 11 on a MacBook M1 with VMware Fusion.
It installs nicely and does everything else I need it to except for the two issues below.
The VMware Tools are installed.
I usually update everything in my computers.
First Issue:
When opening Device Manager, under the Other Devices category, I have the following two items with a yellow triangle next to it as shown in the attached picture (named Unrecognized USB Controller): Base System Device and Universal Serial Bus (USB) Controller.
What do I do about this? I think, because of this I have the second issue below.
Second Issue:
On top of the First Issue...
I have a TM4C123GXL microcontroller (MCU) and a program (Keil, which installs fine) that I need to use on a Windows (and known to work in VMware for Macs as stated by the instructor's directions) to connect to my MacBook laptop for my class so that I can study while I'm at school instead of home at my Windows 11 desktop computer.
When opening Device Manager, under the Other Devices category, I have two items of the same name with a yellow triangle next to it as shown in the attached picture (named Two Unrecognized ICDI): In-Circuit Debug Interface and In-Circuit Debug Interface. This is supposed to be normal as pointed out by the instructions for my class. We're supposed to download some drivers from the manufacturer's website at TI.com. Then, when going to Device Manager and updating the two In-Circuit Debug Interface (ICDI) drivers that have the yellow triangles next to it, we're supposed to point the folder with the downloaded drivers in the Browse My Computer for Drivers option. This would install the Stellaris drivers for my MCU so the Keil program could run it with JTAG or something. In my Windows 11 desktop computer, this works fine and dandy with the same device and cable and everything. However, in my MacBook M1 laptop, it does not work. It shows that it was not able to install, as shown in the attached picture (named Unable to Install). I am using a data cable that came with the microcontroller and it is the same one I used for both computers
Things I have done to try and fix this as pointed out by the internet but to no avail:
1) Reinstalling and repairing VMware Tools.
2) Uninstalling VMware Tools, restarting, installing VMware Tools again, and restarting. I've tried typical and complete install and used the latest download from Broadcom's portal as well.
3) Editing the ".vmx" file's "ehci.present = "TRUE"" to FALSE as well as other lines. However, when I get to my login screen, the screen is frozen and I can't use any inputs. The only way to get out of there would be to shutdown the VM using the VM menu and reverting the file.
4) I went to the Virtual Machine menu to go to Settings. In the Removable Devices category for USB, there is an item called "Luminary Micro In_Circuit Debug Interface" which is supposed to be my Stellaris ICDI for my MCU. I go down to the Advanced USB options to try USB Compatibility for USB 1.1 and USB 2.0, but the VM freezes at the login screen like in step 3 above until I put the USB 3.1 option back up.
5) In the Virtual Machine menu to go to Settings, under the Other category for Compatibility, I looked under the Advanced options drop down for Use Hardware Version to make sure that it is version 21. Some people said that this needed to be 21, and it already was.
Researching, trying all of this out, and more took dozens of hours...
I would appreciate some help so I can make my life easier and study on-the-go like at school.
6) Setting the Virtual Machine > Settings > USB > ICDI Plug In Action to Connect to Windows. However, this always revers back to the "Use default action".
7) In the Mac's System Settings > Privacy & Security > Files & Folders, VMware Fusion does have permission to access Removable Volumes I suppose noted by the "Full Disk Access".
