VMware Workstation
 Internet connection problem with VMWare Workstation 17.5.2
Nael Sayegh's profile image
Nael Sayegh posted Aug 11, 2024 11:26 AM
Hello,
I have VMware Workstation (for personal use) installed on my computer. I updated it 3 days ago. My problem is that, for the past 2 days, the virtual machines that I launch are no longer connecting to the network, whether in bridge or NAT mode.
I have performed the following steps:
- In the virtual machines, I removed and then added the network adapter
- Uninstalled and reinstalled VMware Workstation (latest version)
- Reset the VMware network editor
Unfortunately, my problem still persists. Internet connection problem with VMWare WorkstationCould you please provide a solution? Everything was working correctly prior to the last 2 days.
Thank you in advance for your response.
yrona's profile image
yrona
I had a similar problem.  The way I solved it was by using patches put out by end users who - out of charity - did VMWare's work for them.
The patches fix vmmon and vmnet so that they will function.
The instructions for the basic patch may be found here: https://github.com/mkubecek/vmware-host-modules/blob/master/INSTALL
For later versions of the kernel, you may need to install a different variant of the same repository found here: https://github.com/nan0desu/vmware-host-modules
First, what version of the kernel, and what version of VMware workstation pro are you using?  What is your host OS?
