vSphere Storage Appliance
  • 1.  PLZ help me to solve a problem.
    Posted Jun 13, 2011 09:35 AM
    I have one VM wich runing on ESXI 4.1 I want to backup all the VM as is that in case the disaster I will can to up this VM in another ESXI 3.5 as is.How I can do that?
    Thank you for advance.
  • 2.  RE: PLZ help me to solve a problem.
    Best Answer
    Posted Jun 13, 2011 11:22 AM
    I assume you are talking about the free ESXi version. In this case you may want to take a look at e.g. ghettoVCB as a backup solution. However, a VM created in ESXi 4.1 may not run in ESXi 3.5 without manual modifications. This depends on the virtual hardware version you selected when you created the VM. ESXi 3.5 is only able to run VMs with HW version 4, ESXi 4.x uses HW version 7 by default.
    André
  • 3.  RE: PLZ help me to solve a problem.
    Posted Jun 13, 2011 11:28 AM
    Hello Andre.
    Firgst off all thank you for reply.I seen this GhettoVCB but no idea how to use it I'm very newbie in VM...
  • 4.  RE: PLZ help me to solve a problem.
    Posted Jun 13, 2011 11:53 AM
    First of all you really should be upgrading your 3.5 server so that the time to get your virtual servers back up and running is kept to a minimum.  As mentioned, the virtual hardware versions are different and it will just cause you unnecessary pain getting them to work.
    In terms of backups, I suggest you look at products like Veaam.  It's an awesome backup tool that would have you up and running in no time at all.  You can even set it to replicate a copy of the guest to the other host just in case you suffer a total loss.
    I hope this helps
  • 5.  RE: PLZ help me to solve a problem.
    Posted Jun 13, 2011 12:00 PM
    Hi NeilRHunter.
    Veaam  is free program?How I can to upgrade the esxi to 4.1?Is there any good guide to do that?
    sry for my english..
  • 6.  RE: PLZ help me to solve a problem.
    Posted Jun 13, 2011 01:07 PM
    OK the util that is free can be found here:
    http://www.veeam.com/vmware-esxi-fastscp.html
    In terms of upgrading your current 3.5 host you can use the host upgrade utility that installs when you install your infrastructure client (from esxi 3.5).
    I think your 3.5 needs to be on update 5 at least.  After that it is a straight upgrade from 3.5 to 4.1.
  • 7.  RE: PLZ help me to solve a problem.
    Posted Jun 13, 2011 01:11 PM
    Thank you very much.
    I created a new job in veaam and this worked perfectly.
  • 8.  RE: PLZ help me to solve a problem.
    Posted Jun 13, 2011 01:18 PM
    Awesome news!
