PowerCLI
Expand all | Collapse all
Storage Path details Power Cli script Need
Sivapb
SivapbJul 03, 2014 03:01 AM
  • 1.  Storage Path details Power Cli script Need
    Posted Jul 03, 2014 02:17 AM
    hi i need output for for below command in excel file as a single powercli script any one help me
    1.  esxcfg-mpath –l
    2.  esxcli storage core path list
    3.  esxcli storage nmp device list
  • 2.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 02:51 AM
    (Get-VMhost VMhostname | Get-esxcli).storage.nmp.device.list() | Export-Csv -path c:\test.csv
    (Get-VMhost VMhostname | Get-esxcli).storage.core.path.list() | Export-Csv -path c:\test.csv
  • 3.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 03:01 AM
    Thanks for reply
    Getting error
  • 4.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 05:07 AM
    I assume you have more than 1 ESXi host in your environment ?
    In that case
    Get-VMHost "*"
    will return more than 1 object, and consequently so will the Get-EsxCli cmdlet.
    But that means that
    is an array, on an array there is no storage method or property.
    You should pass 1 object to the Get-EsxCli cmdlet, something like this for example
    &{Get-VMhost VMhostname | %{
         $esxcli = Get-esxcli -VMHost $_
         $esxcli.storage.nmp.device.list()
    }} | Export-Csv -path c:\test.csv
    Note how the script uses the call operator (&).
    This is because the ForEach (alias '%'), doesn't place any objects on the pipeline, which can be used as input to the Ex[prt-Csv cmdlet.
  • 5.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 05:25 AM
    Yes my infra have more than 1 host
    Getting following Error message
    Get-EsxCli : 7/3/2014 10:48:12 AM    Get-EsxCli        Message: An error occurr
    ed while communicating with the remote host.;
    InnerText:
    At C:\Users\\Desktop\storage.ps1:1 char:29
    + (Get-VMhost "*" | Get-esxcli <<<< )
        + CategoryInfo          : NotSpecified: (:) [Get-EsxCli], HostCommunicatio
       n
        + FullyQualifiedErrorId : Client20_DynamicTypeManagerServiceImpl_GetMoInst
       ances_ViError,VMware.VimAutomation.ViCore.Cmdlets.Commands.GetEsxCli
    Get-EsxCli : 7/3/2014 10:48:34 AM    Get-EsxCli        Message: An error occurr
    InnerText:
       n
    i need out put for following commands
    1.  esxcfg-mpath –l
  • 6.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 05:29 AM
    What code are you executing now ?
    From the error it seems you are still using your original code.
  • 7.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 05:36 AM
    (Get-VMhost "*" | Get-esxcli)
    above script i'm executing. i want result for how many active path is there in data store. i have more than 600 hosts and 45 vcenter with different data store .
  • 8.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 06:08 AM
    If you want the info for all the ESXi in your environment, do it like this
    &{Get-VMhost | %{
  • 9.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 06:15 AM
    Thanks got the output
    can you help me out get the output for following command
    esxcfg-mpath –l
  • 10.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 06:32 AM
    Isn't
    $esxcli.storage.core.path.list()
    producing more or less the same output ?
    The list in Replacements for Service Console Commands might come in handy
  • 11.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 07:11 AM
    No. i dint get the output. i need below info in output
    esxcfg-mpath -l
    fc.20000024ff01fe35:21000024ff01fe35-fc.500a098080556875:500a098280556875-naa.60a9800042374b63532b427762556a54
       Runtime Name: vmhba2:C0:T1:L20
       Device: naa.60a9800042374b63532b427762556a54
       Device Display Name: NETAPP Fibre Channel Disk (naa.60a9800042374b63532b427762556a54)
       Adapter: vmhba2 Channel: 0 Target: 1 LUN: 20
       Adapter Identifier: fc.20000024ff01fe35:21000024ff01fe35
       Target Identifier: fc.500a098080556875:500a098280556875
       Plugin: NMP
       State: active
       Transport: fc
       Adapter Transport Details: WWNN: 20:00:00:24:ff:01:fe:35 WWPN: 21:00:00:24:ff:01:fe:35
       Target Transport Details: WWNN: 50:0a:09:80:80:55:68:75 WWPN: 50:0a:09:82:80:55:68:75
  • 12.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 07:15 AM
    I'm getting that same information with $esxcli.storage.core.path.list()
    Which vSphere version are you running this against ?
    I assume vSphere 5.*
  • 13.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 07:32 AM
    yes. running vsphere 5.X .
    can u give me the complete powercli code for that 'esxcli.storage.core.path.list'
    output will be notepad also ok for me
  • 14.  RE: Storage Path details Power Cli script Need
    Best Answer
    Posted Jul 03, 2014 08:10 AM
    Try like this
    &{Get-VMhost | %{
  • 15.  RE: Storage Path details Power Cli script Need
    Posted Jul 03, 2014 08:37 AM
    Many Thanks LucD :smileyhappy:
  • 16.  RE: Storage Path details Power Cli script Need
    Posted Jul 09, 2014 04:19 AM
    Hi Lucd,
         I am getting error after generating the output in csv format
    PowerCLI C:\Program Files (x86)\VMware\Infrastructure\vSphere PowerCLI> &{Get-V
    host | %{
    >> }} | Export-Csv -path c:\temp\test.csv
    Get-EsxCli : 7/8/2014 11:01:54 PM    Get-EsxCli        Esxcli functionality is
    supported for host 'admpls001v.na.corp.cargill.com' only when connected directl
    y to it (not through vCenter connection).
    At line:2 char:26
    +      $esxcli = Get-esxcli <<<<  -VMHost $_
        + CategoryInfo          : InvalidArgument: (:) [Get-EsxCli], InvalidArgume
       nt
        + FullyQualifiedErrorId : Client20_DynamicTypeManagerServiceImpl_GetEsxCli
       _RequiredDirectEsxConnection,VMware.VimAutomation.ViCore.Cmdlets.Commands.
      GetEsxCli
    You cannot call a method on a null-valued expression.
    At line:3 char:36
    +      $esxcli.storage.core.path.list <<<< ()
        + CategoryInfo          : InvalidOperation: (list:String) [], RuntimeExcep
       tion
        + FullyQualifiedErrorId : InvokeMethodOnNull
    supported for host 'admpls002v.na.corp.cargill.com' only when connected directl
    At line:2 char:26
       nt
      GetEsxCli
    At line:3 char:36
       tion
    Get-EsxCli : 7/8/2014 11:05:04 PM    Get-EsxCli        Esxcli functionality is
    supported for host 'admpls030v.na.corp.cargill.com' only when connected directl
    At line:2 char:26
       nt
      GetEsxCli
    At line:3 char:36
       tion
    supported for host 'admpls031v.na.corp.cargill.com' only when connected directl
    At line:2 char:26
       nt
      GetEsxCli
    At line:3 char:36
       tion
    Thanks
    vmk2014
  • 17.  RE: Storage Path details Power Cli script Need
    Posted Jul 09, 2014 04:41 AM
    It looks as if you are not connected to the ESXi server.
    You can display the content of $global:defaultviserver to check.
