Looking for some assistance please. I have a nested ESXi lab set up and was hoping to learn NSX-T. I have an NSX manager installed on my physical esxi host and I am trying to deploy an Edge node on the nested VM. When I try to deploy the Edge, the "Configuration State" says "Failed" with reason being that "mac address for a vnic fp-eth0 is not found on edge node".
I have allowed MAC address changes, forged transmits and promiscous mode on the Distributed Switch.
In my research into this, I have also read that I should enabled Huge Pages. I have tried both "sched.mem.lpage.enable1GPage - TRUE" and "featMask.vm.cpuid.pdpe1gb (Val:1)". When I use the "featMask.vm.cpuid.pdpe1gb" parameter - the VM fails to power on.
I have also tried deploying manually using the OVA however I still have no luck in getting the VM to power on after setting the "featMask.vm.cpuid.pdpe1gb " parameter.
Has anyone overcome this frustrating issue?
My set up is as follows:
On the Physical ESXi Host: (Dell R720 - Intel Xeon CPU E5-2630) :
vCenter appliance - 7.0.3
NSX Manager 3.2.0.1.0.19232594
3 x VM's with ESXi 7.0.3 installed (These are the nested VM's which will ultimately act as transport nodes)
On the Nested ESXi Hosts:
1 cluster (EVC disabled)
Edge VM
