VMware Workstation
 Please help; unable to load vmmon and vmnet modules
James Woodworth's profile image
James Woodworth posted Oct 15, 2024 09:06 PM
Hi All,
I am running Alma Linux 9.4
Linux localhost.localdomain 5.14.0-427.37.1.el9_4.x86_64 #1 SMP PREEMPT_DYNAMIC Tue Sep 24 17:44:03 EDT 2024 x86_64 x86_64 x86_64 GNU/Linux
I have been trying various iterations and incantations to make loading vmmon and vmnet work to no avail.  Have tried building from source, rpms, and downloading from the website.
Something of note is that in order to make the compile work, I have to resort to these directions:
Navigate to the modules path for VMWare Linux
cd /usr/lib/vmware/modules/source
Copy the original build as backup tarballs
sudo cp vmnet.tar vmnet.tar.original && sudo cp vmmon.tar vmmon.tar.original Open both source code tarballs
sudo tar -xvf vmnet.tar && sudo tar -xvf vmmon.tar Open /usr/lib/vmware/modules/source/vmmon-only/include/pgtbl.h add these changes and save
change pte = pte_offset_map(pmd,addr); to pte = pte_offset_kernel(pmd, addr);
Open /usr/lib/vmware/modules/source/vmnet-only/bridge.c and...
Add these two lines below #include <linux/etherdevice.h>
#include <net/gso.h>
#include <linux/inetdevice.h>
Save, exit, and recompress the tarballs
sudo tar -cf vmnet.tar vmnet-only/ && sudo tar -cf vmmon.tar vmmon-only/ Then run the kernel driver installer/loader
sudo vmware-modconfig --console --install-all
No errors anymore. You can run VMWare again.
journalctl output:
Oct 15 18:36:16 localhost.localdomain vmware[30574]: Starting VMware services:
Oct 15 18:36:16 localhost.localdomain vmware[30574]:    Virtual machine monitor - failed
Oct 15 18:36:16 localhost.localdomain vmware[30574]:    Virtual machine communication interface - done
Oct 15 18:36:16 localhost.localdomain vmware[30574]:    VM communication interface socket family - done
Oct 15 18:36:16 localhost.localdomain vmware[30574]:    Virtual ethernet - failed
Oct 15 18:36:16 localhost.localdomain vmware[30574]:    VMware Authentication Daemon - done
Oct 15 18:36:16 localhost.localdomain systemd[1]: vmware.service: Control process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: https://access.redhat.com/support
░░ An ExecStart= process belonging to unit vmware.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Oct 15 18:36:16 localhost.localdomain systemd[1]: vmware.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit vmware.service has entered the 'failed' state with result 'exit-code'.
Oct 15 18:36:16 localhost.localdomain systemd[1]: Failed to start VMware host virtualization and network services for Workstation.
░░ Subject: A start job for unit vmware.service has failed
░░ A start job for unit vmware.service has finished with a failure.
░░ The job identifier is 6287 and the job result is failed.
I am at wit's end with no ideas of my own left and am a relative novice at low level work in C.  Please let me know if there is more information i can/should provide.
Thanks for any help,
Jim
Dhairya Tomar's profile image
Broadcom Employee Dhairya Tomar
Request you to share the vmware ui log file.
James Woodworth
Hi, log file is below.  Thank you
2024-10-18T06:45:23.001Z In(05) vmui Log for VMware Workstation pid=9651 version=17.6.1 build=build-24319023 option=Release
2024-10-18T06:45:23.001Z In(05) vmui The host is x86_64.
2024-10-18T06:45:23.001Z In(05) vmui Host codepage=UTF-8 encoding=UTF-8
2024-10-18T06:45:23.001Z In(05) vmui Host is Linux 5.14.0-427.37.1.el9_4.x86_64 AlmaLinux 9.4 (Seafoam Ocelot) 9.4 AlmaLinux 9.4 (Seafoam Ocelot) cpe:/o:almalinux:almalinux:9::baseos
2024-10-18T06:45:23.001Z In(05) vmui Host offset from UTC is -04:00.
2024-10-18T06:45:22.999Z In(05) host-9651 Using GTK 3.24.31
2024-10-18T06:45:23.000Z In(05) host-9651 UTIL: Change file descriptor limit from soft 1024,hard 524288 to soft 16384,hard 524288.
2024-10-18T06:45:23.000Z In(05) vmui VTHREAD 139985010236544 "vmui" tid 9651
2024-10-18T06:45:23.000Z In(05) vmui DictionaryLoad: Cannot open file "/usr/lib/vmware/settings": No such file or directory.
2024-10-18T06:45:23.000Z In(05) vmui [msg.dictionary.load.openFailed] Cannot open file "/usr/lib/vmware/settings": No such file or directory.
2024-10-18T06:45:23.000Z In(05) vmui PREF Optional preferences file not found at /usr/lib/vmware/settings. Using default values.
2024-10-18T06:45:23.000Z In(05) vmui DictionaryLoad: Cannot open file "/home/jim/.vmware/config": No such file or directory.
2024-10-18T06:45:23.000Z In(05) vmui [msg.dictionary.load.openFailed] Cannot open file "/home/jim/.vmware/config": No such file or directory.
2024-10-18T06:45:23.000Z In(05) vmui PREF Optional preferences file not found at /home/jim/.vmware/config. Using default values.
2024-10-18T06:45:23.001Z Wa(03) vmui PID: 9651, log output: /tmp/vmware-jim/vmware-ui-9651.log
2024-10-18T06:45:23.001Z In(05) vmui Found Preference Settings:
2024-10-18T06:45:23.001Z In(05) vmui DICT --- GLOBAL SETTINGS /usr/lib/vmware/settings
2024-10-18T06:45:23.001Z In(05) vmui DICT --- NON PERSISTENT (null)
2024-10-18T06:45:23.001Z In(05) vmui DICT --- USER PREFERENCES /home/jim/.vmware/preferences
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.autoSoftwareUpdatePermission.epoch = "2465267159"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.autoSoftwareUpdatePermission = "allow"
2024-10-18T06:45:23.001Z In(05) vmui DICT   pref.lastUpdateCheckSec = "1729232248"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.keyboardAndMouse.vmHotKey.enabled = "FALSE"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.keyboardAndMouse.vmHotKey.count = "0"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.vmplayer.firstRunDismissedVersion = "17.6.1"
2024-10-18T06:45:23.001Z In(05) vmui DICT         vmWizard.guestKey = "almalinux-64"
2024-10-18T06:45:23.001Z In(05) vmui DICT vmWizard.installMediaType = "iso"
2024-10-18T06:45:23.001Z In(05) vmui DICT vmWizard.isoLocationMRU.count = "1"
2024-10-18T06:45:23.001Z In(05) vmui DICT vmWizard.isoLocationMRU0.location = "/home/jim/Downloads/AlmaLinux-8.10-x86_64-dvd.iso"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.wspro.firstRunDismissedVersion = "17.6.1"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window.count = "1"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.tab.count = "2"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.tab0.dest = ""
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.tab0.file = "home"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.tab0.type = "home"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.tab0.cnxType = "vmdb"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.tab0.focused = "FALSE"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.tab1.dest = ""
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.tab1.file = "folder:localhost"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.tab1.type = "folder"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.tab1.cnxType = "vmdb"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.tab1.focused = "TRUE"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.sidebar = "TRUE"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.sidebar.width = "215"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.statusBar = "TRUE"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.tabs = "TRUE"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.thumbnailBar = "FALSE"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.thumbnailBar.size = "125"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.thumbnailBar.view = "same-folder"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.placement.left = "90"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.placement.top = "124"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.placement.right = "1114"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.placement.bottom = "892"
2024-10-18T06:45:23.001Z In(05) vmui DICT pref.ws.session.window0.maximized = "FALSE"
2024-10-18T06:45:23.001Z In(05) vmui DICT --- USER DEFAULTS /home/jim/.vmware/config
2024-10-18T06:45:23.001Z In(05) vmui DICT --- HOST DEFAULTS /etc/vmware/config
2024-10-18T06:45:23.001Z In(05) vmui DICT                    libdir = "/usr/lib/vmware"
2024-10-18T06:45:23.001Z In(05) vmui DICT                    bindir = "/usr/bin"
2024-10-18T06:45:23.001Z In(05) vmui DICT             initscriptdir = "/etc/rc.d/init.d"
2024-10-18T06:45:23.001Z In(05) vmui DICT           gksu.rootMethod = "sudo"
2024-10-18T06:45:23.001Z In(05) vmui DICT                NETWORKING = "yes"
2024-10-18T06:45:23.001Z In(05) vmui DICT            authd.fullpath = "/usr/sbin/vmware-authd"
2024-10-18T06:45:23.001Z In(05) vmui DICT       product.buildNumber = "24319023"
2024-10-18T06:45:23.001Z In(05) vmui DICT    player.product.version = "17.6.1"
2024-10-18T06:45:23.001Z In(05) vmui DICT        vix.config.version = "1"
2024-10-18T06:45:23.001Z In(05) vmui DICT             telemetryUUID = "7ee43534-8d1c-11ef-a0c7-10683824b903"
2024-10-18T06:45:23.001Z In(05) vmui DICT installerDefaults.autoSoftwareUpdateEnabled = "none"
2024-10-18T06:45:23.001Z In(05) vmui DICT installerDefaults.autoSoftwareUpdateEnabled.epoch = "1536244204"
2024-10-18T06:45:23.001Z In(05) vmui DICT installerDefaults.dataCollectionEnabled = "yes"
2024-10-18T06:45:23.001Z In(05) vmui DICT installerDefaults.dataCollectionEnabled.epoch = "9162694474"
2024-10-18T06:45:23.001Z In(05) vmui DICT installerDefaults.dataCollectionEnabled.initialized = "none"
2024-10-18T06:45:23.001Z In(05) vmui DICT installerDefaults.componentDownloadEnabled = "yes"
2024-10-18T06:45:23.001Z In(05) vmui DICT installerDefaults.transferVersion = "1"
2024-10-18T06:45:23.001Z In(05) vmui DICT             acceptOVFEULA = "none"
2024-10-18T06:45:23.001Z In(05) vmui DICT           vmware.fullpath = "/usr/bin/vmware"
2024-10-18T06:45:23.001Z In(05) vmui DICT                vix.libdir = "/usr/lib/vmware-vix"
2024-10-18T06:45:23.001Z In(05) vmui DICT           product.version = "17.6.1"
2024-10-18T06:45:23.001Z In(05) vmui DICT workstation.product.version = "17.6.1"
2024-10-18T06:45:23.001Z In(05) vmui DICT              product.name = "VMware Workstation"
2024-10-18T06:45:23.001Z In(05) vmui DICT                acceptEULA = "none"
2024-10-18T06:45:23.001Z In(05) vmui DICT --- SITE DEFAULTS /usr/lib/vmware/config
2024-10-18T06:45:23.001Z In(05) vmui DICT                  tag.help = "introduction.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT   tag.configurationEditor = "config_editor_newvm.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT             tag.ideConfig = "devices_virtualdrive.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT          tag.floppyConfig = "devices_floppy.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT           tag.mouseConfig = "devices_mouse.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT             tag.netConfig = "devices_netadapter.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT        tag.parallelConfig = "devices_parallel.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT          tag.serialConfig = "devices_serial.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT           tag.soundConfig = "devices_sound.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT             tag.memConfig = "configvm_memory.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT            tag.miscConfig = "configvm.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT             tag.usbConfig = "devices_usb.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT         tag.displayConfig = "configvm_display-problems.htm"
2024-10-18T06:45:23.001Z In(05) vmui DICT                 tag.tools = "vmtools.htm"
2024-10-18T06:45:23.001Z In(05) vmui OBJLIB-LIB: Objlib initialized.
2024-10-18T06:45:23.002Z In(05) vmui lib/ssl: OpenSSL using default provider
2024-10-18T06:45:23.002Z In(05) vmui lib/ssl: Client usage
2024-10-18T06:45:23.002Z In(05) vmui lib/ssl: protocol list tls1.2
2024-10-18T06:45:23.002Z In(05) vmui lib/ssl: protocol min 0x303 max 0x303
2024-10-18T06:45:23.002Z In(05) vmui lib/ssl: protocol list tls1.2 (openssl flags 0x36000000)
2024-10-18T06:45:23.002Z In(05) vmui lib/ssl: cipher list ECDHE+AESGCM:RSA+AESGCM:ECDHE+AES:RSA+AES
2024-10-18T06:45:23.002Z In(05) vmui lib/ssl: cipher suites TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384
2024-10-18T06:45:23.002Z In(05) vmui lib/ssl: curves list prime256v1:secp384r1:secp521r1
2024-10-18T06:45:23.002Z In(05) vmui lib/ssl: Server usage
2024-10-18T06:45:23.070Z No(04) vmui gVmomi: gvmomi_init: success.
2024-10-18T06:45:23.085Z In(05) vmui GLib-GIO: _g_io_module_get_default: Found default implementation gvfs (GDaemonVfs) for ‘gio-vfs’
2024-10-18T06:45:23.106Z In(05) vmui WQPoolAllocPoll : pollIx = 1, signalHandle = 23
2024-10-18T06:45:23.106Z In(05) vmui HALLoadLibrary: Could not dlopen libhal.so.1: libhal.so.1: cannot open shared object file: No such file or directory.
2024-10-18T06:45:23.106Z In(05) vmui HALLoadLibrary: Could not dlopen libhal.so.0: libhal.so.0: cannot open shared object file: No such file or directory.
2024-10-18T06:45:23.122Z In(05) vmui UUID: Unable to open /sys/firmware/dmi/entries/1-0/raw: Permission denied
2024-10-18T06:45:23.122Z In(05) vmui UUID: Unable to open /sys/firmware/dmi/tables/DMI: Permission denied
2024-10-18T06:45:23.122Z In(05) vmui UUID: Unable to open /sys/firmware/efi/systab: Permission denied
2024-10-18T06:45:23.122Z In(05) vmui UUID: Unable to open /dev/mem: Permission denied
2024-10-18T06:45:23.122Z In(05) vmui UUIDHostSearch: UUID could not be located.
2024-10-18T06:45:23.122Z In(05) vmui UUID: Invalid gethostid routine. Value = 7F0100.
2024-10-18T06:45:23.122Z In(05) vmui vmxFilePath="/usr/lib/vmware/bin/vmware-vmx"
2024-10-18T06:45:23.122Z In(05) vmui vmxFilePathDebug="/usr/lib/vmware/bin/vmware-vmx-debug"
2024-10-18T06:45:23.122Z In(05) vmui vmxFilePathStats="/usr/lib/vmware/bin/vmware-vmx-stats"
2024-10-18T06:45:23.123Z In(05) vmui HostDeviceInfo_FindHostCDROMs: enumerating IDE CDROMs
2024-10-18T06:45:23.123Z In(05) vmui HostDeviceInfoFindHostIDECDROMs: /proc/ide could not be explored. Unable to enumerate host IDE cdroms.
2024-10-18T06:45:23.123Z In(05) vmui HostDeviceInfo_FindHostCDROMs: IDE CDROM enumerating completed
2024-10-18T06:45:23.123Z In(05) vmui HostDeviceInfo_FindHostCDROMs: enumerating SCSI CDROMs
2024-10-18T06:45:23.123Z In(05) vmui HostDeviceInfoCheckDevCDROM: can't stat /dev/cdrom: No such file or directory
2024-10-18T06:45:23.123Z In(05) vmui HostDeviceInfo_FindHostCDROMs: SCSI CDROM enumerating completed
2024-10-18T06:45:23.123Z In(05) vmui HostDeviceInfo_FindHostCDROMs: enumerating CDROMs in VSI
2024-10-18T06:45:23.123Z In(05) vmui HostDeviceInfo_FindHostCDROMs: VSI CDROM enumerating completed
2024-10-18T06:45:23.128Z In(05) vmui SMBIOS: can't open /dev/mem: Insufficient permission to access the file
2024-10-18T06:45:23.128Z In(05) vmui VmhsHostInfoPopulateSystem:  Could not get information from smbios to populate VMDB.
2024-10-18T06:45:23.227Z In(05) vmui ReadProxyFile: Failed to read file: /etc/vmware/hostd/proxy.xml
2024-10-18T06:45:23.227Z In(05) CnxFSVigor VTHREAD 139984526898752 "CnxFSVigor" tid 9675
2024-10-18T06:45:23.228Z In(05) vthread-9676 VTHREAD 139984508024384 "vthread-9676" tid 9676
2024-10-18T06:45:23.228Z In(05) vmui USBArbLib: USBArbLib initialized successfully, retryIntervalStart(5), retryIntervalMax(120), arbSocketName(/var/run/vmware/usbarbitrator-socket), useLocking(no), tryUpgrading(no).
2024-10-18T06:45:23.228Z In(05) vmui UsbEnum: Initializing UsbEnum library, disableLocking(yes), allowBootableHid(yes).
2024-10-18T06:45:23.228Z In(05) vmui SOCKET creating new socket, connecting to /var/run/vmware/usbarbitrator-socket
2024-10-18T06:45:23.228Z In(05) vmui REM-USB: Protocol version min:15 current:19. hostId:52 23 48 f6 96 a8 9e d6-46 45 da 90 18 43 78 91
2024-10-18T06:45:23.228Z In(05) vmui REM-USB: Initializing 'Generic' backend
2024-10-18T06:45:23.228Z Wa(03) vmui USBArbLib: OUT SET_AUTO_CONNECT: Not connected to arbitrator, autoconnect(0) for client 'VMPlayer', connectState(1).
2024-10-18T06:45:23.228Z In(05) vmui REM-USB: Initializing 'Virtual CCID' backend
2024-10-18T06:45:23.229Z In(05) vmui USB-CCID:  dlopened default libpcsclite.so.1.
2024-10-18T06:45:23.229Z In(05) vmui USB-CCID: Could not establish context: SCARD_E_NO_SERVICE(0x8010001d).
2024-10-18T06:45:23.229Z Wa(03) vmui Could not initialize emulated USB smart card subsystem.
2024-10-18T06:45:23.229Z In(05) vmui REM-USB: Unable to initialize 'Virtual CCID' backend
2024-10-18T06:45:23.233Z In(05) vmui DictionaryLoad: Cannot open file "/home/jim/.vmware/preferences-private": No such file or directory.
2024-10-18T06:45:23.233Z In(05) vmui NewComponentMgr: 17.6.1(24319023)
2024-10-18T06:45:23.233Z In(05) vmui CDS: Initializing a CDS updater client 1.0 for product ws-linux, version 17.6.1.24319023 (workspace /home/jim/.cache/vmware/cds)
2024-10-18T06:45:23.322Z In(05) vmui LOCALE en_US.UTF-8 -> NULL
2024-10-18T06:45:23.322Z In(05) vmui CDS: No cached version for vmware-player
2024-10-18T06:45:23.322Z In(05) vmui RefreshComponentListWithDefaults: CDS_UNKNOWN_PRODUCT_ERROR for product player-windows
2024-10-18T06:45:23.322Z Er(02) vmui CDS error: No install keys defined for tools-arm64-windows
2024-10-18T06:45:23.322Z In(05) vmui RefreshComponentListWithDefaults: CDS_UNKNOWN_PRODUCT_ERROR for product tools-arm64-windows
2024-10-18T06:45:23.322Z In(05) vmui CDS: Found cached version 12.4.5 build 24319023 for vmware-tools-windows
2024-10-18T06:45:23.322Z In(05) vmui CDS: Found cached version 12.4.5 build 24319023 for vmware-tools-windows-x86
2024-10-18T06:45:23.322Z In(05) vmui CDS: Found cached version 17.6.1 build 24319023 for vmware-workstation
2024-10-18T06:45:23.322Z In(05) vmui RefreshComponentListWithDefaults: CDS_UNKNOWN_PRODUCT_ERROR for product ws-windows
2024-10-18T06:45:23.323Z In(05) vmui Phone Home: PhoneHome_CreateClient: Creating client for host https://vcsa.vmware.com/ph, collector workstation.17_0, instance 522348f6-96a8-9ed6-4645-da9018437891.
2024-10-18T06:45:23.323Z In(05) vmui Phone Home: PhoneHome_CreateClient: Will send phone home requests to "https://vcsa.vmware.com/ph/api/hyper/send?_c=workstation.17_0&_i=522348f6-96a8-9ed6-4645-da9018437891".
2024-10-18T06:45:23.323Z In(05) vmui Foundry Init: setting up global state (1 poll threads, 0 worker threads).
2024-10-18T06:45:23.323Z In(05) vmui Vix_InitializeGlobalState: vixLogLevel = 0
2024-10-18T06:45:23.323Z In(05) vmui Vix_InitializeGlobalState: vixApiTraceLevel = 0
2024-10-18T06:45:23.323Z In(05) vmui Vix_InitializeGlobalState: vixDebugPanicOnVixAssert = 0
2024-10-18T06:45:23.323Z In(05) vmui Vix_InitializeGlobalState: vixLogRefcountOnFinalRelease = 0
2024-10-18T06:45:23.323Z In(05) vmui Vix_InitializeGlobalState: asyncOpWarningThreshold = 1000000
2024-10-18T06:45:23.323Z In(05) vmui Vix_InitializeGlobalState: enableSyncOpSelection = FALSE
2024-10-18T06:45:23.323Z In(05) vmui Vix_InitializeGlobalState: enableExternalThreadInterface = TRUE
2024-10-18T06:45:23.323Z In(05) vmui Vix_InitializeGlobalState: enableVigor = FALSE
2024-10-18T06:45:23.323Z In(05) vmui LOCALE en_US.UTF-8 -> NULL
2024-10-18T06:45:23.323Z In(05) vmui VixHost_ConnectEx: version -1, hostType 3, hostName (null), hostPort 0, options 8707
2024-10-18T06:45:23.360Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:23.360Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:23.360Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:23.360Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:23.360Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:23.363Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:23.363Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:23.363Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:23.363Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:23.363Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:23.365Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:23.365Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:23.365Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:23.365Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:23.365Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:23.367Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:23.367Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:23.367Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:23.367Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:23.367Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:23.396Z In(05) vmui Printing loaded objects
2024-10-18T06:45:23.396Z In(05) vmui [0x55737204C000-0x557372062478): /usr/lib/vmware/bin/vmware
2024-10-18T06:45:23.396Z In(05) vmui [0x7FFD87180000-0x7FFD8718107D): linux-vdso.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCD1A000-0x7F50CCD1A820): /lib64/librt.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCD13000-0x7F50CCD13690): /lib64/libdl.so.2
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCCF8000-0x7F50CCCFA978): /lib64/libgcc_s.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCCF3000-0x7F50CCCF3AC0): /lib64/libpthread.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCA00000-0x7F50CCA27ED8): /lib64/libc.so.6
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCD35000-0x7F50CCD36B50): /lib64/ld-linux-x86-64.so.2
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC600000-0x7F50CC788DD8): /usr/lib/vmware/lib/libvmware.so/libvmware.so
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC4C5000-0x7F50CC4E1510): /lib64/libglib-2.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCC96000-0x7F50CCCA33E0): /lib64/libgobject-2.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC200000-0x7F50CC26B342): /usr/lib/vmware/lib/libglibmm-2.4.so.1/libglibmm-2.4.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CBE00000-0x7F50CBE0436D): /usr/lib/vmware/lib/libsigc-2.0.so.0/libsigc-2.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCC6D000-0x7F50CCC76FF0): /lib64/libatk-1.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CBA00000-0x7F50CBA4329C): /usr/lib/vmware/lib/libatkmm-1.6.so.1/libatkmm-1.6.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CB600000-0x7F50CB6215F9): /usr/lib/vmware/lib/libcairomm-1.0.so.1/libcairomm-1.0.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CAC00000-0x7F50CAC85EE8): /lib64/libgtk-3.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC108000-0x7F50CC130990): /lib64/libgdk-3.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CA800000-0x7F50CA83CEBC): /usr/lib/vmware/lib/libgdkmm-3.0.so.1/libgdkmm-3.0.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CA000000-0x7F50CA4060B4): /usr/lib/vmware/lib/libgtkmm-3.0.so.1/libgtkmm-3.0.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C9C00000-0x7F50C9C278A6): /usr/lib/vmware/lib/libpangomm-1.4.so.1/libpangomm-1.4.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CBCB8000-0x7F50CBCD3640): /lib64/libX11.so.6
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCC68000-0x7F50CCC68A50): /lib64/libXinerama.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCC5B000-0x7F50CCC5D530): /usr/lib/vmware/lib/libbasichttp.so/libbasichttp.so
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C9400000-0x7F50C94BAA50): /usr/lib/vmware/lib/libgvmomi.so/libgvmomi.so
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C8A00000-0x7F50C8B13568): /usr/lib/vmware/lib/libvmwarebase.so/libvmwarebase.so
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C6A00000-0x7F50C7442230): /usr/lib/vmware/lib/libvmwareui.so/libvmwareui.so
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C6600000-0x7F50C6698CA8): /lib64/libstdc++.so.6
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC02D000-0x7F50CC039360): /lib64/libm.so.6
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CB988000-0x7F50CB989420): /lib64/libpcre.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCC4F000-0x7F50CCC50948): /lib64/libffi.so.8
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCC49000-0x7F50CCC49EE0): /lib64/libgmodule-2.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CB8C4000-0x7F50CB8D0CE8): /lib64/libfreetype.so.6
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCC12000-0x7F50CCC16D88): /lib64/libpng16.so.16
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC9E6000-0x7F50CC9E81D8): /lib64/libz.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC9D9000-0x7F50CC9DA880): /lib64/libXrender.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CB4E6000-0x7F50CB4F6D60): /lib64/libcairo.so.2
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC9C4000-0x7F50CC9C7388): /lib64/libXext.so.6
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C6829000-0x7F50C6860218): /lib64/libgio-2.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC4B3000-0x7F50CC4B7240): /lib64/libpangocairo-1.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CBC64000-0x7F50CBC720B0): /lib64/libpango-1.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CB417000-0x7F50CB41FF18): /lib64/libharfbuzz.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC499000-0x7F50CC49FAB8): /lib64/libpangoft2-1.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CB875000-0x7F50CB87BB50): /lib64/libfontconfig.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC47B000-0x7F50CC47C2E0): /lib64/libfribidi.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC021000-0x7F50CC024428): /lib64/libcairo-gobject.so.2
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CB845000-0x7F50CB84C220): /lib64/libgdk_pixbuf-2.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CAACB000-0x7F50CAB2A090): /lib64/libepoxy.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC00F000-0x7F50CC010F80): /lib64/libXi.so.6
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CAA92000-0x7F50CAA9DA38): /lib64/libatk-bridge-2.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CA739000-0x7F50CA750DD8): /lib64/libtracker-sparql-3.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CBC52000-0x7F50CBC57090): /lib64/libwayland-client.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CCC09000-0x7F50CCC0A3E8): /lib64/libXfixes.so.3
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CAA4D000-0x7F50CAA51258): /lib64/libxkbcommon.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC471000-0x7F50CC472130): /lib64/libwayland-cursor.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CC00A000-0x7F50CC00A648): /lib64/libwayland-egl.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CB838000-0x7F50CB83A3A0): /lib64/libXcursor.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CBC4D000-0x7F50CBC4DAA0): /lib64/libXdamage.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CB833000-0x7F50CB833B40): /lib64/libXcomposite.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CB826000-0x7F50CB827AD0): /lib64/libXrandr.so.2
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C6200000-0x7F50C6365AD4): /usr/lib/vmware/lib/libgiomm-2.4.so.1/libgiomm-2.4.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CA70E000-0x7F50CA7193C0): /lib64/libxcb.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C5E00000-0x7F50C5E9932C): /usr/lib/vmware/lib/libcurl.so.4/libcurl.so.4
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C9E77000-0x7F50C9EA5980): /lib64/libxml2.so.2
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C5A00000-0x7F50C5A9C1CC): /usr/lib/vmware/lib/libssl.so.3/libssl.so.3
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C5200000-0x7F50C5633838): /usr/lib/vmware/lib/libcrypto.so.3/libcrypto.so.3
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C4E00000-0x7F50C4E31A1C): /usr/lib/vmware/lib/libcds.so/libcds.so
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C9B95000-0x7F50C9BB10F8): /lib64/libgcr-ui-3.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C9361000-0x7F50C9383160): /lib64/libgcr-base-3.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CAA47000-0x7F50CAA47C90): /lib64/libXau.so.6
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CA6C1000-0x7F50CA6CE5E8): /lib64/libsecret-1.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C9E64000-0x7F50C9E65468): /lib64/libbz2.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C9E56000-0x7F50C9E56B78): /lib64/libbrotlidec.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C8954000-0x7F50C895E110): /lib64/libpixman-1.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50CAA42000-0x7F50CAA42D20): /lib64/libxcb-shm.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C9E46000-0x7F50C9E4AEB0): /lib64/libxcb-render.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C9B4E000-0x7F50C9B571F0): /lib64/libmount.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C8927000-0x7F50C892CE98): /lib64/libselinux.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C9E3B000-0x7F50C9E3CD38): /lib64/libthai.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C9340000-0x7F50C9342388): /lib64/libgraphite2.so.3
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C88A6000-0x7F50C88A9978): /lib64/libjpeg.so.62
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C65AD000-0x7F50C65B9D50): /lib64/libdbus-1.so.3
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C8869000-0x7F50C8878B58): /lib64/libatspi.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C61AB000-0x7F50C61C49E8): /lib64/libstemmer.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C6580000-0x7F50C65882A0): /lib64/libjson-glib-1.0.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C4C15000-0x7F50C4C76AC0): /lib64/libicuuc.so.67
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C4800000-0x7F50C48DDC40): /lib64/libicui18n.so.67
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C5CC8000-0x7F50C5CD62E8): /lib64/libsqlite3.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C617F000-0x7F50C6181C60): /lib64/liblzma.so.5
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C6148000-0x7F50C6150F18): /lib64/libgck-1.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C5069000-0x7F50C509DE10): /lib64/libp11-kit.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C58C7000-0x7F50C58D4DA0): /lib64/libgcrypt.so.20
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C6122000-0x7F50C6125C08): /lib64/libgpg-error.so.0
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C60FF000-0x7F50C60FF780): /lib64/libbrotlicommon.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C60C7000-0x7F50C60CDFF8): /lib64/libblkid.so.1
2024-10-18T06:45:23.396Z In(05) vmui [0x7F50C4B79000-0x7F50C4B7AF58): /lib64/libpcre2-8.so.0
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C9E32000-0x7F50C9E33238): /lib64/libdatrie.so.1
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C4723000-0x7F50C4738B68): /lib64/libsystemd.so.0
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C2C00000-0x7F50C2C004A8): /lib64/libicudata.so.67
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C9B44000-0x7F50C9B45F28): /lib64/libcap.so.2
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C2B29000-0x7F50C2B2DF58): /lib64/libzstd.so.1
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C60A3000-0x7F50C60A58A8): /lib64/liblz4.so.1
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C9B3E000-0x7F50C9B3E788): /usr/lib64/gconv/UTF-16.so
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C4B44000-0x7F50C4B4DDC8): /usr/lib64/gio/modules/libgvfsdbus.so
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C28E5000-0x7F50C28F7430): /usr/lib64/gvfs/libgvfscommon.so
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50CCD2A000-0x7F50CCD2BC90): /usr/lib64/gtk-3.0/modules/libcanberra-gtk-module.so
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50CCD23000-0x7F50CCD24920): /lib64/libcanberra-gtk3.so.0
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C9B39000-0x7F50C9B395C0): /lib64/libgthread-2.0.so.0
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C4B2F000-0x7F50C4B31A20): /lib64/libcanberra.so.0
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C9B2E000-0x7F50C9B2FB58): /lib64/libvorbisfile.so.3
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C4B15000-0x7F50C4B181C8): /lib64/libtdb.so.1
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C885D000-0x7F50C885EF48): /lib64/libltdl.so.7
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C2876000-0x7F50C2878FE8): /lib64/libvorbis.so.0
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C589A000-0x7F50C589B7B8): /lib64/libogg.so.0
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C5CC1000-0x7F50C5CC24B0): /usr/lib64/gtk-3.0/modules/libpk-gtk-module.so
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50C4B08000-0x7F50C4B08AE8): /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so
2024-10-18T06:45:23.397Z In(05) vmui [0x7F50ADC00000-0x7F50ADD14978): /lib64/librsvg-2.so.2
2024-10-18T06:45:23.397Z In(05) vmui End printing loaded objects
2024-10-18T06:45:23.423Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:23.423Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:23.423Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:23.423Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:23.423Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:23.426Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:23.426Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:23.426Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:23.426Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:23.426Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:23.428Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:23.428Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:23.428Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:23.428Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:23.428Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:23.431Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:23.431Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:23.431Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:23.431Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:23.431Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:23.457Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:23.457Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:23.457Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:23.457Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:23.457Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:23.463Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:23.463Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:23.463Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:23.463Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:23.463Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:23.466Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:23.466Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:23.466Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:23.466Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:23.466Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:23.470Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:23.470Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:23.470Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:23.470Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:23.470Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:24.479Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:24.479Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:24.479Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:24.479Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:24.479Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:24.561Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:24.561Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:24.561Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:24.561Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:24.561Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:25.013Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:25.013Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:25.013Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:25.013Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:25.013Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:26.244Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:26.244Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:26.244Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:26.244Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:26.244Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:26.761Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:26.762Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:26.762Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:26.762Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:26.762Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:28.788Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:28.788Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:28.788Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:28.788Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:28.788Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:28.971Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:28.971Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:28.971Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:28.971Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:28.971Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:28.978Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:28.978Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:28.978Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:28.978Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:28.978Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:28.979Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:28.979Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:28.979Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:28.979Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:28.979Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:28.981Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:28.981Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:28.981Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:28.981Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:28.981Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:30.662Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:30.662Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:30.662Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:30.662Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:30.662Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:30.961Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:30.961Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:30.961Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:30.961Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:30.961Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:31.926Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:31.926Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:31.926Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:31.926Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:31.926Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:32.513Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:32.513Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:32.513Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:32.513Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:32.513Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:33.897Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:33.897Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:33.897Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:33.897Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:33.897Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:34.081Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:34.081Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:34.081Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:34.081Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:34.081Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:34.085Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:34.085Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:34.085Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:34.085Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:34.085Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:34.086Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:34.086Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:34.086Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:34.086Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:34.086Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:34.088Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:34.088Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:34.088Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:34.088Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:34.088Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:39.317Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:39.317Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:39.317Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:39.317Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:39.317Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:39.320Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:39.320Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:39.320Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:39.320Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:39.320Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:39.321Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:39.321Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:39.321Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:39.321Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:39.321Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:45:39.323Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:45:39.323Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:45:39.323Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:45:39.323Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:45:39.323Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:00.402Z In(05) vmui OnHostTopologyChanged, found host monitor 0: 1920x1080 @ 0,0 (scale: 1)
2024-10-18T06:46:00.402Z In(05) vmui OnHostTopologyChanged, I'm now on monitor 0: 1920x1080 @ 0,0
2024-10-18T06:46:00.403Z In(05) vmui OnWindowManagerChanged: found Window Manager: GNOME Shell, with fullscreen capability: 2
2024-10-18T06:46:00.451Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:00.451Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:00.451Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:00.451Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:00.451Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:00.484Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:00.484Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:00.484Z In(05) vmui GdkPixbuf:     Dimensions: 20 x 25
2024-10-18T06:46:00.484Z In(05) vmui GdkPixbuf:     Rowstride: 80, Length: 2024
2024-10-18T06:46:00.484Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:31.362Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:31.362Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:31.362Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:31.362Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:31.362Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:31.363Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:31.363Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:31.363Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:31.363Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:31.363Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:31.369Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:31.369Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:31.369Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:31.369Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:31.369Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.323Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.323Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.323Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.323Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.323Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.325Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.325Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.325Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.325Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.325Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.326Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.326Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.326Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.326Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.326Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.328Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.328Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.328Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.328Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.328Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.331Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.331Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.331Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.331Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.331Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.334Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.334Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.334Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.334Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.334Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.337Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.337Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.337Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.337Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.337Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.339Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.339Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.339Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.339Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.339Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.342Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.342Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.342Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.342Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.342Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.343Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.343Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.343Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.343Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.343Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.346Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.346Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.346Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.346Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.346Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.347Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.347Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.347Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.347Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.347Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.349Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.349Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.349Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.349Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.349Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.351Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.351Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.351Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.351Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.351Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.426Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.426Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.426Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.426Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.426Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.429Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.429Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.429Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.429Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.429Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.431Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.431Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.431Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.431Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.431Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.432Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.432Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.432Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.432Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.432Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.435Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.435Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.435Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.435Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.435Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.438Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.438Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.438Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.438Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.438Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.442Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.442Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.442Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.442Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.442Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.444Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.444Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.444Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.444Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.444Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.447Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.447Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.447Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.447Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.447Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.448Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.448Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.448Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.448Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.448Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.451Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.451Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.451Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.451Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.451Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.452Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.452Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.452Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.452Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.452Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.454Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.454Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.454Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.454Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.454Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.456Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.456Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.456Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.456Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.456Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.481Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.482Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.482Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.482Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.482Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.512Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.512Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.512Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.512Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.512Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.521Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.521Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.521Z In(05) vmui GdkPixbuf:     Dimensions: 20 x 25
2024-10-18T06:46:39.521Z In(05) vmui GdkPixbuf:     Rowstride: 80, Length: 2024
2024-10-18T06:46:39.521Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.544Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.544Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.544Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.544Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.544Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.560Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.560Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.560Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.560Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.560Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.577Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.577Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.577Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.577Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.577Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.596Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.596Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.596Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.596Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.596Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.611Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.611Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.611Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.611Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.611Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.627Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.627Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.627Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.627Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.627Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.646Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.646Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.646Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.646Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.646Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.661Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.661Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.661Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.661Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.661Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:39.678Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:39.678Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:39.678Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:39.678Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:39.678Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.209Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.209Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.209Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.209Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.209Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.215Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.215Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.215Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.215Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.215Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.219Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.219Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.219Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.219Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.219Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.222Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.222Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.222Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.222Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.222Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.225Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.225Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.225Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.225Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.225Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.230Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.230Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.230Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.230Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.230Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.235Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.235Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.235Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.235Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.235Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.238Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.238Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.238Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.238Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.238Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.240Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.240Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.240Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.240Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.240Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.242Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.242Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.242Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.242Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.242Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.244Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.244Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.244Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.244Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.244Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.246Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.246Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.246Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.246Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.246Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.247Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.247Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.247Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.247Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.247Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:44.249Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:44.249Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:44.249Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:44.249Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:44.249Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.561Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.561Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.561Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.561Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.561Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.563Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.563Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.563Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.563Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.563Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.564Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.564Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.564Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.564Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.564Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.566Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.566Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.566Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.566Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.566Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.568Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.568Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.568Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.568Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.568Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.572Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.572Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.572Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.572Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.572Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.574Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.574Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.574Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.574Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.574Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.576Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.576Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.576Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.576Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.576Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.579Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.579Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.579Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.579Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.579Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.580Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.580Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.580Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.580Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.580Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.583Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.583Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.583Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.583Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.583Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.585Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.585Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.585Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.585Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.585Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.586Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.586Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.586Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.586Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.586Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:46:53.588Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:46:53.588Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:46:53.588Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:46:53.588Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:46:53.588Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.236Z Wa(03) vmui CnxFSVigor: Error to open dir /home/jim/vmware/AlmaLinux 64-bit, No such file or directory
2024-10-18T06:47:14.236Z Wa(03) vmui CnxFSVigor: Failed to get file stat /home/jim/vmware/AlmaLinux 64-bit.
2024-10-18T06:47:14.238Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.238Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.238Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.238Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.238Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.240Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.240Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.240Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.240Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.240Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.242Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.242Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.242Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.242Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.242Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.244Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.244Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.244Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.244Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.244Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.247Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.247Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.247Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.247Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.247Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.250Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.250Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.250Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.250Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.250Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.253Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.253Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.253Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.253Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.253Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.254Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.254Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.254Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.254Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.254Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.257Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.257Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.257Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.257Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.257Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.258Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.258Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.258Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.258Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.258Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.261Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.261Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.261Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.261Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.261Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.263Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.263Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.263Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.263Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.263Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.264Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.264Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.264Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.264Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.264Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:14.266Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:14.266Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:14.266Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:14.266Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:14.266Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.901Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.901Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.901Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.901Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.901Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.904Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.904Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.904Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.904Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.904Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.906Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.906Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.906Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.906Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.906Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.907Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.907Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.907Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.907Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.907Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.909Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.909Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.909Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.909Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.909Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.912Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.912Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.912Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.912Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.912Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.915Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.915Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.915Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.915Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.915Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.918Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.918Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.918Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.918Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.918Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.920Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.920Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.920Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.920Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.920Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.922Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.922Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.922Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.922Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.922Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.923Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.923Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.923Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.923Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.923Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.926Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.926Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.926Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.926Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.926Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.928Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.928Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.928Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.928Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.928Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:24.929Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:24.929Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:24.929Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:24.929Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:24.929Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.376Z Wa(03) vmui CnxFSVigor: Failed to get file stat /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx.
2024-10-18T06:47:33.377Z In(05) vmui VigorOffline_Init: Failed to initialize VIGOR offline: Cannot open file "/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx": No such file or directory.
2024-10-18T06:47:33.377Z In(05)+ vmui
2024-10-18T06:47:33.377Z In(05) vigorCnx VTHREAD 139984480757312 "vigorCnx" tid 9999
2024-10-18T06:47:33.378Z In(05) vmui DictionaryLoad: Cannot open file "/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx": No such file or directory.
2024-10-18T06:47:33.378Z In(05) vmui Locale_Errno2LocalString: "en_US.UTF-8" locale found. LC_ALL=(null), LANG=en_US.UTF-8
2024-10-18T06:47:33.378Z In(05) vmui Locale_Errno2LocalString: locale(LC_ALL)=en_US.UTF-8 locale(LC_MESSAGES)=en_US.UTF-8
2024-10-18T06:47:33.378Z In(05) vmui VmdbVmCfgUpdateFile: Could not load dictionary file /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: Cannot open file "/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx": No such file or directory.
2024-10-18T06:47:33.378Z In(05)+ vmui
2024-10-18T06:47:33.409Z In(05) CnxFSVigor DISKLIB-LIB_CREATE   : DiskLibCreateObjExtParamsInt: CreateObjExtParams: Object backing type 0 is invalid. Figuring out the most suitable backing type...
2024-10-18T06:47:33.411Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.411Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.411Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.411Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.411Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.414Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.414Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.414Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.414Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.414Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.416Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.416Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.416Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.416Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.416Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.416Z In(05) CnxFSVigor DDB: "virtualHWVersion" = "21" (was "14")
2024-10-18T06:47:33.418Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.418Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.418Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.418Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.418Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.421Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.421Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.421Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.421Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.421Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.425Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.425Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.425Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.425Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.425Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.427Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.427Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.427Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.427Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.427Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.429Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.429Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.429Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.429Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.429Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.432Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.432Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.432Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.432Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.432Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.433Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.433Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.433Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.433Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.433Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.437Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.437Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.437Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.437Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.437Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.438Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.438Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.438Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.438Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.438Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.440Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.440Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.440Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.440Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.440Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.442Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.442Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.442Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.442Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.442Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.452Z In(05) vmui VMMgr::OpenVM (cfgPath=/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx)
2024-10-18T06:47:33.467Z In(05) host-10000 /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: Reloading config state.
2024-10-18T06:47:33.472Z In(05) host-10000 SNAPSHOT: SnapshotConfigInfoOpenVmsd: Creating new snapshot dictionary, '/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmsd'.
2024-10-18T06:47:33.473Z In(05) host-10000 VMHS: Transitioned vmx/execState/val to poweredOff
2024-10-18T06:47:33.494Z In(05) vmui VMHS: Transitioned vmx/execState/val to poweredOff
2024-10-18T06:47:33.496Z In(05) vmui /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: Reloading config state.
2024-10-18T06:47:33.499Z In(05) vmui VMHS: Transitioned vmx/execState/val to poweredOff
2024-10-18T06:47:33.503Z In(05) vmui Vix: [foundryVMPowerOps.c:986]: FoundryVMPowerStateChangeCallback: /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx, vmx/execState/val = poweredOff.
2024-10-18T06:47:33.503Z In(05) RemoteDeviceMgr VTHREAD 139984480757312 "RemoteDeviceMgr" tid 10003
2024-10-18T06:47:33.504Z In(05) vigorCnx VTHREAD 139984489150016 "vigorCnx" tid 10004
2024-10-18T06:47:33.505Z In(05) vmui SnapshotTree: Populating (/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx)
2024-10-18T06:47:33.505Z In(05) vmui SnapshotTree: Emitting refresh (/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx)
2024-10-18T06:47:33.513Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.513Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.513Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.513Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.513Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.519Z In(05) vigorCnx VigorOfflineGetToolsVersion: updated tools version to 0
2024-10-18T06:47:33.520Z In(05) vmui ReadProxyFile: Failed to read file: /etc/vmware/hostd/proxy.xml
2024-10-18T06:47:33.527Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.527Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.527Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.527Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.527Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.529Z In(05) vmui VMStatus: Unknown guest os type:
2024-10-18T06:47:33.536Z In(05) vmui SnapshotTree: Emitting refresh (/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx)
2024-10-18T06:47:33.536Z In(05) vmui SnapshotTree: Populating (/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx)
2024-10-18T06:47:33.537Z In(05) vmui MKSControlClientBase: Initialized mksControl client 5573743B4D00.
2024-10-18T06:47:33.537Z In(05) vmui CUIMKS: cui::MKS (557374970820)
2024-10-18T06:47:33.537Z In(05) vmui OnVMStateChanged: alive = 0
2024-10-18T06:47:33.537Z In(05) vmui CUIMKS: cui::MKS::SetAttached (557374970820): detach
2024-10-18T06:47:33.537Z In(05) vmui CUIMKS: cui::MKS::OnSetAttachedCompleted (557374970820)
2024-10-18T06:47:33.537Z In(05) vmui VMMKS: to observe MKS device.
2024-10-18T06:47:33.539Z In(05) vmui VMMKS::OnMKSDeviceInfoChanged: reset pipe name now in offline.
2024-10-18T06:47:33.539Z In(05) vmui VMMKS::OnInitVMDeviceObserverDone: done.
2024-10-18T06:47:33.539Z In(05) vmui VMMgr: Finished opening VM at /vm/#58b714fe069b0ead/ from /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx
2024-10-18T06:47:33.556Z In(05) vmui HandleGuestTopologyChange: main UI rect: 1920x1080 @ 0,0
2024-10-18T06:47:33.556Z In(05) vmui HandleGuestTopologyChange: Found 0 present screens
2024-10-18T06:47:33.556Z In(05) vmui HandleGuestTopologyChange: Windows for extra guest monitors will not be shown
2024-10-18T06:47:33.564Z In(05) vmui KeyLocator_ExtractCipherFromConfigFile: Dictionary /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx is not encrypted
2024-10-18T06:47:33.578Z In(05) vmui /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: Reloading config state.
2024-10-18T06:47:33.580Z In(05) vmui VMHS: Transitioned vmx/execState/val to poweredOff
2024-10-18T06:47:33.582Z In(05) vigorCnx VigorOfflineGetToolsVersion: updated tools version to 0
2024-10-18T06:47:33.602Z In(05) vmui Vix: [foundryVMPowerOps.c:986]: FoundryVMPowerStateChangeCallback: /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx, vmx/execState/val = poweredOff.
2024-10-18T06:47:33.603Z In(05) vmui VMMKS::OnMKSDeviceInfoChanged: reset pipe name now in offline.
2024-10-18T06:47:33.603Z In(05) vmui Found vmx as /usr/lib/vmware/bin/vmware-vmx
2024-10-18T06:47:33.603Z In(05) vmui Starting vmx as /usr/lib/vmware/bin/vmware-vmx
2024-10-18T06:47:33.603Z In(05) vmui VigorExecVMXExCommon: VM /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx in directory /home/jim/vmware/AlmaLinux 64-bit
2024-10-18T06:47:33.603Z In(05) vmui VigorExecVMXExCommon: Exec()'ing /usr/lib/vmware/bin/vmware-vmx /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx.
2024-10-18T06:47:33.610Z In(05) vmui VmdbAddConnection: cnxPath=/db/connection/#e/, cnxIx=1
2024-10-18T06:47:33.610Z In(05) vmui Vmdb_AddConnectionAsync_Secure: registered VERSION completion callback, cnx = /db/connection/#e/
2024-10-18T06:47:33.621Z In(05) vmui SnapshotTree: Populating (/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx)
2024-10-18T06:47:33.621Z In(05) vmui SnapshotTree: Emitting refresh (/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx)
2024-10-18T06:47:33.629Z In(05) vmui OnVMStateChanged: alive = 1
2024-10-18T06:47:33.629Z In(05) vmui CUIMKS: cui::MKS::SetAttached (557374970820): detach
2024-10-18T06:47:33.629Z In(05) vmui CUIMKS: cui::MKS::OnSetAttachedCompleted (557374970820)
2024-10-18T06:47:33.635Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.635Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.635Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.635Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.635Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.711Z In(05) vmui /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: Mounting VM begun.
2024-10-18T06:47:33.711Z In(05) vmui /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: Mounting virtual machine paths on connection: /db/connection/#e/.
2024-10-18T06:47:33.712Z In(05) vmui VmdbCnxControlCb: registered SUBSCRIBE completion callback, cnx = /db/connection/#e/
2024-10-18T06:47:33.751Z In(05) vmui VigorOnlineStartMountCb Succeeded
2024-10-18T06:47:33.751Z In(05) vmui /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: Mounting VM complete.
2024-10-18T06:47:33.751Z In(05) vmui /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: VMHSStartVmxVigorCb: vmPath=/vm/#58b714fe069b0ead/ status=done
2024-10-18T06:47:33.751Z In(05) vmui /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: Mount VM completion for vm.
2024-10-18T06:47:33.751Z In(05) vmui /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: Mount VM Complete: False
2024-10-18T06:47:33.797Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.797Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.797Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.797Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.797Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.826Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.826Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.826Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.826Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.826Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.841Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.842Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.842Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.842Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.842Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.858Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.858Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.858Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.858Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.858Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.875Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.875Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.875Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.875Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.875Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.892Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.892Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.892Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.892Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.892Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.909Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.909Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.909Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.909Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.909Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.925Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.925Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.925Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.925Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.925Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.942Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.942Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.942Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.942Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.942Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.958Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.958Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.958Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.958Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.958Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.976Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.976Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.976Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.976Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.976Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:33.992Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:33.992Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:33.992Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:33.992Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:33.992Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:34.035Z In(05) vmui CnxFSVigor: Could not get the dataFileKey
2024-10-18T06:47:38.312Z In(05) vmui CUIMKS: cui::MKS::SetAttached (557374970820): detach
2024-10-18T06:47:38.312Z In(05) vmui CUIMKS: cui::MKS::OnSetAttachedCompleted (557374970820)
2024-10-18T06:47:38.337Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.337Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.337Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.337Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.337Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.365Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.365Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.365Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.365Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.365Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.392Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.392Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.392Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.392Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.392Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.408Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.408Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.408Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.408Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.408Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.426Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.426Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.426Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.426Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.426Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.445Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.445Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.445Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.445Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.445Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.459Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.459Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.459Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.459Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.459Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.475Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.475Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.475Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.475Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.475Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.491Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.491Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.491Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.491Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.491Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.508Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.508Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.508Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.508Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.508Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.525Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.525Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.525Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.525Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.525Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.541Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.541Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.541Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.541Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.541Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.558Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.558Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.558Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.558Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.558Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:38.575Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:38.575Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:38.575Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:38.575Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:38.575Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:40.373Z In(05) vmui CUIMKS: cui::MKS::SetAttached (557374970820): detach
2024-10-18T06:47:40.373Z In(05) vmui CUIMKS: cui::MKS::OnSetAttachedCompleted (557374970820)
2024-10-18T06:47:40.373Z In(05) vmui VmdbPipeStreamsOvlError Couldn't read: OVL_STATUS_EOF (remote disconnect)
2024-10-18T06:47:40.373Z In(05) vmui VmdbCnxDisconnect: Disconnect: closed pipe for sub cnx '/db/connection/#e/' (-32)
2024-10-18T06:47:40.373Z In(05) vmui VigorOnlineCnxDemux: VmdbCnx failed: Lost a connection to the running VMX instance.
2024-10-18T06:47:40.373Z In(05)+ vmui Transport (VMDB) error -32: Pipe: Read failed.
2024-10-18T06:47:40.373Z In(05) vmui VigorOnlineDisconnect: disconnect /vm/#58b714fe069b0ead/ via /db/connection/#e/
2024-10-18T06:47:40.374Z In(05) vmui /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: Unmounting VM begun.
2024-10-18T06:47:40.374Z In(05) vmui VMDB unmount initiated for /vm/#58b714fe069b0ead/.
2024-10-18T06:47:40.387Z In(05) vmui VigorOnlineUnmountCb: Mount state values have changed for /vm/#58b714fe069b0ead/.
2024-10-18T06:47:40.387Z In(05) vmui VmdbDbRemoveCnx: Removing Cnx from Db for '/db/connection/#e/'
2024-10-18T06:47:40.387Z In(05) vmui VigorOnlineUnmountCb: Unmount complete for /vm/#58b714fe069b0ead/.
2024-10-18T06:47:40.387Z In(05) vmui VigorOnlineUnmountCb unset Vigor path on vm unmount.
2024-10-18T06:47:40.387Z In(05) vmui /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: Unmounting VM complete.
2024-10-18T06:47:40.387Z In(05) vmui /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx: Reloading config state.
2024-10-18T06:47:40.391Z In(05) vmui VMHS: Transitioned vmx/execState/val to poweredOff
2024-10-18T06:47:40.392Z In(05) vigorCnx VigorOfflineGetToolsVersion: updated tools version to 0
2024-10-18T06:47:40.412Z In(05) vmui Vix: [foundryVM.c:10387]: FoundryVMMountStateChangeCallback: remount complete, set flag, VM = /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx
2024-10-18T06:47:40.413Z In(05) vmui Vix: [foundryVMPowerOps.c:986]: FoundryVMPowerStateChangeCallback: /home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx, vmx/execState/val = poweredOff.
2024-10-18T06:47:40.413Z In(05) vmui vm power operation abort, error = Transport (VMDB) error -14: Pipe connection has been broken.
2024-10-18T06:47:40.413Z In(05)+ vmui  .
2024-10-18T06:47:40.427Z In(05) vmui OnVMStateChanged: alive = 0
2024-10-18T06:47:40.427Z In(05) vmui CUIMKS: cui::MKS::SetAttached (557374970820): detach
2024-10-18T06:47:40.427Z In(05) vmui CUIMKS: cui::MKS::OnSetAttachedCompleted (557374970820)
2024-10-18T06:47:40.428Z In(05) vmui VMMKS::OnMKSDeviceInfoChanged: reset pipe name now in offline.
2024-10-18T06:47:40.430Z In(05) vmui SnapshotTree: Emitting refresh (/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx)
2024-10-18T06:47:40.430Z In(05) vmui SnapshotTree: Populating (/home/jim/vmware/AlmaLinux 64-bit/AlmaLinux 64-bit.vmx)
2024-10-18T06:47:40.443Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:40.443Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:40.443Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:40.443Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:40.443Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:40.478Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:40.478Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:40.478Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:40.478Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:40.478Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:40.491Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:40.491Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:40.491Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:40.491Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:40.491Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:40.508Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:40.508Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:40.508Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:40.508Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:40.508Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:40.900Z In(05) vmui CnxFSVigor: Could not get the dataFileKey
2024-10-18T06:47:41.432Z In(05) vmui CnxFSVigor: Could not get the dataFileKey
2024-10-18T06:47:57.619Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:57.619Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:57.619Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:57.619Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:57.619Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:57.645Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:57.645Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:57.645Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:57.645Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:57.645Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:57.677Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:57.677Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:57.677Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:57.677Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:57.677Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:57.694Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:57.694Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:57.694Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:57.694Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:57.694Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:57.708Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:57.708Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:57.708Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:57.708Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:57.708Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:57.725Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:57.725Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:57.725Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:57.725Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:57.725Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:57.741Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:57.741Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:57.741Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:57.741Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:57.741Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:57.759Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:57.759Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:57.759Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:57.759Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:57.759Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:57.775Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:57.775Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:57.775Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:57.775Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:57.775Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:57.792Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:57.792Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:57.792Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:57.792Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:57.792Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:57.808Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:57.808Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:57.808Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:57.808Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:57.808Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:47:57.824Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:47:57.824Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:47:57.824Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:47:57.824Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:47:57.824Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:50:53.966Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:50:53.966Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:50:53.966Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:50:53.966Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:50:53.966Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:50:53.988Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:50:53.988Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:50:53.988Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:50:53.988Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:50:53.988Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:50:54.002Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:50:54.002Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:50:54.002Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:50:54.002Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:50:54.002Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:50:54.019Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:50:54.019Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:50:54.019Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:50:54.019Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:50:54.019Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:51:01.026Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:51:01.026Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:51:01.026Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:51:01.026Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:51:01.026Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:51:01.049Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:51:01.049Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:51:01.049Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:51:01.049Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:51:01.049Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:51:01.075Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:51:01.075Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:51:01.075Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:51:01.075Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:51:01.075Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:51:01.103Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:51:01.103Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:51:01.103Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:51:01.103Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:51:01.103Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:51:01.120Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:51:01.120Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:51:01.120Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:51:01.120Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:51:01.120Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:51:01.137Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:51:01.137Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:51:01.137Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:51:01.137Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:51:01.137Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:51:01.153Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:51:01.153Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:51:01.153Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:51:01.153Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:51:01.153Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:51:01.170Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:51:01.170Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:51:01.170Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:51:01.170Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:51:01.170Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:51:01.188Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:51:01.188Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:51:01.188Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:51:01.188Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:51:01.188Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:51:01.205Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:51:01.205Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:51:01.205Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:51:01.205Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:51:01.205Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:51:01.221Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:51:01.221Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:51:01.221Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:51:01.221Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:51:01.221Z In(05) vmui GdkPixbuf:     Copy pixels == false
2024-10-18T06:51:01.240Z In(05) vmui GdkPixbuf: gdk_pixbuf_from_pixdata() called on:
2024-10-18T06:51:01.240Z In(05) vmui GdkPixbuf:     Encoding raw
2024-10-18T06:51:01.240Z In(05) vmui GdkPixbuf:     Dimensions: 14 x 14
2024-10-18T06:51:01.240Z In(05) vmui GdkPixbuf:     Rowstride: 56, Length: 808
2024-10-18T06:51:01.240Z In(05) vmui GdkPixbuf:     Copy pixels == false
(base) [root@localhost vmware-jim]#
James Woodworth's profile image
James Woodworth
Hi again, log file is attached as a zip file.  Thanks
Dhairya Tomar's profile image
Broadcom Employee Dhairya Tomar
Ticket has been raised internally, relevant team will look into the same.
Vinitha V Nair's profile image
Broadcom Employee Vinitha V Nair
Hi,
Could you please share the original version of the files that is modified?
Request you to share the original versions of /usr/lib/vmware/modules/source/vmnet-only/bridge.c and /usr/lib/vmware/modules/source/vmmon-only/include/pgtbl.h
goldeneye_007's profile image
goldeneye_007
I don't see anywhere that you ran
make
make install
You have to do that after making the script changes. I also had to reboot so that the kernel modules would get loaded which wasn't listed as something that needed to be done in the instructions I followed, but it only worked after a reboot. Probably something related to secureboot.
