vSAN1
  • 1.  Need help troubleshooting an issue with HCIBench
    Posted Sep 23, 2024 09:23 PM
    Edited by RKDRnD Sep 23, 2024 09:25 PM
    HCIBench version is 2.8.3.
    vSphere\vSAN version is 8.0.3
    When attempting to run a Test the process fails almost immediately with "[ERROR] Unknown Failed...".
    Deploy.log shows - {"vSAN-Datastore"=>["host1", "host2"]} Unable to connect ESXi host
    On  the ESXi hosts side logs show "SSH session was closed for 'root@HCIBench_IPAddress' fraction of a second after opening the session; as though the SSH login is rejected.
    SSH and Shell services are enabled and running on the hosts. No Firewall restrictions. I am able to SSH with the same credentials form the HCIBench machine's command line to these hosts.
    What could this be? This is a two-node vSAN cluster.
    A few weeks ago this used to work. The only changes that took place since the last time it worked: a) replaced storage controllers on these two hosts and b) replaced vCenter machine self-signed SSL certificate with a custom one.
  • 2.  RE: Need help troubleshooting an issue with HCIBench
    Posted Oct 16, 2024 09:44 PM
    can you try testing one host at a time in HCIBench?
