I'm not familiar with newer-version-specific-problems, but have you tried copy/paste instead of drag? Have you tried from Desktop to Desktop? If you try from or to network drive, it probably wouldn't work.
Other than that, it has always been a bit flaky, but up to version 17.5.2 that is what I always use - except when working with network drives that can be mounted like normally in Linux/Windows (if you use NAT).
Original Message:
Sent: Jun 19, 2025 02:21 AM
Subject: Drag and Drop not working
I have the same problem in VMware Workstation 17 Pro version - 17.6.1 and VMware-tools-13.0.0. I have enabled "Enable drag and drop" and "Enable Copy and Paste" in Guest Isolation but still not working.
Original Message:
Sent: Apr 17, 2025 06:17 PM
Version VMware-tools-12.5.1-24649672-x64
Uploaded Log. Tried draging and dropping from guest to host and host to guest. As stated guest to hosts works but not the reverse.
Original Message:
Sent: Apr 17, 2025 10:17 AM
what version of vmware tools are you using? also please paste the vmware.log file content after you are doing the action of draging and droping a file from host to guest (the log file is in the same directory of where the virtual machine is stored)
Original Message:
Sent: Apr 16, 2025 10:39 PM
Thanks for the reply, however same issue with new vmware tools.
Original Message:
Sent: Apr 16, 2025 11:45 AM
Hi mate, you wrote that you are using vmware workstation 17.6.1, but didn't wrote the vmware tools version you are using (if you installed it of course, because without it, nothing will work)
anyway, I suggest you to install the latest vmware tools available from here in the guest machine: https://packages.vmware.com/tools/releases/latest/windows/x64/
, since the chances the bugs are fixed there
