Tanzu
 Enabling traffic encryption with Antrea
Alvaro Fernandez Rodriguez's profile image
Alvaro Fernandez Rodriguez posted Jul 10, 2024 03:57 AM
Hello,
I've been trying to enable traffic encryption in a TKGs workload cluster using Antrea as CNI.
As soon as I edit the antrea-config configmap to enable it, it gets restored to its default state.
I have also tried to modify the antreaconfig CRD in my Supervisor, but trafficEncryptionMode is not a field of the spec.
Is this a supported configuration? Maybe I can mess with the Antrea package that is auto-installed?
Thanks in advance.
Nicholas Marts's profile image
Broadcom Employee Nicholas Marts
Hello Alvaro,
Thanks so much for the great question! Unfortunately right now, the Antrea package is configured/managed by the supervisor cluster base off of the supervisor cluster's desired state for that guest cluster.
I have escalated to our engineering team about exposing these kinds of configurations in a future version and sited your specific use case.
-Nick
vSphere with Tanzu Global Support Lead
Hello Nicholas,
Thanks for your answer. Would we be able to modify this setting if we deployed TKGm instead?
I see it mentioned in the management cluster configuration doc, but it isn't clear to me if this is only for the management cluster, or if I can also apply it in the workload clusters as I can't see it in the workload cluster creation doc.
Thanks again for your time.
