Yeah, because the integrated smartcard reader isn't going to be listed in removeable devices, you may be forced to attach a USB reader so you can use the main device from removeable devices or stick with the older version. I chose to use a USB reader so I can keep current. I sure hope Broadcom fixes this soon.
Original Message:
Sent: Nov 19, 2024 02:14 AM
Subject: Shared Generic Smart Card Reader Issue with 17.6 and higher
So, I have the same problem. Normally I use the integraded Smartcard reader, which is recognized as a "Shared Broadcom Corp" in removable devices. For my other USB reader it's the same problem, when using it as a "Shared" device.
Rolling back to 17.5.2 resolved the issue.
Unfortunately, for the integrated smartcard reader, there is no workaround, because only the "shared" smartcard option is available.
Original Message:
Sent: Nov 05, 2024 12:23 AM
@Dhairya Tomar, thank you for your help. As directed by our private thread, I will put a support ticket in this when I get some time. Until then at least if someone else hits this issue they will know the workaround is to add the entire device in the Removable Devices option.
Original Message:
Sent: Nov 03, 2024 11:34 PM
damondawson Requesting you to recreate the issue where it shows "No valid certificates were found on the smart card." and share support bundle of the affected VM.
Also share the make and model of the Smart cards where this issue is seen.
Original Message:
Sent: Nov 03, 2024 07:00 PM
On 09/16/2024 After upgrading to VMware Workstation 17.6.0-24238078 the USB-attached smart card reader stopped working. I tried 3 different readers... It would just go to "Checking status..." and after a long time would report "No valid certificates were found on the smart card." I was using the option under VM > Removable Devices > "Shared Generic Smart Card Reader Interface 0" I have used it this way for many years.
I ended up uninstalling 17.6.0-24238078 and rolled back by installing 17.5.2-23775571 to get it working again.
In Oct 2024 I also tried upgrading to 17.6.1-24319023 and it too had the same issue. This time I tried connecting the main USB device that had the Smart Card reader in it v/s using the "Shared Generic Smart Card Reader Interface 0" I did this by going to VM > Removeable Devices > "Realtek USB2.0-CRW" This corrected the issue and it started working again. Note: After doing this it removed the "Shared Generic Smart Card Reader Interface 0" and only lists the main USB device "Realtek USB2.0-CRW"
For sure something has changed between 17.5.2, where it was working, and versions 17.6.0 and 17.6.1, where it no longer works. The workaround limits the ability to use the smart card reader on the host system and multiple VMs, locking it down to only this one VM.
