PowerCLI
  • 1.  network adapter - connected and connect at power on
    Posted Sep 25, 2010 12:57 PM
    Hi
    I have 10 to 20 vms, they are not connected to network, when i checked the status for device the adapter was unchecked for
    connected & connect at power on, how could i enable ( make a check mark) on them using the script ? they are on dhcp.
    Thank you.
  • 2.  RE: network adapter - connected and connect at power on
    Best Answer
    Posted Sep 25, 2010 02:34 PM
    Try this
    Get-VM | Get-NetworkAdapter | Set-NetworkAdapter -StartConnected:$true -Connected:$true
    See the Set-NetworkAdapter cmdlet for more info.
    ____________
    Blog: LucD notes
    Twitter: lucd22
  • 3.  RE: network adapter - connected and connect at power on
    Posted Sep 25, 2010 05:32 PM
    Thanks - it works, i had a do a small change to filter the vmk network. .....:)
    Get-VM | Get-NetworkAdapter | Where { $_.NetworkName -eq "VM Network" } |
  • 4.  RE: network adapter - connected and connect at power on
    Posted Sep 28, 2010 02:31 AM
    is it possible to add 2nd NIC (adapter type: vmxnet3) and remove 1st NIC or uncheck the connected/connect at power on?
  • 5.  RE: network adapter - connected and connect at power on
    Posted Sep 28, 2010 07:58 AM
    That should be possible.
    Have a look at the New-NetworkAdapter cmdlet. With the -Type parameter you can select a vmxnet3 card.
    You can remove the first NIC with the Remove-NetworkAdapter cmdlet. But I would advise to do this when the guest is powered off.
    The alternative is to change the StartConnected option with the Set-NetworkAdapter cmdlet.
    ____________
    Blog: LucD notes
    Twitter: lucd22
