PowerCLI
Expand all | Collapse all
PowerCLI 12 offline installation problem
  • 1.  PowerCLI 12 offline installation problem
    Posted Feb 11, 2021 09:11 AM
    Hi,
    We are working in secure environment, so it is no possible to install PowerCLI from PowerShell Gallery.
    There are lot of articles about offline installation, but I have found nothing VMware official.
    With PowerCLI 11 there were no problem.
    Just save modules and copy it to C:\Program Files\WindowsPowerShell\Modules.
    And it worked fine.
    But with PowerCLI 12.1 we have received following error when run new-vm:
    New-VM -Name testVM -Template template1 -host host01
    New-VM : 2/11/2021 8:54:49 AM   New-VM    Could not load file or assembly 'Newtonsoft.Json,
    Version=10.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The system cannot find the file specified.
    I have found following KBs where it is said that Newtonsoft.Json.dll must be registered:
    https://kb.vmware.com/s/article/79793
    Does anyone know if there is any official method how to install PowerCLI 12.X offline?
    Thanks.
    moderator edit by wila: Moved to PowerCLI forum
  • 2.  RE: PowerCLI 12 offline installation problem
    Posted Feb 11, 2021 06:44 PM
  • 3.  RE: PowerCLI 12 offline installation problem
    Posted Feb 19, 2021 07:01 AM
    Hi LucD,
    Thanks for replay.
    The provided post works for PowerCLI 11.X but not for 12.1.
  • 4.  RE: PowerCLI 12 offline installation problem
    Posted Feb 19, 2021 07:04 AM
    What does not work?
    Any error messages?
    Did you use the Save-Module on a station that runs the same PS version as your target station?
  • 5.  RE: PowerCLI 12 offline installation problem
    Posted Feb 19, 2021 07:11 AM
    You can see the error in my first post.
    I did not use save-module but I have downloaded modules in zip from VMware Code.
  • 6.  RE: PowerCLI 12 offline installation problem
    Posted Feb 19, 2021 07:12 AM
    Why can't you use Save-Module?
  • 7.  RE: PowerCLI 12 offline installation problem
    Posted Feb 19, 2021 07:19 AM
    Just because I have found zip with modules on Code webpage.
  • 8.  RE: PowerCLI 12 offline installation problem
    Posted Feb 19, 2021 07:22 AM
    Can you at least try the Save-Module procedure as documented in the (official VMware) post I linked to earlier?
  • 9.  RE: PowerCLI 12 offline installation problem
    Posted Feb 19, 2021 07:25 AM
    Btw, you seem to be complaining about a lack of documentation, but the procedure with the ZIP file is documented in the User Guide.
  • 10.  RE: PowerCLI 12 offline installation problem
    Posted Feb 19, 2021 07:36 AM
    You are right, it is for version 12.2.
    I have installed 12.1 and there are no info about offline installation in the docs.
    It is fine that it is corrected now.
  • 11.  RE: PowerCLI 12 offline installation problem
    Posted Feb 19, 2021 07:44 AM
    Did you try with 12.2?
    Does that give the same error?
    Did you clean up (remove) any old PowerCLI installation before installing the new version?
  • 12.  RE: PowerCLI 12 offline installation problem
    Posted Feb 19, 2021 08:43 AM
    I have tested it on computer outside our environment. Both 12.1 and 12.2 versions.
    There is no problem.
    Now with official docs I can proove that we do installation correctly and there is no error outside our environment.
    So I can ask our security team if the library is not blocked by a security software.
    It takes a while...
    Thanks for your help!
  • 13.  RE: PowerCLI 12 offline installation problem
    Posted Feb 16, 2021 02:14 PM
    And the procedure stated in the KB doesn't fix it?
  • 14.  RE: PowerCLI 12 offline installation problem
    Posted Feb 19, 2021 07:07 AM
    Hi vXav,
    We are working in secure environment.
    I cannot register any library because I have found KB with similar (not exactly same) problem.
    I need official VMware offline installation steps.
    I don´t understand why offline installation is not part of official PowerCLI docs.
    I think there must be lot of companies where online installation is not possible.
    P.
  • 15.  RE: PowerCLI 12 offline installation problem
    What did you actually try?
    The Save-Module procedure or the installation from the ZIP file?
