VMware Tanzu Kubernetes Grid Integrated Edition
 I want to create a dev standalone management cluster on vSphere without NSX, LB and DHCP. I want to fix static IP for nodes using Node IPAM.
Achraf BENTABIB's profile image
Achraf BENTABIB posted Jan 09, 2024 09:07 AM
Hello,
So i used the configuration file as bellow with Node IPAM enabled.
AVI_CA_DATA_B64: ""
AVI_CLOUD_NAME: ""
AVI_CONTROL_PLANE_HA_PROVIDER: "false"
AVI_CONTROL_PLANE_NETWORK: ""
AVI_CONTROL_PLANE_NETWORK_CIDR: ""
AVI_CONTROLLER: ""
AVI_DATA_NETWORK: ""
AVI_DATA_NETWORK_CIDR: ""
AVI_ENABLE: "false"
AVI_LABELS: ""
AVI_MANAGEMENT_CLUSTER_CONTROL_PLANE_VIP_NETWORK_CIDR: ""
AVI_MANAGEMENT_CLUSTER_CONTROL_PLANE_VIP_NETWORK_NAME: ""
AVI_MANAGEMENT_CLUSTER_SERVICE_ENGINE_GROUP: ""
AVI_MANAGEMENT_CLUSTER_VIP_NETWORK_CIDR: ""
AVI_MANAGEMENT_CLUSTER_VIP_NETWORK_NAME: ""
AVI_PASSWORD: ""
AVI_SERVICE_ENGINE_GROUP: ""
AVI_USERNAME: ""
CLUSTER_ANNOTATIONS: 'description:,location:'
CLUSTER_CIDR: 10.96.0.0/11
CLUSTER_PLAN: dev
ENABLE_AUDIT_LOGGING: "false"
ENABLE_CEIP_PARTICIPATION: "false"
ENABLE_MHC: "false"
IDENTITY_MANAGEMENT_TYPE: none
INFRASTRUCTURE_PROVIDER: vsphere
LDAP_BIND_DN: ""
LDAP_BIND_PASSWORD: ""
LDAP_GROUP_SEARCH_BASE_DN: ""
LDAP_GROUP_SEARCH_FILTER: ""
LDAP_GROUP_SEARCH_GROUP_ATTRIBUTE: ""
LDAP_GROUP_SEARCH_NAME_ATTRIBUTE: cn
LDAP_GROUP_SEARCH_USER_ATTRIBUTE: DN
LDAP_HOST: ""
LDAP_ROOT_CA_DATA_B64: ""
LDAP_USER_SEARCH_BASE_DN: ""
LDAP_USER_SEARCH_FILTER: ""
LDAP_USER_SEARCH_NAME_ATTRIBUTE: ""
LDAP_USER_SEARCH_USERNAME: userPrincipalName
OIDC_IDENTITY_PROVIDER_CLIENT_ID: ""
OIDC_IDENTITY_PROVIDER_CLIENT_SECRET: ""
OIDC_IDENTITY_PROVIDER_GROUPS_CLAIM: ""
OIDC_IDENTITY_PROVIDER_ISSUER_URL: ""
OIDC_IDENTITY_PROVIDER_NAME: ""
OIDC_IDENTITY_PROVIDER_SCOPES: ""
OIDC_IDENTITY_PROVIDER_USERNAME_CLAIM: ""
OS_ARCH: amd64
OS_NAME: photon
OS_VERSION: "3"
SERVICE_CIDR: 10.64.0.0/13
TKG_HTTP_PROXY_ENABLED: "false"
VSPHERE_CONTROL_PLANE_DISK_GIB: "20"
VSPHERE_CONTROL_PLANE_ENDPOINT: 192.168.1.100
VSPHERE_CONTROL_PLANE_MEM_MIB: "4096"
VSPHERE_CONTROL_PLANE_NUM_CPUS: "2"
VSPHERE_DATACENTER: /dc01
VSPHERE_DATASTORE: /dc01/datastore/ca
VSPHERE_FOLDER: /dc01/vm/clusterk
VSPHERE_INSECURE: "true"
VSPHERE_NETWORK: /dc01/network/VLAN
VSPHERE_PASSWORD: XXXX
VSPHERE_RESOURCE_POOL: /dc01/host/poolx
VSPHERE_SERVER: 10.10.10.10
VSPHERE_SSH_AUTHORIZED_KEY: ssh-rsa XXXXX
VSPHERE_TLS_THUMBPRINT: ""
VSPHERE_USERNAME: email@email.com
VSPHERE_WORKER_DISK_GIB: "20"
VSPHERE_WORKER_MEM_MIB: "4096"
VSPHERE_WORKER_NUM_CPUS: "2"
WORKER_ROLLOUT_STRATEGY: ""
MANAGEMENT_NODE_IPAM_IP_POOL_GATEWAY: "192.168.1.101"
MANAGEMENT_NODE_IPAM_IP_POOL_ADDRESSES: "192.168.1.102-192.168.1.120"
MANAGEMENT_NODE_IPAM_IP_POOL_SUBNET_PREFIX: "24"
CONTROL_PLANE_NODE_NAMESERVERS: "192.168.1.110, 192.168.1.111"
WORKER_NODE_NAMESERVERS: "192.168.1.110, 192.168.1.111"
NTP_SERVERS: "192.168.1.1"
VSPHERE_TEMPLATE: "/dc01/vm/foldercustom/photon1.27.5"
But this configuration create a VM in vsphere but continue to check cloud-init with DHCP and continue to print "A start job is running for Wait for Network to be Configured ..."
I also notice that the mgmt cluster yaml created enable dhcp...even if used node ipam.
apiVersion: infrastructure.cluster.x-k8s.io/v1beta1
kind: VSphereMachineTemplate
metadata:
 annotations:
  vmTemplateMoid: null
 namespace: tkg-system
spec:
 template:
  spec:
   cloneMode: fullClone
   datacenter: /dc01
   datastore: /dc01/datastore/ca
   diskGiB: 20
   folder: /dc/vm/clusterk
   memoryMiB: 4096
   network:
    devices:
    - dhcp4: true
     nameservers:
     - 192.168.1.110
     - 192.168.1.111
     networkName: /dc01/network/VLAN
   numCPUs: 2
   resourcePool: /dc01/host/poolx
   server: 10.10.10.10
   storagePolicyName: ""
   template: /dc01/vm/foldercustom/photon1.27.5
I use tkg 1.1.0.
Can you help me please ?
