Spring
 Caused by: org.springframework.orm.jpa.JpaSystemException: Unable to commit against JDBC Connection; nested exception is org.hibernate.TransactionException: Unable to commit against JDBC Connection
Gary Shepard's profile image
Gary Shepard posted Mar 14, 2019 04:13 PM
Daniel Lynch's profile image
Broadcom Employee Daniel Lynch
Hi Gary,
Could you provide a bit more context regarding what steps you performed to observe this error and if you have verified the database is healthy? It looks like that error is saying it failed to commit a transaction in the database.
Gary Shepard
Sure, basically I created an application using yoeman generator / Jhipster, I selected MySQL as my database, the app runs fine in my local env, with MySQL, NOTE: local app uses admin/admin and authenticates with no issue.
I use Jhipster to build a manifest.yml, I use a my dev profile, again its a MySQL db
Deploy the app to PCF -
? Name to deploy as: MovieRental
? Which profile would you like to use? dev
? What is the name of your database service? cleardb
? What is the name of your database plan? spark
Creating Cloud Foundry deployment files
Checking for an existing Cloud Foundry hosting environment...
Creating your Cloud Foundry hosting environment, this may take a couple minutes...
Creating the database
Creating service instance movierental in org ea2sa / space uat as gary.shepard@capgemini.com...
OK --- looks ok to me :-)
The app stages and builds w/o issue:
In case you want to see it :-) : https://movierental.cfapps.io/#/
When I attempt to login : I fails to authenticate me, looking at the logs I saw that error:
I've included the ENV VARS just because:
That app not rocket science, I share that if you like as well:
Adding this line from the log also: 2019-03-15T10:40:47.868-07:00 [APP/PROC/WEB/0] [OUT] Caused by: java.sql.SQLException: Can't call commit when autocommit=true
Thank Dan for responded to this
Attachment  View in library
it sounds like you might be getting a stack trace similar to this
https://javabeat.net/java-sql-sqlexception-autocommittrue-exception/
you can disable auto commit by adding the option to your JDBC URL from "VCAP_SERVICES.cleardb[0].credentials.jdbcUrl"
some folks also suggest setting the relaxAutoCommit flag
https://stackoverflow.com/questions/5262327/jdbc-commit-failed-calling-commit-when-autocommit-true-multithreaded-hibernate
Patrick Crocker's profile image
Patrick Crocker
I've seen this problem when using the MySql driver that JHipster is pulling in to use with the `cleardb` PWS marketplace service.  To test, comment out the `mysql:mysql-connector-java` dependency in your `pom.xml` and then re-package and re-push your app.  In the absence of the mysql driver, the java buildpack will auto add in the mariadb-jdbc driver. You should see things working after that.
If that works, you might experiment with packaging the `org.mariadb.jdbc:mariadb-java-client` dependency in your app instead of the `mysql-connector-java` when targeting cleardb.
