VMware Tanzu Greenplum
 I downloaded and installed a Greenplum 5.0.0 VM from your site. It is up and running but when I try to connect remotely from a java program with a postgres jdbc, I get password authentication failed for user 'gpadmin' I can't seem to get past this.
tom conrad's profile image
tom conrad posted Jun 29, 2018 08:12 PM
It is a test machine so not worried about security. I used pivotal as the database password. Please help. Thanks in advance!!
tom conrad
Any idea's on this? Still haven't solved it. Thanks.
Shawn Yan's profile image
Broadcom Employee Shawn Yan
Hi Tom,
If you haven't verified the pg_hba.conf file for this connection, I would suggest take a look at below document:
https://gpdb.docs.pivotal.io/590/admin_guide/client_auth.html
If you are sure the pg_hba.conf file is correctly setup, then provide the complete error message may help check further. (You can find the complete error message) from master log. $MASTER_DATA_DIRECTORY/pg_log/
tom conrad
Hi Shawn, Thank you for getting back to me. I am pretty sure that pg_hba.conf is set up correctly. Here is the error from the log.GPPasswordErrorI also can't seem to use psql. Here is the error I am getting from it.
GPSQL
The server looks like it up but hard to tell.
Thanks,
Tom
Hi Tom,
Here are a few items to check:
  1. did you run " source /usr/local/greenplum-db-5.0.0/greenplum_path.sh" before running psql?
  2. for gpdb 5.0 vm, did you use the 5.0 sandbox, or a binary file to install and init a new cluster on your VM ?
  3. can you provide the output of " env |grep PG"
tom conrad
Hi Shawn,
Running greenplum_path.sh was the answer. Once I ran that, I could run psql and change the gpadmin password. Now I can access and test the database remotely.
Thanks for all the help,
Tom
