VMware Workstation
  • 1.  Workstation Pro 17.5.2 & 17.6.0 fail to install. Virtual machine monitor & Virtual ethernet fail to start. (KDE Neon)
    Posted Sep 16, 2024 11:29 AM
    I tried installing 17.6 on a fresh install of KDE Neon, which is based on Ubuntu 24.04. It failed, even after trying several kernel patches. I resorted trying 17.5.2 because I have it running on another laptop running KDE Neon. It fails with similar results.
    Kernel is 6.8.0-40-generic. Default gcc is gcc (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0.
    $ sudo ./VMware-Workstation-Full-17.6.0-24238078.x86_64.bundle
    Place your right index finger on the fingerprint reader
    Extracting VMware Installer...done.
    Installing VMware Workstation 17.6.0
        Configuring...
    [######################################################################] 100%
    Installation was successful.
    Install isn't really successful. The Workstation UI runs, but the two services are not.
    A rebuild attempt:
    $ sudo vmware-modconfig --console --install-all
    [AppLoader] GLib does not have GSettings support.
    Stopping VMware services:
       VMware Authentication Daemon                                        done
       Virtual machine monitor                                             done
    make: Entering directory '/tmp/modconfig-aVODUz/vmmon-only'
    Using kernel build system.
    /usr/bin/make -C /lib/modules/6.8.0-40-generic/build/include/.. M=$PWD SRCROOT=$PWD/. \
      MODULEBUILDDIR= modules
    make[1]: Entering directory '/usr/src/linux-headers-6.8.0-40-generic'
    warning: the compiler differs from the one used to build the kernel
      The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
      You are using:           gcc (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/linux/driver.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/linux/driverLog.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/linux/hostif.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/common/apic.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/common/comport.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/common/cpuid.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/common/crosspage.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/common/memtrack.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/common/moduleloop.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/common/phystrack.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/common/sharedAreaVmmon.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/common/statVarsVmmon.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/common/task.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/common/vmx86.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/bootstrap/bootstrap.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/bootstrap/monLoader.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/bootstrap/monLoaderVmmon.o
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/bootstrap/vmmblob.o
    /tmp/modconfig-aVODUz/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Add() falls through to next function PhysTrack_Remove()
    /tmp/modconfig-aVODUz/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Remove() falls through to next function PhysTrack_Test()
    /tmp/modconfig-aVODUz/vmmon-only/common/task.o: warning: objtool: .text: unexpected end of section
      LD [M]  /tmp/modconfig-aVODUz/vmmon-only/vmmon.o
      MODPOST /tmp/modconfig-aVODUz/vmmon-only/Module.symvers
      CC [M]  /tmp/modconfig-aVODUz/vmmon-only/vmmon.mod.o
      LD [M]  /tmp/modconfig-aVODUz/vmmon-only/vmmon.ko
      BTF [M] /tmp/modconfig-aVODUz/vmmon-only/vmmon.ko
    Skipping BTF generation for /tmp/modconfig-aVODUz/vmmon-only/vmmon.ko due to unavailability of vmlinux
    make[1]: Leaving directory '/usr/src/linux-headers-6.8.0-40-generic'
    /usr/bin/make -C $PWD SRCROOT=$PWD/. \
      MODULEBUILDDIR= postbuild
    make[1]: Entering directory '/tmp/modconfig-aVODUz/vmmon-only'
    make[1]: 'postbuild' is up to date.
    make[1]: Leaving directory '/tmp/modconfig-aVODUz/vmmon-only'
    cp -f vmmon.ko ./../vmmon.o
    make: Leaving directory '/tmp/modconfig-aVODUz/vmmon-only'
    make: Entering directory '/tmp/modconfig-aVODUz/vmnet-only'
      CC [M]  /tmp/modconfig-aVODUz/vmnet-only/driver.o
      CC [M]  /tmp/modconfig-aVODUz/vmnet-only/hub.o
      CC [M]  /tmp/modconfig-aVODUz/vmnet-only/userif.o
      CC [M]  /tmp/modconfig-aVODUz/vmnet-only/netif.o
      CC [M]  /tmp/modconfig-aVODUz/vmnet-only/bridge.o
      CC [M]  /tmp/modconfig-aVODUz/vmnet-only/procfs.o
      CC [M]  /tmp/modconfig-aVODUz/vmnet-only/smac_compat.o
      CC [M]  /tmp/modconfig-aVODUz/vmnet-only/smac.o
      CC [M]  /tmp/modconfig-aVODUz/vmnet-only/vnetEvent.o
      CC [M]  /tmp/modconfig-aVODUz/vmnet-only/vnetUserListener.o
    /tmp/modconfig-aVODUz/vmnet-only/userif.o: warning: objtool: VNetCsumAndCopyToUser+0x2d: call to csum_partial_copy_nocheck() with UACCESS enabled
      LD [M]  /tmp/modconfig-aVODUz/vmnet-only/vmnet.o
      MODPOST /tmp/modconfig-aVODUz/vmnet-only/Module.symvers
      CC [M]  /tmp/modconfig-aVODUz/vmnet-only/vmnet.mod.o
      LD [M]  /tmp/modconfig-aVODUz/vmnet-only/vmnet.ko
      BTF [M] /tmp/modconfig-aVODUz/vmnet-only/vmnet.ko
    Skipping BTF generation for /tmp/modconfig-aVODUz/vmnet-only/vmnet.ko due to unavailability of vmlinux
    make[1]: Entering directory '/tmp/modconfig-aVODUz/vmnet-only'
    make[1]: Leaving directory '/tmp/modconfig-aVODUz/vmnet-only'
    cp -f vmnet.ko ./../vmnet.o
    make: Leaving directory '/tmp/modconfig-aVODUz/vmnet-only'
    Starting VMware services:
       Virtual machine monitor                                            failed
       Virtual machine communication interface                             done
       VM communication interface socket family                            done
       Virtual ethernet                                                   failed
    Unable to start services
  • 2.  RE: Workstation Pro 17.5.2 & 17.6.0 fail to install. Virtual machine monitor & Virtual ethernet fail to start. (KDE Neon)
    Posted Sep 16, 2024 12:03 PM
    WS 1.6.0 on F40 host
    W11 client
    Have you seen the patches here
    https://github.com/bytium/vm-host-modules/
    together with a further fix here at the end of
    https://github.com/mkubecek/vmware-host-modules/issues/280
    Working well on Fedora 40, kernel 6.10.9-200.fc40.x86_64
    John
    >     Configuring...
    > A rebuild attempt:
    > Reply to Sender :
    > https://community.broadcom.com/eGroups/PostReply/?GroupId=7171&MID=4366183&SenderKey=fd6d1c9e-4758-4bcd-acbd-cb658c570bd1
    > Reply to Discussion : https://community.broadcom.com/eGroups/PostReply/?GroupId=7171&MID=4366183
    > You are subscribed to "VMware Workstation" as ja@jaa.org.uk. To change your subscriptions, go to
    > http://community.broadcom.com/preferences?section=Subscriptions.  To unsubscribe from this community
    > discussion, go to
    > http://community.broadcom.com/HigherLogic/eGroups/Unsubscribe.aspx?UserKey=555e8c66-e95e-42fa-9d37-018faae3c7f3&sKey=KeyRemoved&GroupKey=1b0a16ce-2127-4fae-a840-018f5da56726
    > Copyright © 2005-2023 Broadcom. All Rights Reserved. The term "Broadcom" refers to Broadcom Inc.
    > and/or its subsidiaries.
    > Hosted by Higher Logic, LLC on the behalf of Broadcom
    > https://www.broadcom.com/company/legal/privacy-policy | https://www.higherlogic.com/legal/privacy |
    > https://www.broadcom.com/company/citizenship/governance-and-ethics#supply |
    > https://www.broadcom.com/termsandconditions
  • 3.  RE: Workstation Pro 17.5.2 & 17.6.0 fail to install. Virtual machine monitor & Virtual ethernet fail to start. (KDE Neon)
    Posted Sep 16, 2024 12:48 PM
    I tried bytium this morning.
    Here is a module rebuild after installing 17.6.0:
    make: Entering directory '/tmp/modconfig-xy8dGm/vmmon-only'
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/linux/driver.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/linux/driverLog.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/linux/hostif.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/common/apic.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/common/comport.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/common/cpuid.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/common/crosspage.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/common/memtrack.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/common/moduleloop.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/common/phystrack.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/common/sharedAreaVmmon.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/common/statVarsVmmon.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/common/task.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/common/vmx86.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/bootstrap/bootstrap.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/bootstrap/monLoader.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/bootstrap/monLoaderVmmon.o
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/bootstrap/vmmblob.o
    /tmp/modconfig-xy8dGm/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Add() falls through to next function PhysTrack_Remove()
    /tmp/modconfig-xy8dGm/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Remove() falls through to next function PhysTrack_Test()
    /tmp/modconfig-xy8dGm/vmmon-only/common/task.o: warning: objtool: .text: unexpected end of section
      LD [M]  /tmp/modconfig-xy8dGm/vmmon-only/vmmon.o
      MODPOST /tmp/modconfig-xy8dGm/vmmon-only/Module.symvers
      CC [M]  /tmp/modconfig-xy8dGm/vmmon-only/vmmon.mod.o
      LD [M]  /tmp/modconfig-xy8dGm/vmmon-only/vmmon.ko
      BTF [M] /tmp/modconfig-xy8dGm/vmmon-only/vmmon.ko
    Skipping BTF generation for /tmp/modconfig-xy8dGm/vmmon-only/vmmon.ko due to unavailability of vmlinux
    make[1]: Entering directory '/tmp/modconfig-xy8dGm/vmmon-only'
    make[1]: Leaving directory '/tmp/modconfig-xy8dGm/vmmon-only'
    make: Leaving directory '/tmp/modconfig-xy8dGm/vmmon-only'
    make: Entering directory '/tmp/modconfig-xy8dGm/vmnet-only'
      CC [M]  /tmp/modconfig-xy8dGm/vmnet-only/driver.o
      CC [M]  /tmp/modconfig-xy8dGm/vmnet-only/hub.o
      CC [M]  /tmp/modconfig-xy8dGm/vmnet-only/userif.o
      CC [M]  /tmp/modconfig-xy8dGm/vmnet-only/netif.o
      CC [M]  /tmp/modconfig-xy8dGm/vmnet-only/bridge.o
      CC [M]  /tmp/modconfig-xy8dGm/vmnet-only/procfs.o
      CC [M]  /tmp/modconfig-xy8dGm/vmnet-only/smac_compat.o
      CC [M]  /tmp/modconfig-xy8dGm/vmnet-only/smac.o
      CC [M]  /tmp/modconfig-xy8dGm/vmnet-only/vnetEvent.o
      CC [M]  /tmp/modconfig-xy8dGm/vmnet-only/vnetUserListener.o
    /tmp/modconfig-xy8dGm/vmnet-only/userif.o: warning: objtool: VNetCsumAndCopyToUser+0x2d: call to csum_partial_copy_nocheck() with UACCESS enabled
      LD [M]  /tmp/modconfig-xy8dGm/vmnet-only/vmnet.o
      MODPOST /tmp/modconfig-xy8dGm/vmnet-only/Module.symvers
      CC [M]  /tmp/modconfig-xy8dGm/vmnet-only/vmnet.mod.o
      LD [M]  /tmp/modconfig-xy8dGm/vmnet-only/vmnet.ko
      BTF [M] /tmp/modconfig-xy8dGm/vmnet-only/vmnet.ko
    Skipping BTF generation for /tmp/modconfig-xy8dGm/vmnet-only/vmnet.ko due to unavailability of vmlinux
    make[1]: Entering directory '/tmp/modconfig-xy8dGm/vmnet-only'
    make[1]: Leaving directory '/tmp/modconfig-xy8dGm/vmnet-only'
    make: Leaving directory '/tmp/modconfig-xy8dGm/vmnet-only'
    Here is a module rebuild after bytium (It got worse.):
    sudo make install
    Copying tarballs to /usr/lib/vmware/modules/source...
    sudo cp vmmon.tar vmnet.tar /usr/lib/vmware/modules/source
    Rebuilding VMware modules...
    make: Entering directory '/tmp/modconfig-XmfwMj/vmmon-only'
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/linux/driver.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/linux/driverLog.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/linux/hostif.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/common/apic.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/common/comport.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/common/cpuid.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/common/crosspage.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/common/memtrack.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/common/moduleloop.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/common/phystrack.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/common/sharedAreaVmmon.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/common/statVarsVmmon.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/common/task.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/common/vmx86.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/bootstrap/bootstrap.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/bootstrap/monLoader.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/bootstrap/monLoaderVmmon.o
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/bootstrap/vmmblob.o
    /tmp/modconfig-XmfwMj/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Add() falls through to next function PhysTrack_Remove()
    /tmp/modconfig-XmfwMj/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Remove() falls through to next function PhysTrack_Test()
    /tmp/modconfig-XmfwMj/vmmon-only/common/task.o: warning: objtool: .text: unexpected end of section
      LD [M]  /tmp/modconfig-XmfwMj/vmmon-only/vmmon.o
      MODPOST /tmp/modconfig-XmfwMj/vmmon-only/Module.symvers
      CC [M]  /tmp/modconfig-XmfwMj/vmmon-only/vmmon.mod.o
      LD [M]  /tmp/modconfig-XmfwMj/vmmon-only/vmmon.ko
      BTF [M] /tmp/modconfig-XmfwMj/vmmon-only/vmmon.ko
    Skipping BTF generation for /tmp/modconfig-XmfwMj/vmmon-only/vmmon.ko due to unavailability of vmlinux
    make[1]: Entering directory '/tmp/modconfig-XmfwMj/vmmon-only'
    make[1]: Leaving directory '/tmp/modconfig-XmfwMj/vmmon-only'
    make: Leaving directory '/tmp/modconfig-XmfwMj/vmmon-only'
    make: Entering directory '/tmp/modconfig-XmfwMj/vmnet-only'
      CC [M]  /tmp/modconfig-XmfwMj/vmnet-only/driver.o
      CC [M]  /tmp/modconfig-XmfwMj/vmnet-only/hub.o
      CC [M]  /tmp/modconfig-XmfwMj/vmnet-only/userif.o
      CC [M]  /tmp/modconfig-XmfwMj/vmnet-only/netif.o
      CC [M]  /tmp/modconfig-XmfwMj/vmnet-only/bridge.o
      CC [M]  /tmp/modconfig-XmfwMj/vmnet-only/procfs.o
      CC [M]  /tmp/modconfig-XmfwMj/vmnet-only/smac_compat.o
      CC [M]  /tmp/modconfig-XmfwMj/vmnet-only/smac.o
      CC [M]  /tmp/modconfig-XmfwMj/vmnet-only/vnetEvent.o
      CC [M]  /tmp/modconfig-XmfwMj/vmnet-only/vnetUserListener.o
    /tmp/modconfig-XmfwMj/vmnet-only/driver.c:288:1: warning: no previous prototype for 'LinuxDriverInit' [-Wmissing-prototypes]
      288 | LinuxDriverInit(void)
    /tmp/modconfig-XmfwMj/vmnet-only/driver.c:367:1: warning: no previous prototype for 'LinuxDriverExit' [-Wmissing-prototypes]
      367 | LinuxDriverExit(void)
    /tmp/modconfig-XmfwMj/vmnet-only/userif.o: warning: objtool: VNetCsumAndCopyToUser+0x2d: call to csum_partial_copy_nocheck() with UACCESS enabled
      LD [M]  /tmp/modconfig-XmfwMj/vmnet-only/vmnet.o
      MODPOST /tmp/modconfig-XmfwMj/vmnet-only/Module.symvers
      CC [M]  /tmp/modconfig-XmfwMj/vmnet-only/vmnet.mod.o
      LD [M]  /tmp/modconfig-XmfwMj/vmnet-only/vmnet.ko
      BTF [M] /tmp/modconfig-XmfwMj/vmnet-only/vmnet.ko
    Skipping BTF generation for /tmp/modconfig-XmfwMj/vmnet-only/vmnet.ko due to unavailability of vmlinux
    make[1]: Entering directory '/tmp/modconfig-XmfwMj/vmnet-only'
    make[1]: Leaving directory '/tmp/modconfig-XmfwMj/vmnet-only'
    make: Leaving directory '/tmp/modconfig-XmfwMj/vmnet-only'
    make: *** [Makefile:49: vmware-rebuild] Error 1
  • 4.  RE: Workstation Pro 17.5.2 & 17.6.0 fail to install. Virtual machine monitor & Virtual ethernet fail to start. (KDE Neon)
    Posted Sep 17, 2024 12:02 PM
    Hmmm
    I would try just one more time with a completely clean
    version of 17.6.0, bytium modules, ...
    However my procedure looks different to yours, ???
    vmware-installer -u vmware-workstaion
    Lots of errors I ignored.
    cd somewhere
    git clone https://github.com/bytium/vm-host-modules.git
    cd somewhere/vm-host-modules
    git checkout 17.6.0
    [edit
    vm-host-modules/vmmon-only/include/x86cpuid.h
    vm-host-modules/vmmon-only/include/x86msr.h
    if you wish]
    make clean
    make
    su
    make install
    Good luck!
    > sudo make install
    > Original Message:
    > Sent: Sep 16, 2024 12:03 PM
    > From: John Austin
    > Subject:  Workstation Pro 17.5.2 & 17.6.0 fail to install. Virtual machine monitor & Virtual ethernet
    > W11 client
    > https://github.com/bytium/vm-host-modules/ <https: github.com/bytium/vm-host-modules/="">
    > https://github.com/mkubecek/vmware-host-modules/issues/280 <
    > https://github.com/mkubecek/vmware-host-modules/issues/280>
    > John
    > >     Configuring...
    > > A rebuild attempt:
    > > vmlinux
    > > vmlinux
    > > Reply to Sender :
    > > https://community.broadcom.com/eGroups/PostReply/?GroupId=7171&MID=4366183 <https: community.broadcom.com/egroups/postreply/?groupid=""></https:>
    > > You are subscribed to "VMware Workstation" as ja@jaa.org.uk <ja@jaa.org.uk>. To change your
    > > <http: community.broadcom.com/preferences?section="Subscriptions.">  To unsubscribe from this
    > > community
    > > discussion, go to
    > > https://www.broadcom.com/company/legal/privacy-policy <
    > > https://www.broadcom.com/company/legal/privacy-policy> |
    > > https://www.higherlogic.com/legal/privacy <https: www.higherlogic.com/legal/privacy=""> |
    > > https://www.broadcom.com/company/citizenship/governance-and-ethics#supply <
    > > https://www.broadcom.com/company/citizenship/governance-and-ethics#supply> |
    > > https://www.broadcom.com/termsandconditions <https: www.broadcom.com/termsandconditions="">
    > Original Message:
    > Sent: 9/16/2024 11:29:00 AM
    > From: kamiller42
    >     Configuring...
    > A rebuild attempt:
    > Reply to Sender :
    > https://community.broadcom.com/eGroups/PostReply/?GroupId=7171&MID=4366199&SenderKey=fd6d1c9e-4758-4bcd-acbd-cb658c570bd1
    > Reply to Discussion : https://community.broadcom.com/eGroups/PostReply/?GroupId=7171&MID=4366199
    > discussion, go to
  • 5.  RE: Workstation Pro 17.5.2 & 17.6.0 fail to install. Virtual machine monitor & Virtual ethernet fail to start. (KDE Neon)
    Posted Sep 17, 2024 05:00 PM
    Thank you, John. Thanks for caring and providing a concise set of steps.
    I followed your steps using bytium, nan0desu, and mkubecek modules. Same results. "Virtual machine monitor" and 'Virtual ethernet" failed to start.
    I started moving to a KVM/QEMU solution. Not bad, but I can't get the guest resolution to occupy all of the host window space. So, I'm trying VirtualBox. During its install, it prompted me it needed to make an entry in UEFI and to set a password.
    Would the new laptop (Dell Inspiron 16+ w/Ultra 7 155H) being UEFI with SecureBoot enabled be an issue when setting up Workstation?
